honda c90e electrical problem
machete101
PostPosted: 15:58 - 11 Aug 2011    Post subject: honda c90e electrical problem Reply with quote
hello i have a honda c90e, the engine has been put on to a pitbike frame so it only has the basic wiring to run.
it used to run but used to cutting out when you tried to apply any sort of throttle, i cleaned and then eventually change the carb, so i was told to check the points, so i set them to 0.3-0.4mm which is what it says in the manual.
however i now not getting a spark at the plug or at the points, and now i dont no what i need to do or check, should i check the voltage etc at the different wires and coil, if so what are the values i am looking for and how do i check the coil.
If not what else should i check or do?
thanks
Drake
PostPosted: 11:13 - 13 Aug 2011    Post subject: Reply with quote
you killed the un-killable Shocked yer just keep fiddling till you get a spark
The last post was made 15 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 36.18 Kb
