Maybe I'm missing something??
Dazbo666
PostPosted: 16:38 - 23 Jul 2011    Post subject: Maybe I'm missing something?? Reply with quote
I've been replacing the old swiss cheese allen bolts for stainless steel alternatives on the Bandit recently, and in the process took the front sprocket cover off the other day...
Well I found a damaged tension spring (approx 10-15mm long, and similar to this), with one end hooked thru a small hole in the sprocket cover, and the other end missing, presumably snapped by the chain/sprocket.
I've double checked the Haynes manual and there's no mention of any tension spring, plus the bike seems to be running as normal.
So I'm wondering if I and Mr Haynes both missed something that should have been fitted??
Word of the day : DILLIGAF
Quote Me Happy
PostPosted: 16:40 - 23 Jul 2011    Post subject: Reply with quote
Is it anything to do with the side stand?
jimbothe
PostPosted: 16:43 - 23 Jul 2011    Post subject: Reply with quote
There was one on the gsx I'm breaking. I believe it's part of the clutch return system. It looks like it keeps the assembly tight and not flapping around the sprocket area.
Edit:
Yep, just took a pic to confirm.
https://i22.photobucket.com/albums/b342/jgillard/gsxclutchreturnspring001.jpg
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Dazbo666
PostPosted: 16:56 - 23 Jul 2011    Post subject: Reply with quote
Edit:
Yup that looks like the fella Thumbs Up Embarassed
Skudd
PostPosted: 17:12 - 23 Jul 2011    Post subject: Reply with quote
I'm sure you could pick one up from a breakers. Rolling Eyes Laughing
caragh
PostPosted: 19:24 - 23 Jul 2011    Post subject: Reply with quote
It's the return spring for the clutch lever it basically takes the little bit of slack up at the handlebar end. I think they are about £4 from a dealer you can leave it off it just means that the clutch lever does not return to a fully closed position snappily.
Triumph Tiger 800 XR
Dazbo666
PostPosted: 14:54 - 24 Jul 2011    Post subject: Reply with quote
I might just do a temporary botch job in "modifying" a small loop in the snapped end, and extend it back to the normal length with some heavy gauge wire Thumbs Up
jimbothe
PostPosted: 15:01 - 24 Jul 2011    Post subject: Reply with quote
or a small tie wrap.
Dazbo666
PostPosted: 13:46 - 28 Jul 2011    Post subject: Reply with quote
Well I've managed to make a temporary fix this morning with a tie wrap ( Thumbs Up to jimbothe)
.... and after MUCH searching, managed to find a supplier that can sell me a new replacement for the princely sum of £2.38 Shocked LOL
jimbothe
PostPosted: 14:02 - 28 Jul 2011    Post subject: Reply with quote
Thats a good site. I've used them before. Thumbs Up
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 66.57 Kb
