Biker with a cage (car) question! Mis-matched tyres.....
cb1rocket
PostPosted: 13:52 - 08 Aug 2011    Post subject: Biker with a cage (car) question! Mis-matched tyres..... Reply with quote
Hi all
My car is due for an MoT in just over a month and i'm concerned about the tyres on my front axle having a different tread pattern.
One is like a normal road going one and the other being an arrow sporty looking tread pattern. Both tyres are the same size and both are radial tyres. I know you can't mis match construction type ie radials and cross ply etc. But can you mix tread patterns?
Cheers!
Sorry its not a bike question!
DrDonnyBrago
PostPosted: 13:58 - 08 Aug 2011    Post subject: Re: Biker with a cage (car) question! Mis-matched tyres..... Reply with quote
You can mix tread patterns as much as you want, makes no difference to the MOT, my car ALWAYS has mis matched tread patterns. I had four different brand tyres on there at one point Smile .
PostPosted: 13:58 - 08 Aug 2011    Post subject: Reply with quote
Suspect a very large percentage of cars on the road have mismatched makes of tyre on the same axle.
Not ideal but not really a major problem
Fizzer Thou
PostPosted: 13:59 - 08 Aug 2011    Post subject: Reply with quote
The tread pattern will not make any differance to the MoT testers decision making.He/she will be looking for the depth of tread,bulges in the sidewall,cuts/nails/tears and severe ozone cracking.If you have front wheel drive,put the best tyres on the front.
Always have a 'Plan B'
cb1rocket
PostPosted: 21:00 - 08 Aug 2011    Post subject: Reply with quote
thank you to all, nothing to worry about then!
Its only a mondy! Laughing
StevRS
PostPosted: 03:42 - 09 Aug 2011    Post subject: Reply with quote
In any four wheeler you want to put the best tyres on the BACK, not the front. Understeer is far easier to control than oversteer. Smile
https://en.wikipedia.org/wiki/Tire_rotation
MV Agusta Brutale 800 RR, Unfinished 1978 XS250
stonesie
PostPosted: 15:00 - 09 Aug 2011    Post subject: Reply with quote
I disagree but then again, untill recently I had a powerful rear drive car with no ABS or traction control so I kinda had to learn how to control a rear end slide Twisted Evil Lots of fun Twisted Evil
(1989 BMW 3 series with a 2.8 transplanted in and not left standard)
If you loose the back you can control it with the front because the front does most of the brakeing and steering.
If you loose the front you have just kissed goodbye to all your steering and 80% of your brakeing power untill you get those tyres gripping again, or hit something solid.
Back to the main point, as long as both fronts are the same size as eachother and both rears are the same size as eachother it's all good. Some cars are fitted as standard with different sizes front to back.
Oh, if it is a rotational tyre it must be fitted the right way for the side of the car that it is on, it will say on the sidewall.
The last post was made 15 years, 37 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 57.16 Kb
