starting problems 600bandit
01Thaiboxer
PostPosted: 12:30 - 05 Aug 2011    Post subject: starting problems 600bandit Reply with quote
Hi. I have a P reg Bandit. I went to start it the other day but the bike was dead. It had ignition lights but nothing else. No lights,indicators, horn and the engine wont start. The side stand switch has been disconnected before i had the bike. The ignition switch was faulty so Ive changed this but still no luck. Ive checked the fuses, block connections and the wiring the wiring around the headstock. Ive come to a dead end. Id appreciate any help. Thanks.
Simon
temeluchus
PostPosted: 12:46 - 05 Aug 2011    Post subject: Reply with quote
tried charging the battery or jumping it from another?
01Thaiboxer
PostPosted: 21:18 - 06 Aug 2011    Post subject: Reply with quote
Forgot to say; its got a new battery. Since i wrote last ive also checked all other block connetors, the 30amp fuse and the connetions into the CDI. Cleaned all but still cant get any life. Any more ideas? Sad
Thanks
Simon
ThoughtContro...
PostPosted: 21:52 - 06 Aug 2011    Post subject: Reply with quote
Maybe there's a fault with your loom or an earth connection somewhere if it's knocking out all you've indicated. You could dig out a wiring diagram and a meter and check voltages and connectivity at various points. A PITA tho.
Prize cunt
01Thaiboxer
PostPosted: 10:27 - 10 Aug 2011    Post subject: Reply with quote
Hi all. Ive sorted the problem. There was a block connector under the right side panel that connected to earth. It was green! Cleaned it; bike sorted. Thank guys for taking the time.javascript:emoticon('Razz')
Simon
The last post was made 15 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 42.4 Kb
