runing in my af1 125 sports pro
penis020
PostPosted: 21:08 - 10 Aug 2011    Post subject: runing in my af1 125 sports pro Reply with quote
hi could anyone tell how to run my bike in correctly my af1 125 sports pro engine has just been fully rebuilt any tips would be helpful many thanks jamie
stirlinggaz
PostPosted: 21:27 - 10 Aug 2011    Post subject: Reply with quote
hi,
im gonna get masel comfy for this..................
be prepared for conflicting/vastly differing opinions on this.
i've always stuck to the same routine after changing the piston &/or rings on my 2t's : varying the revs as much as possible for first few hundred miles..... not redlining it. steadily increasing the max revs. ie sticking to 5000rpm for a bit... then 6000, then 7k, etc.
depending on the type of piston used, using decent 2t, etc etc.
im not going to bother with specifics, simply because what works for me, i can guaruntee umpteen other folk will say im doing it wrong,lol.
but never had any issues after any top end work I'VE done ("running in" related anyway").
but if you want specifics, i'll elaborate,lif you do,lol. (who done what work, make of piston, bottom end flushed?, reason for re-build etc etc)
good luck,
cheers,
GAZ
Livefast123
PostPosted: 22:11 - 10 Aug 2011    Post subject: Reply with quote
There's so many differing views on this and nobody can really say which is best. Just to be different I tried the 'hard' run in on my NSR that I rebuilt a couple of months ago.
1.Start engine and run till it's up to temperature - \Check for leaks etc.
2.Start engine and run up to temperature then take bike out on the road keeping below 6000 rpm.
3. Find a long straight bit of road then put it in 3rd gear and run it from rolling pace up to the redline. When you reach the redline let go of the throttle and let the engine run back down to walking pace.
4.Do this 6 times with cooling (slow riding) time in between and your done.
Compression tested the engine after trying this technique and it read 140 PSI which I was impressed with given the quickness of the procedure.
Obviously using this procedure I made sure that I had top grade synthetic oil and had warmed the engine up fully as the potential for disaster is ever present Twisted Evil
Current ride - Yamaha MT-07
PostPosted: 23:41 - 10 Aug 2011    Post subject: Reply with quote
I would agree with stirlinggaz' method.
Livefast123
PostPosted: 11:35 - 11 Aug 2011    Post subject: Reply with quote
I would normally, but after speaking to a couple of MX friends who swear by the hard break in method i thought i'd try it and was impressed.
PostPosted: 12:14 - 11 Aug 2011    Post subject: Reply with quote
But after how many hours use are their MX bikes rebuilt?
The last post was made 15 years, 28 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 49.89 Kb
