| UpcomingChris |
 UpcomingChris Nova Slayer
 Posted: 01:41 - 28 Jul 2011 Post subject: CG125 problem..... again |
Ok so after fixing problems on my CG, It is all running smoothly.... Sort of.
The bike starts first time 90% of the time, and if it doesn't it's because i'm a spaz and didn't kick it properly.
When i let it idle, it usually cuts out, Used to do it pretty quickly, sounded like it was trying to catch its breath, and would sometimes just stop.
Even when doing 40MPH,If i pull the clutch in an the revs drop, it's pretty much defiantly going to cut out.
Then i changed the oil as it needed some, and it doesn't do it as much, but i still won't let it idle at junctions, usually cuts out 5-10 minutes after idling, it varies alot.
I think it could be the Idle screw, I've tried moving it but the bugger just won't move!, i've WD40'd it, and it's not budging.
Any ideas what this could be, and how to fix it?
BTW: I'm no mechanic, i was assured at 10/40 oil would be all right for it, so i used that, i drained it from the nut, then put the new oil in where the dipstick is, (Should have used a Funnel or something, Ended up making quite a mess).
The dipstick shows just under the 'full' mark thing, so i think that is all fine, Pleas help! |
| Ingah |
 Ingah World Chat Champion
| TUG |
 TUG World Chat Champion
 Posted: 08:01 - 28 Jul 2011 Post subject: |
Idle screw not moving? Positive it is the correct screw you are turning?
How old is the spark plug? I had problems like this due to a crap old plug, fitted a new one then the bike was happy. Generally just check that the carb rubber isn't split, the air filter is clean, and that the choke is in the correct position when riding (mine used to bounce on meaning cut outs).
If the idle screw is really stuck I would suggest that you soak it with WD-40 or some penetrating oil and retry, sometimes a bit of shock can free up a stuck screw or heat but as there is petrol in the carb I wouldnt recommend the last option.  ____________________ Haz ER-5, innit! |
| UpcomingChris |
 Posted: 12:52 - 28 Jul 2011 Post subject: |
| TUG wrote: | Idle screw not moving? Positive it is the correct screw you are turning?
If the idle screw is really stuck I would suggest that you soak it with WD-40 or some penetrating oil and retry, sometimes a bit of shock can free up a stuck screw or heat but as there is petrol in the carb I wouldnt recommend the last option.  |
I have looked at a manual thing online, and it is infact the idle screw, I soaked it in WD40, i'll try it again later. And i have a new spark plug that is not in yet, I will plonk that in and see what happens, I will report back later today
EDIT: I have found somthing, On the carb there is a rubber tube going to the Air filter, There is a split in that, Would that be causing the problem?, If so, Where can i get a nw one?, or can i just glue it? |
| N cee thirty |
 N cee thirty Banned
| UpcomingChris |
| TUG |
 Posted: 22:36 - 28 Jul 2011 Post subject: |
Your welcome Chris.  ____________________ Haz ER-5, innit! |
| UpcomingChris |
 Posted: 22:43 - 28 Jul 2011 Post subject: |
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful? |
