Ran a bike on diesel. How buggered is it?
crazyjoyce
PostPosted: 20:07 - 27 Jul 2011    Post subject: Ran a bike on diesel. How buggered is it? Reply with quote
Turns out the smoking problem on my dads Z1000 is from filling and running with diesel Laughing
So besides the fouled plugs, what else is likely to be buggered? Cat, injectors?
Nexus Icon
PostPosted: 20:14 - 27 Jul 2011    Post subject: Reply with quote
Drain it all down and fill it with lovely fresh petrol. He might be lucky.
TBH, it's unlikely to have broken anything, though it might puff a bit of smoke for a short while after start up.
Greetings from Shitsville!
crazyjoyce
PostPosted: 20:21 - 27 Jul 2011    Post subject: Reply with quote
seems to be running better already. will throw in a full tank of petrol and take it for a blast.
reckon its worth getting new plugs?
Nexus Icon
PostPosted: 20:24 - 27 Jul 2011    Post subject: Reply with quote
I wouldn't bother unless I was sure they needed replacing. I might be tempted to give them a clean but the truth is, I'd give it a good chance to sort itself out before I started buggering about like that Very Happy
lozza59
PostPosted: 20:31 - 27 Jul 2011    Post subject: Reply with quote
should be fine i used to race cars around the field a few times with a diesel/petrol mix in a petrol car, apart from taking a lot to start the thing it would run ok once warmed up, though mk3 escorts dont have catylic converters.....
PostPosted: 20:35 - 27 Jul 2011    Post subject: Reply with quote
Wouldn't worry about the cat. There's no emissions test on the bike MOT. If you're really worried about it, chuck it in the bin and buy a decat pipe. Thumbs Up
As they others have said really, drain and refill. Should be fine after a good thrash.
Frost
It's doing things the other way around that you want to be worried about.
jimspeed
PostPosted: 20:57 - 27 Jul 2011    Post subject: Reply with quote
Yea as above just fill it up and see how it runs, as long as it runs ok after a tank of decent fuel thru it don't worry, It may have fouled the plugs a bit but they should self clean with some decent load on the engine Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
crazyjoyce
PostPosted: 21:49 - 27 Jul 2011    Post subject: Reply with quote
excellent! makes my life easier, getting to the plugs is a bastard!
2nd gear everywhere for a while it is Laughing
PostPosted: 21:53 - 27 Jul 2011    Post subject: Reply with quote
Would be a bit tempted to put new plugs in. Maybe a new fuel filter. Although both I wouldn't worry too much about.
However I would be a bit concerned about a lambda sensor in the exhaust (assuming the Z1000 has one).
PostPosted: 22:03 - 27 Jul 2011    Post subject: Reply with quote
Should thrown an engine fault light if it had failed.
PostPosted: 22:06 - 27 Jul 2011    Post subject: Reply with quote
Depends how it has failed. With just the single lambda probe it needs to be way out of spec for the ECU to know about it.
More advanced injection system will have a 2nd lambda probe after the cat and so has far more chance of spotting something up due to mismatched readings.
crazyjoyce
PostPosted: 22:38 - 27 Jul 2011    Post subject: Reply with quote
no FI warning lights, and only the one lambda sensor. will keep an eye on things, will check the plugs after a few tank fulls have been run through
herulach
PostPosted: 00:20 - 28 Jul 2011    Post subject: Reply with quote
I did it on mine about 2 months ago, drained the tank and it took about 10 minutes running before it felt 'normal' not a problem since.
YBR 125>FZS600
Triumph1300
PostPosted: 11:37 - 28 Jul 2011    Post subject: Reply with quote
Change the oil, diesel is a lot more detergent, and penetrative.
Run it on petrol first.
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
The last post was made 15 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 84.1 Kb
