Filter
Jrod
Page 3 Girl
PostPosted: 12:36 - 31 Aug 2004    Post subject: Filter Reply with quote
Crying or Very sad My bike won't go over 70 from its normal 100, fuel filter is brown and crappy, How do i clean it ?
Annabella
Like a person, only smaller
PostPosted: 12:48 - 31 Aug 2004    Post subject: Reply with quote
Try buying a new one Thumbs Up
If it's not too bad just try knocking out as much dust as you can.
Avast! Pirates ahoy!
I did Cadwell! Very Happy
NickD
PostPosted: 12:51 - 31 Aug 2004    Post subject: Reply with quote
Most fuel filters can't be cleaned, just replace it. But for a loss of 30 mph, unless it was very gradual, I'd be looking elsewhere for a problem.
I was only doing what it said on my licence officer....
Tear along the dotted line!
map
Mr Calendar
PostPosted: 12:52 - 31 Aug 2004    Post subject: Reply with quote
After sorting it you'd better think about getting an in-line one as well Thumbs Up
Try checking/cleaning carbs as well - oh and try the workshop section - maybe someone else has sorted same problem.
HTH Smile
NickD
PostPosted: 12:53 - 31 Aug 2004    Post subject: Reply with quote
I'm confused now Confused are we talking about fuel or air filters?
TheShaggyDA
Repost Police
PostPosted: 12:59 - 31 Aug 2004    Post subject: Reply with quote
If it's a sudden thing (drop to 70 and fuel filter crappy) then change the filter, and get your carbs cleaned out (drain the bowls, blow out the jets).
Have you recently run out of fuel, or let the tank get way low? Or maybe the garage you get fuel from lets their tanks run low? These are great ways to get the crap at the bottom of the tank into your carbs.
Maybe the garage recently had a delivery of petrol? This stirs up all the crap at the bottom of their tanks - should wait a few days for the sediment to settle before using a garage if you see petrol being delivered.
Big Pete
PostPosted: 13:26 - 31 Aug 2004    Post subject: Reply with quote
fuel filters are generally disposal and are about £5 for an after market one.
Trust me, I`m an engineer
GarageOfPower.co.uk
Jrod
Page 3 Girl
PostPosted: 13:41 - 31 Aug 2004    Post subject: Reply with quote
Yes, I did let my fuel run onto reserve for first time in 3 years ,Thats when it all started, So i need to replace fuel filter and just see how it goes from there? £5? sounds like a plan
TheShaggyDA
Repost Police
PostPosted: 14:00 - 31 Aug 2004    Post subject: Reply with quote
So, you had 3 years of sediment build up in your tank for your carbs to suck on Smile I'd be tempted to flush the tank, too. No point in clearing the carbs and putting a new filter on if the crap is still there.
Jrod
Page 3 Girl
PostPosted: 14:35 - 31 Aug 2004    Post subject: Reply with quote
Would it of got to the carbs though, I mean the fuel filter is totally black at one end so could it of all got caught in there ?
Frost
PostPosted: 17:12 - 31 Aug 2004    Post subject: Reply with quote
It would have just clogged the filter, thats what its there for.
30mph is a serious drop off in speed however!
Change the filter and see how it runs, i expect changing the filter to help, but i wouldnt be supprised if there were other things contributing to your dropoff in speed.
if there could be ultiple causes to a problem, allways fix the cheapest one first Wink
Mister James
I want to believe!
PostPosted: 17:16 - 31 Aug 2004    Post subject: Reply with quote
Ahhh, interesting. I was recently riding to work, when I noticed too late I was almost out of petrol. Just before I pulled into the car park, the bike (ok - the scooter!) started to jerk and generally mess around. Pretty much the same thing happened on the way home, even after having filled up, although when I took it out in the evening, it improved somewhat. It's much better now, but the performance is not what it was, and there is a definite lack of power or certainty to the engine, expecially at lower speeds/gears. Would you say that I was suffering from a similar problem? And how major a job is it for a garage to sort it out?
Jrod
Page 3 Girl
PostPosted: 21:09 - 31 Aug 2004    Post subject: Reply with quote
Right its fixed Very Happy Just drained the carbs and water came pouring out, Runs sweet again Very Happy Very Happy Thanx for the help
The last post was made 22 years, 45 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 79.01 Kb
