RXS100 Carb Cleaning fail
johnsmith222
PostPosted: 18:03 - 14 Aug 2011    Post subject: RXS100 Carb Cleaning fail Reply with quote
Hi guys.
I dismantled the carb and cleaned everything, reassembing it and fitted it back to the bike.
When i kick the bike over it fires into life but goes straight for the redline instantly. Now it's definately not the throttle cable. What else could this be?
I am confident I put everything back where it should go.
Thanks for any help.
Oh yeah it's not the idle set too high. I've already tried that.
Thanks again.
Carvel
PostPosted: 18:11 - 14 Aug 2011    Post subject: Reply with quote
Have you made sure the slide is seated properly? If its sat too high it'll rev it's knackers off
johnsmith222
PostPosted: 18:24 - 14 Aug 2011    Post subject: Reply with quote
I think it's likely this is the problem. I removed the top and replaced it but it is still doing the same thing. I am going to give it another go.
MaybeGuy
PostPosted: 20:47 - 14 Aug 2011    Post subject: Reply with quote
Turn the carb slide around. On an RXS 100 it can fit one of 2 ways.
swampy
PostPosted: 21:03 - 14 Aug 2011    Post subject: Reply with quote
Airleak between carb and air intake ??
Guessing its a rubber boot on an RXS, make sure its seated properly...
Fizzer Thou
PostPosted: 21:10 - 14 Aug 2011    Post subject: Reply with quote
On the bottom of the slide should be a cutaway or wedge shaped cut out.This should face the airbox.Something like this
https://i358.photobucket.com/albums/oo25/angryshawn/ForSale/XR650R%20Part%20Out/IMG_2413.jpg
Always have a 'Plan B'
The last post was made 15 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 47.78 Kb
