1996 Suzuki Bandit 600S
BBM
PostPosted: 14:57 - 28 Jul 2011    Post subject: 1996 Suzuki Bandit 600S Reply with quote
When my 1996 Suzuki Bandit 600S is parked, what position should I leave the vacuum petcock in: Pri, On, Res? After an 80K run, gas will slowly leak from carbs. I think if I could shut off the petcock, I could stop this annoying slight leak. Thoughts?
Thanks,
BBM
BBM
PostPosted: 15:25 - 28 Jul 2011    Post subject: Reply with quote
Thanks Vincent. I'll check out replacing the petcock. I looked at the carbs and valves about a month ago and they really looked clean.
BBM
BBM
PostPosted: 16:01 - 28 Jul 2011    Post subject: Reply with quote
Thanks for your help. I will proceed as suggested. I hate leaks of any sort, especially fuel!!!!
BBM
PostPosted: 16:27 - 28 Jul 2011    Post subject: Reply with quote
Vincent, by the way, what is the best position for the petcock to be in, while the bike is parked, or doesn't it make any difference?
Ditto
PostPosted: 19:26 - 28 Jul 2011    Post subject: Reply with quote
Leave it in 'on'.
It's a vacuum switch jobby so no fuel will flow unless the engine is on.
If you leave it in 'prime' fuel will flow regardless so its not the best thing to leave it on if you have a leak.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
The last post was made 15 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 54.66 Kb
