Loose & Rattling Rear on CG125
Radis
PostPosted: 09:57 - 12 Aug 2011    Post subject: Loose & Rattling Rear on CG125 Reply with quote
Hi all, was riding the old CG about yesterday and noticed that there was some fairly loud rattling coming from the rear end. I had a little look and it appears that the plastics that house the rear light, behind the pillion seat are loose.
Image attached (from google) to show where.
It isn't a big deal, not causing any damage or anything but it is rather noisy.
What would you recommend to fix this? Superglue?
Thanks in advance!
Radis
PostPosted: 10:25 - 12 Aug 2011    Post subject: Reply with quote
I'm not sure if someone has sat on there as I haven't been riding that bike for a while but looking underneath the mounts appear to be intact and there are no obvious loose screws.
Behind the seat are two bits of plastic that are joined down the middle of the bike (will try and take a photo later if this needs pictures) and these don't appear to sit flush with each other any more. They have maybe 4mm play if I hold them and wiggle so I think this is what is causing the noise.
Ingah
PostPosted: 10:29 - 12 Aug 2011    Post subject: Reply with quote
I think i know what you're referring to as my own CG suffers from this.
Tape stuck down taut across the back, just above/below the "Honda", across all 3 panels, will shut it up for a while until the tape breaks.
-- Ingah
Radis
PostPosted: 10:32 - 12 Aug 2011    Post subject: Reply with quote
Will have a look when I get home and see if I can sort it with a refit. If I can't sort it with spanners then I'll tape it as suggested.
Thanks for the input guys!
Radis
PostPosted: 22:49 - 15 Aug 2011    Post subject: Reply with quote
Rob Fzs wrote:
there should be 4 bolts you can undo to take the whole unit off
then you should be able to slot the plastic together again
This fixed it - the bolts had worked very loose, I'm guessing from the vibration. I should probably put some locktight on there.
Thanks for the tip - have some karma Karma
DrDonnyBrago
PostPosted: 09:41 - 16 Aug 2011    Post subject: Reply with quote
Vapours from locktight ruin your plastics.
Just do the bolts up properly and let them be.
Radis
PostPosted: 16:49 - 16 Aug 2011    Post subject: Reply with quote
Didn't realise that locktight ruined plastics. Guess I will just have to regularly tighten the various nuts and bolts then as they all seem to rattle loose after about 1000 miles of riding.
The last post was made 14 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 60.51 Kb
