Which way round ? Fuel Filter
WannaBeDude
PostPosted: 22:32 - 01 Aug 2011    Post subject: Which way round ? Fuel Filter Reply with quote
No indication on item or woefull packing ? Confused Karma
https://i37.photobucket.com/albums/e53/covdude/01082011.jpg
R6 Wilson This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
WannaBeDude
PostPosted: 22:55 - 01 Aug 2011    Post subject: Reply with quote
Fuck off Pedo ! Smile
nowhere.elysium
The Pork Lord
PostPosted: 22:58 - 01 Aug 2011    Post subject: Reply with quote
I reckon you want the little bit with the filter connected to the tank, big bit connected to the carb. Screw it together before connecting the hoses, of couse.
WannaBeDude
PostPosted: 23:12 - 01 Aug 2011    Post subject: Reply with quote
Reckon Shocked
calyx
PostPosted: 02:02 - 02 Aug 2011    Post subject: Reply with quote
covdude wrote:
Reckon Shocked
Lucky he didn't say "spray some wd40 on it"
Boris - London
temeluchus
PostPosted: 02:06 - 02 Aug 2011    Post subject: Reply with quote
With that style of filter it probably isn't hypercritical which way it goes.
As a guess I would say you should put the cap end on the tank hose and the main body to the carburettor as it looks like it would allow larger chunks of crap to settle without obstructing the gauze.
PostPosted: 09:44 - 02 Aug 2011    Post subject: Reply with quote
This is correct but for a different reason. The larger screwcap goes towards the fuel tank, so that when it get's clogged up you can 1) see that it is by un-screwing the cap and 2) see that it's clean when you clean it out. You also benefit from a greater surface area.
R6 Wilson
PostPosted: 09:50 - 02 Aug 2011    Post subject: Reply with quote
SMD
sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf sdfsdf
♥ YZF-R6 '05 ♥
Time is money so I stay late
nowhere.elysium
The Pork Lord
PostPosted: 10:35 - 02 Aug 2011    Post subject: Reply with quote
calyx wrote:
covdude wrote:
Reckon Shocked
I also reckon that this should be done.
WannaBeDude
PostPosted: 10:47 - 02 Aug 2011    Post subject: Reply with quote
Scroll down the page and watch the third vid, tis how you make me feel at present.
You may want to watch the first 2 vids after, but the THIRD one first, tis my reply. Smile
I'm the comedian in the vid, the shop selling the duva is this thread, and the bcf replies are the sales assisant Thumbs Up Cool
https://www.squidoo.com/rhod-gilbert
One of you, poss who's ginger is geting the punch to the face !
nowhere.elysium
The Pork Lord
PostPosted: 10:55 - 02 Aug 2011    Post subject: Reply with quote
Charming.
For the record, I'd still fit it the way round that I suggested, regardless of Pete.'s (probably better) suggestion, largely because I'd take the whole thing off, if I was intending to clean it.
WannaBeDude
PostPosted: 11:24 - 02 Aug 2011    Post subject: Reply with quote
Something online said about allowing the filter to clapse in on itself without creating an opening.
As for the comment you quoted, i hope you have watched the third vid, so funny and applicable to my noob confusion. Esp with the end of it being about the punch.
In other words totally joking so hope you did not take it otherwise. Thumbs Up
For the record, i'm not fitting it until someone says for absolute certainty which way it goes !! Evil or Very Mad
PostPosted: 11:29 - 02 Aug 2011    Post subject: Reply with quote
If it was me, I'd put the right hand part on the tank side and the left hand on the carb side.
WannaBeDude
PostPosted: 11:32 - 02 Aug 2011    Post subject: Reply with quote
Evil or Very Mad You best watch vid 3 i listed !!!!!!!!!!!!!!
DrDonnyBrago
PostPosted: 11:39 - 02 Aug 2011    Post subject: Reply with quote
You wont go far wrong with following Pete's advice Thumbs Up .
I also would put the RHS bit on the tank side and and filter bit on the carb side, to clean it out you just undo the cap (right hand side bit) and brush away the bits. If it was the other way round you would need to take it off and find a way to remove the filter element so you can clean behind it. The dirty side (the side that leads FROM the tank) will always be more accessible as it needs to be accessed more frequently.
TLDR - Right hand bit on the tank side and left hand bit on the carb side.
WannaBeDude
PostPosted: 11:47 - 02 Aug 2011    Post subject: Reply with quote
Ok will do, i have to cut the fuel line and attach it, the fuel line from the on off tap is about 12 inches long, should i attach it anywhere will do or somewhere more specific ? ta Karma
PostPosted: 11:49 - 02 Aug 2011    Post subject: Reply with quote
I would attach it to the most vertical part of fuel line, just because im a tart and figure gravity pulls down..
WannaBeDude
PostPosted: 11:52 - 02 Aug 2011    Post subject: Reply with quote
Clever ! anyone watched the vid Laughing
DrDonnyBrago
Makes no difference, fit it somewhere convenient.
WannaBeDude
PostPosted: 12:11 - 02 Aug 2011    Post subject: Reply with quote
PostPosted: 13:45 - 02 Aug 2011    Post subject: Reply with quote
Appropriate karma dispensed in this thread for filling a workshop thread with irrelevant drivel that (at best) belongs in random banter if not F&FW.
I response to the OP, I agree that the bit on the right should be nearest the tank for ease of cleaning and I also tend to keep them as near vertical as possible in case of air locks, although this is probably an irrelevance.
It won't make any difference to the actual function of the filter which way up it is though.
Incidentally, you'd have been cheaper and better with a disposable paper element filter like this:
https://levahnbros.files.wordpress.com/2010/02/fuel-filter.jpg
Although less tarty. You can see through them so you can watch the fuel flow and see any dirt or water contamination. There is also a comparatively massive surface area for filtration. This type do need to be fitted the correct way round and usually have an arrow on them.
WannaBeDude
PostPosted: 14:03 - 02 Aug 2011    Post subject: Reply with quote
Watch the vids have a laugh, chill out, f and fw wtf ! Shocked Thumbs Down
PostPosted: 14:18 - 02 Aug 2011    Post subject: Reply with quote
Use common sense, fit filter, ride bike. Rolling Eyes
WannaBeDude
PostPosted: 14:21 - 02 Aug 2011    Post subject: Reply with quote
Have you even watched the 3rd video ?
The last post was made 15 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 132.53 Kb
