will an 18 volt battery blow reg?
skatefreak
PostPosted: 15:26 - 09 Aug 2011    Post subject: will an 18 volt battery blow reg? Reply with quote
Hey all there.
Well the NSR is still alive and kicking and I'm just about to swap the stator coils and regulator but i dont have a battery yet...
I was wondering if it would be a good idea to put the new regulator in there whilst the current battery is in there as it is sitting around 18 volts and i am a little concerned that the high voltage on the battery side may do some harm to the new regulator...
Any thoughts would be much appreciated.
Best regards
-Jvr
PostPosted: 15:30 - 09 Aug 2011    Post subject: Reply with quote
18V battery, or is the regulator / rectifier screwed and charging at 18V?
skatefreak
PostPosted: 15:36 - 09 Aug 2011    Post subject: Reply with quote
the origional reg that came on the bike blew and i put in a spare one i had and a new battery.....
this one then in time blew itself and has been abusing the battery which new sits at 18 volts with the ignition off...
When riding the reg puts out some odd voltages but the battery itself doesnt put out enough current to start the bike.
I'm sick of bumping (for the past few months) again *sighs*.
I would get a new battery and put it in at the same time but due to working all the time and all my tools being at my parents house at the moment, if I'm to get it done soon I would have to do it today and then put a battery in tomorrow/later in the week.
Best regards
-Jvr
PostPosted: 15:42 - 09 Aug 2011    Post subject: Reply with quote
18V sounds very dodgy. Normal lead acid battery you will get 2V per cell, and there should only be 6 cells.
While the rr might take the voltage I wouldn't be surprised in the slightest if it were damaged by it. However I would also not be at all surprised if any other electrical components were damaged by that voltage (ie, cdi unit, power valve control unit, rev counter, etc).
If the voltage is already all over the place when the engine is running then I wouldn't be surprised if the rr is already dead.
Bezzer
PostPosted: 16:01 - 09 Aug 2011    Post subject: Reply with quote
I've seen a Blackbird that put out 18volts because of a knackered reg/rec owner wondered why the lights were ultra bright before they kept blowing Very Happy . He got away with just the blown bulbs and a boiled/fried battery, luckily didn't take out more expensive stuff though no doubt it would have if he hadn't caught it fairly quickly.
You sure the multimeter is working OK? there's no way it should show a 12v battery putting out 18v with the engine not running.
PostPosted: 16:03 - 09 Aug 2011    Post subject: Reply with quote
Our ZZR rr died and would charge at ~18V. Most things survived but it killed the control unit for the heated grips.
pepperami
PostPosted: 19:18 - 09 Aug 2011    Post subject: Reply with quote
Hmmm? if that was my battery chucking out 18v through my bikes 12v system, I`d take it off straight away Shocked befor all my wires and little black boxes got cooked!
But hey that`s just me Thumbs Up
skatefreak
PostPosted: 10:38 - 10 Aug 2011    Post subject: Reply with quote
hey all,
thanks for the input,
the little bike seems to be handling it pretty well to be honest, no bulbs blown, power valve working as it should do...
I pulled off the alternator side of the engine to swap the stator and found water in there Neutral
Turns out there is a little part missing from the starter that covers the hole where the + cable goes in, this had let water in (thrown up from the front wheel), flooded the starter and one side of the engine...
All the waters out, starter has been cleaned thoroughly as well as that side of the engine and the stator swapped.
Just need to swap the reg and put the new battery in. I opted to put a new one on and try aviod blowing it again Neutral
If this reg goes again i have no idea where to look as there isnt much between the stator coils and the reg and I will check the earth on the reg this time...
Darn late 1990's hondas and there reg blowing habbits Neutral
All the best.
-Jvr
Bezzer
PostPosted: 13:54 - 10 Aug 2011    Post subject: Reply with quote
This 18 volts from a battery with nothing running has bugged me so I'm not being sarcastic here but do you know how to use your multimeter correctly??
Reason I ask is you should be checking with it set to DC volts, (usually a 20v setting on the meter). I've just checked a shagged battery in the garage that was only showing 9.8v DC, switching to AC volts it then gives a reading of 20.2v AC Idea , sticking the charger on it so 13.8v DC is running into it then shows 29.6v AC.
This would explain your weird 18v reading, the only time you should really be using the AC setting is the stator/alternator output BEFORE it goes into the reg/rec.
If you do know what you're doing then forgive and ignore me but use another multimeter to make sure yours isn't knackered Mr. Green
skatefreak
PostPosted: 19:12 - 10 Aug 2011    Post subject: Reply with quote
heh,
Yeah I have half a clue when it comes to the basics with these Smile
I threw in another reg, stator, battery and ignition di-hicky (next to the stator) and the new battery is charging at a more reasonable 13.5v throughout the engine rev range so all is back to normal.
I will certainly keep an eye on this though, am thinking of puting a voltage meter display on the clocks out of paranoia...
Much appreciation for the responses.
-Jvr
The last post was made 15 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 69.46 Kb
