| adamck |
 adamck Crazy Courier
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 00:17 - 04 Aug 2011 Post subject: |
first of all check the brake adjustment is ok on the adjuster,then get a small screwdriver or plastic rod and force the brake light switch a little further up the tunnel towards the lever.some brake light switches are slotted so make sure its gone in the slot properly.
If that does'nt work and you still have the old switch then try taking it apart and cleaning it and see if you can bodge it. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| flumpy7 |
 flumpy7 Could Be A Chat Bot
| adamck |
| unitynotsocri... |
 Posted: 14:16 - 04 Aug 2011 Post subject: |
flumpy7 advice is best,if you can add a little pad on the lever,or,sit there for hours pressing the switch on n off to weaken the spring. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| adamck |
| unitynotsocri... |
 Posted: 14:34 - 04 Aug 2011 Post subject: |
should do even a little bit,but like flumpy7 has pointed out you need to add a tiny bit of length to the top of the switch or add somthing to the lever to press the switch in a bit more.If you rough up the top of the switch then add a tiny blob of araldite it should be enough to do it.
If all else fails at the mot then show the mot tester the recipt/old switch and tell him tour problem ,he might ignore it as you are pro active about having a safe bike. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| adamck |
 Posted: 14:37 - 04 Aug 2011 Post subject: |
The MOT guy is one of my best mates, but... he is very particular (which is a good thing) and due to where he works they need him to be particular lol.
And if my bike wasnt MOT passable then i wouldnt want it to pass
I will try the araldite method  ____________________ <insert><something><useful>Here</useful></something></insert> |
| Blau Zedong |
 Blau Zedong Banned
The last post was made 14 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
