ZX1 oil addictive in my 125cc bike
Gamerwillz This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
0ddball
PostPosted: 10:52 - 28 Jul 2011    Post subject: Reply with quote
If you use a decent oil there is no need for snake oil additives.
Smells like pork
ZXR750L
PostPosted: 10:53 - 28 Jul 2011    Post subject: Reply with quote
Personally don't put any in.
There are a couple of different types of aftermarket oil additives. Those based on teflon, which being a solid will soon be caught by the oil filter. At best they won't block the oil filter that much.
Other type are those based on chlorinated compounds. They will have a minor positive effect for a short while. Trouble is that when heated up (such as in an engine) they react and form hydrochloric acid. As you might expect, acid is not beneficial to metal engine components.
PostPosted: 11:04 - 28 Jul 2011    Post subject: Re: ZX1 oil addictive in my 125cc bike Reply with quote
Gamerwillz wrote:
Hi, my CBF125 is due for its first service at 600 miles and I want to put some ZX1 oil addictive in to extend the life of my engine. The instructions here - https://bit.ly/o8Yr3I, said that I should put 125ml of ZX1 in my bike. But my father that it's WAY too much for a 125cc... so I'm in need for some advice from you guys... How much ZX1 should I put in?
You're not going to own the bike at the point when engine life might become a problem, so don't bother.
This is either one of the most ridiculous threads I've ever seen by someone who is too gullible for words and suceptible to all sorts of marketing claptrap, or is SPAM.
I call Spam actually.
PostPosted: 11:32 - 28 Jul 2011    Post subject: Re: ZX1 oil addictive in my 125cc bike Reply with quote
Gamerwillz wrote:
Yeah but I bought the bike from new so I'm looking after it, keeping it clean, etc... ZX1 will lower the wear that is happening in the engine. I sure would like some ZX1 in my brand new bike.
It will almost certainly not lower the wear. Depending on what kind of additive it is it will likely increase wear in different ways.
If you want to reduce wear then change the oil frequently and let the engine get properly up to temperature before using it hard.
DrDonnyBrago
PostPosted: 11:42 - 28 Jul 2011    Post subject: Re: ZX1 oil addictive in my 125cc bike Reply with quote
Two posts and both are about some snake oil bullshit additive...
SPAM
PostPosted: 12:30 - 28 Jul 2011    Post subject: Reply with quote
No 17 year old can spell as well as that...
Spam.
PostPosted: 12:37 - 28 Jul 2011    Post subject: Reply with quote
Not sure. Quick google finds a few links to Gamerwillz about the CBF125 but this thread is the only one asking about dodgy oil additives.
weasley
PostPosted: 13:24 - 28 Jul 2011    Post subject: Reply with quote
Any engine oil already has all the additives it needs to do the job, so long as you change it when you're supposed to.
Keith summed up the two aftermarket additive types and I endorse everything he said, through personal experience of engine oil product development and technical support. When I developed an oil, I didn't leave anything out.
Adding any aftermarket additive for one thing is against all manufacturers' instructions and could therefore lead to voiding your warranty (if you have one). Secondly, once you have added whatever it is you want to add, the oil no longer meets any of its specifications or approvals (API, ACEA, JASO, OEM etc) and so there's no saying how it will perform in service.
If you're worried about wear then use a good quality oil and change it regularly. I have personally seen engines with 100's of thousands of miles on them with virtually no wear because they were well-maintained with good oil.
Gamerwillz This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
PostPosted: 00:46 - 29 Jul 2011    Post subject: Reply with quote
Gamerwillz wrote:
I will have to talk to my father about this, and my uncle... Thanks guys for advices, they counts.
I'm sorry but some of you guys thinks I'm spamming this thread. Seriously? Neutral
Lol, you mention that additive loads, thats why.
Never added any shit to my oil, straight from the bottle and into my engine and ragged senseless.. even the car doesnt get special treatment!
andys675
PostPosted: 21:37 - 29 Jul 2011    Post subject: Reply with quote
additive?
what the fuck for? modern oils are already full of additives, just read the label on the back
if you really want to prolong the life of your engine, check the oil level religously and change it often with good quality oil
prawny1
PostPosted: 21:42 - 29 Jul 2011    Post subject: Reply with quote
modern oils will keep your engine good for many years without additional additives, honestly just stick to good old semi synthyetic and you should be fin for the forseable future.
your bikes not even run in yet chill out,
hellkat wrote:
jimspeed
PostPosted: 22:03 - 29 Jul 2011    Post subject: Reply with quote
As said by everyone else there is no need for any extra additives to be added as decent modern oils are very very good, also adding anything to it may damage the clutch (if its wet clutch like most bikes are).
Even in my highly stressed (and expensive )rally car engines I use a decent oil with no extra's and regular changes.
You will help your engine stay in good shape longer by letting it warm up before revving it hard etc than adding anything to the oil.
Just check the spec that the manual says is recommended and stick to that.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
neil.
PostPosted: 22:28 - 29 Jul 2011    Post subject: Reply with quote
+1 for the regular oil changes, level checking/topping up and warming up. Did this regime with my old YBR (Halfords semi-synthetic 10w40, changed mostly every 2'000 miles, sometimes let it slip to 4'000) and the engine was still fantastic, even after 40'000 miles on the clock. The only work I ever did on the engine was valve clearances, checking the cam chain tensioner once because of my paranoia about hearing phantom noises, and I took the casing off to check the oil strainer for the first time at 38'000 miles - it was very clean, with just a couple of small specks of dirt on it. There was a very tiny amount of sludge in the very bottom of the casing, right in the nooks and crannies of it, you could scrape it all out with a toothpick. The clutch housing looked in good shape, no notches in the basket. Not bad at all.
PostPosted: 23:13 - 29 Jul 2011    Post subject: Reply with quote
I put some Slick 50 into some old 50,000+ mile 70's/80's era cars with suspect service history back in the Day. Pouring it in while the engine was running, the reduction in clatter was immediate and dramatic.
BUT, old cars are not new bikes. If you know the service history of your bike, don't nob it up by adding anything that might cause you trouble.
Gamerwillz This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
pits
PostPosted: 19:30 - 30 Jul 2011    Post subject: Reply with quote
Gamerwillz wrote:
Noticed that some of my posts on here are hidden because they're "spam", I'm sorry but I think you guys are retarded. Just got my first glimpse of what the members on these forums are like.
Don't post shit then Wink
stonesie
PostPosted: 19:42 - 30 Jul 2011    Post subject: Reply with quote
Some say.... Honda 125 4 strokes will run until about 4 years after doomsday with minimal maintainance, putting snake oil designed for clapped out old yank-tanks into a brand new 125 is totally un-necessary.
At worst the bits in there designed to sort out shagged old internals will actually damage your pristeen new internals.
The absolute best thing you can do is keep it well serviced with good quality oil, have the bike treated with ACF 50 or the like to keep the dreaded rust at bay and go easy on it for the first couple of miles on every ride to let things warm through.
chrisw
PostPosted: 19:53 - 30 Jul 2011    Post subject: Re: ZX1 oil addictive in my 125cc bike Reply with quote
This is why you've been spanked with 'SPAM' ratings.
As for retarded, I'd pin that badge on users of oil additives. Thumbs Up
There is a gap of 1 year, 328 days between these two posts...
i2ico This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
trevor saxe-coburg-gotha
PostPosted: 06:10 - 23 Jun 2013    Post subject: Reply with quote
Yehrite.
Nice account dude.
j.silvs
PostPosted: 10:31 - 23 Jun 2013    Post subject: Reply with quote
Thank fcuk.
Been looking into snake additives all night long..... I'm going to buy ten boxes now, what was your site again?
The last post was made 13 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 135.43 Kb
