ExUP valve
Jayy
Mr. Ponzi
PostPosted: 23:45 - 03 Aug 2011    Post subject: ExUP valve Reply with quote
Do I need the exup valve on my zx10r? Will there be any advantage to removing it?
Also, what about the cat in the exhaust and mid pipe? Will I get any gains by removing the cat and putting a different mid pipe on there?
Any help is appreciated as I keep reading conflicting things on Google.
MaybeGuy
PostPosted: 23:56 - 03 Aug 2011    Post subject: Reply with quote
buy a full system and map it. if it's anything like the 636 of the same age it's a noise regulations thing. the cat is obviously emissions.
obviously removing without remapping will cause a few flat spots, so get a PC3
TUG
PostPosted: 00:53 - 04 Aug 2011    Post subject: Reply with quote
He already has a PC3.
Haz ER-5, innit!
Paulington
PostPosted: 03:34 - 04 Aug 2011    Post subject: Reply with quote
Replace the ENTIRE exhaust system including downpipes etc with a new system which removes the catalytic converter and EXUP valve, then take it to a professional motorcycle shop that has a dyno and makes custom maps, usually costs about £30 for a custom map I believe.
It will run MUCH better, this is exactly what has been done to my GSX-R1000, with the full Akrapovic race system it gained 8bhp at the rear wheel over stock. Thumbs Up.
PostPosted: 05:49 - 04 Aug 2011    Post subject: Reply with quote
Stick a 1 on the front of that and you'll be getting close.
PostPosted: 07:04 - 04 Aug 2011    Post subject: Re: ExUP valve Reply with quote
EXUP Valve is the Yamaha system, but I know what you mean. Razz No advantage just by removing. May find you gain some top end and lose a touch of bottom end after it's mapped.
Again very little gain without mapping, a larger gain across the range with mapping.
The best way for big power would be a full Akra system and a race air filter, however from memory you were after a slash fit can anyway?
Jayy
Mr. Ponzi
PostPosted: 09:44 - 04 Aug 2011    Post subject: Reply with quote
I'm not too fussed on a few extra HP, was just told it would improve the sound of the exhaust note by removing it. Would like it sounding meaner than it does and a slash cut / race fit type exhaust would help too Very Happy
PostPosted: 09:51 - 04 Aug 2011    Post subject: Reply with quote
Suspect you will gain a few at the top end and lose a few in the mid range (probably giving you a flat spot in the mid range).
No doubt the valve does help with keeping the noise down at low and medium revs though.
The last post was made 15 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 58.57 Kb
