Brake Discs - Do I needs new ones?
kingnathski88
PostPosted: 11:40 - 13 Aug 2011    Post subject: Brake Discs - Do I needs new ones? Reply with quote
Hi All,
Bought a new bike today which needs doing up, has been stored for a while and neglected.
Got it back to my mates farm and whilst looking round it, we noticed the 2 front discs are covered in either brake fluid / oil?
Its very slimy, light black / clear / silverly looking liquid.
Just wandered if these are no good now? Or if we would be able to clean them up at all?
Thanks in advance for any help / advice Thumbs Up
Raffles
PostPosted: 12:11 - 13 Aug 2011    Post subject: Reply with quote
The slimy black stuff may have been deliberately applied to the discs in order to protect them from corrosion during storage. Clean the stuff off and give them a close inspection before running out and needlessly purchasing replacements. It is highly likely though that the brake pads will have been contaminated with this slime and will probably need replacing. It's also possible that oil leaking from the forks or brake fluid leaking from the calipers may have caused this.
kingnathski88
PostPosted: 12:46 - 13 Aug 2011    Post subject: Reply with quote
Many thanks.
If this is the case, would they be no good, or should I still be able to clean this off?
Nathan
MickC
PostPosted: 12:57 - 13 Aug 2011    Post subject: Reply with quote
kingnathski88 wrote:
Many thanks.
Nathan
If you mean the pads, they will be knackered, they don't like oily substances on them. They are relatively cheap and not a thing you want in a defective state. Play it safe and replace them. The disks as mentioned will just want cleaning off (I'd start with petrol then hot soapy water then rinse with clean water and dry them off .
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
kingnathski88
PostPosted: 13:33 - 13 Aug 2011    Post subject: Reply with quote
Sorry, I apologise, I was referencing to the discs, we will stick new pads in the cat, just concerned as the discs will be an expense we could do without!
We'll try giving the discs a clean tomorrow.
Thanks for your help Thumbs Up
MickC
PostPosted: 15:05 - 13 Aug 2011    Post subject: Reply with quote
Yeh your disks will be fine, you just need to clean them.
XX XXXx
kingnathski88
PostPosted: 15:43 - 13 Aug 2011    Post subject: Reply with quote
Thanks Thumbs Up that's put my mind at rest Smile
Frost
PostPosted: 15:53 - 13 Aug 2011    Post subject: Reply with quote
I usually just wipe them down, wash them then ride as normal. This moves what's left of the contaminants on to the brake pads, which at some point i usually take out and set on fire. The fact i'm still alive means this can't be totally idiotic Laughing
trisers
PostPosted: 21:34 - 13 Aug 2011    Post subject: Reply with quote
The pads are absorbent and will never clean up but the disks being steel aren't so whatever is on them can be cleaned away to leave them fresh using a suitable solvent or detergent.
PostPosted: 22:32 - 13 Aug 2011    Post subject: Reply with quote
Pretty much what brake cleaner is designed for.
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 64.8 Kb
