Acid etching vs Zinc Priming
koolio
PostPosted: 22:24 - 11 Aug 2011    Post subject: Acid etching vs Zinc Priming Reply with quote
On the topic of rust proofing before painting. Ok you've just sanded/cleaned/brushed the rust back to the steel.
Some people say its enough to just put zinc primer on bare steel others say you always need acid etching on bare metal, no question.
I'm stuck between the two, anyone able to shed some light?
koolio
PostPosted: 18:47 - 12 Aug 2011    Post subject: Reply with quote
No one's ever done this?
Drake
PostPosted: 18:54 - 12 Aug 2011    Post subject: Reply with quote
galvafroid? paint with zinc in? just paint over it?
koolio
PostPosted: 19:25 - 12 Aug 2011    Post subject: Reply with quote
Good call thanks wonder how it compares to Isopon David's Zinc 182.
It is a paint however so don't know how well paint adheres to it and I was after a Primer or acid etching
Drake
PostPosted: 19:27 - 12 Aug 2011    Post subject: Reply with quote
not a clue, but we use it at work if someone want something galvanising, but cant wait, plus you dont have to use morden solution to make it dull
ZRX61
Victor Meldrew
PostPosted: 20:05 - 13 Aug 2011    Post subject: Reply with quote
I use epoxy primer.
They're not one night stands, they're auditions.
koolio
PostPosted: 19:39 - 17 Aug 2011    Post subject: Reply with quote
ZRX61 wrote:
I use epoxy primer.
Personally my least favoured method (although without justice as I've never tried it).
Having read up about it I know Galvafroid is good but it is overkill for me at the moment as its very expensive.
I was under the impression etch primer (Por or whatever) was used more for aluminium and that its pointless overcoating it with zinc primer afterwards.
I've heard Bondaprimer + zinc is good.
So I'm still in two minds and no further concerning which priming treatment is good.
koolio
PostPosted: 12:17 - 18 Aug 2011    Post subject: Reply with quote
As no one seems to have any idea bcf here is some more, this is the recommendation on every single acid etch primer I've found:
Compatibility/Substrates
For use on Aluminium/Alloy, Zinc-sprayed Surfaces and Lead.
note not for bare steel surfaces and
ALUMINIUM:
Above water:: Clean and degrease with Yacht Line Super Cleaner. For better adhesion, mechanically abrade using aluminium compatible paper or low pressure grit blast using aluminium oxide.
Below water:: Clean and degrease with Yacht Line Super Cleaner. Mechanically abrade using aluminium compatible paper or low pressure grit blast using aluminium oxide.
ZINC/GALVANISED STEEL: Degrease with Yacht Line Super Cleaner.
LEAD: Rub down with an emery cloth or power wire brush. Degrease with Yacht Line Super Cleaner.
Nowhere does it say you should/can apply it to steel without a zinc coat.
Dex
PostPosted: 21:10 - 18 Aug 2011    Post subject: Reply with quote
I'm trying to remember all the highly technical stuff I was taught when learning the "Corrosion" module of my apprenticeship a million years ago....
I think we were taught you don't use Jenolite (IIRC Acid Etch Primer) on high tensile steel as it causes Hydrogen Embrittlement.
That could all be rubbish though. It was rather a dry subject, and I was drinking a lot that week.
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 60.34 Kb
