fuel tank rubber
WannaBeDude
PostPosted: 05:48 - 18 Aug 2011    Post subject: fuel tank rubber Reply with quote
Mine have fallen off, by the ignition key, to stop tank moving, any cheap DIY ideas as i'm not paying fleabay stik on prices ! Idea Karma
yen_powell
PostPosted: 08:48 - 18 Aug 2011    Post subject: Reply with quote
Do you know anyone else with the same bike?
XT1200Z and a DR350 in bits
PostPosted: 10:17 - 18 Aug 2011    Post subject: Reply with quote
gaffer tape, round tank and under frame, keep wrapping till its all done. Laughing
DrDonnyBrago
PostPosted: 10:26 - 18 Aug 2011    Post subject: Re: fuel tank rubber Reply with quote
What do they look like?
Rubber tubes that go around a bolt or bits of rubber that are glued on and stop things rubbing on metal?
You could probably fashion either out of a block of rubber, something like EPDM would do it however it will probably look a bit shit.
Simplest is to just cough up and buy some.
hazza
PostPosted: 10:38 - 18 Aug 2011    Post subject: Reply with quote
the ones on my bandit have been replaced with the sole of a plimsole shoe and secured with its laces.
Raffles
PostPosted: 11:51 - 18 Aug 2011    Post subject: Reply with quote
Foam type pipe insulation secured with tie-wraps also works well in such situations.
WannaBeDude
PostPosted: 14:20 - 18 Aug 2011    Post subject: Reply with quote
Will buy some rubber, what glue is best for rubber to metal frame ? Karma so they don't fall off like last pair ! Rolling Eyes
Bezzer
PostPosted: 16:16 - 18 Aug 2011    Post subject: Reply with quote
I'd try silicone gasket first, test it when you get your rubber to see if it sticks to it well enough for what you want, it'll stick fine to the frame just don't know how good to the actual rubber part. Other than that you're looking at an epoxy glue- proper araldite (not the quick stuff) or whatever. But try silicone first that won't cause any damage to the surfaces.
Germ
PostPosted: 17:02 - 18 Aug 2011    Post subject: Reply with quote
try Copydex carpet adhesive.It's a latex glue I think and sticks good and easy to remove when you need to.Should stick metal to plastic no bother and as it's latex it's a bit stretchy rather than brittle like a lot of glues.
Ariel Badger
PostPosted: 19:38 - 18 Aug 2011    Post subject: Reply with quote
Rubber ends for walking sticks work on Ariels.
Fizzer Thou
PostPosted: 19:59 - 18 Aug 2011    Post subject: Reply with quote
I've used door stop rubbers in the past.
Always have a 'Plan B'
WannaBeDude
PostPosted: 02:40 - 19 Aug 2011    Post subject: Reply with quote
Thanks all for many ideas and suggestions, gonna go to a popular hardware place, a local independent store, some rubber and araldite slow acting sounds good, as can use the glue in future on allsorts.
Not fucking paying 11 quid for them on fleabay Shocked Karma
WannaBeDude
PostPosted: 21:58 - 24 Aug 2011    Post subject: Reply with quote
Hardware store delivered as it were for 65 p and fleabay araldite 3.50 del .. WIN Smile
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 75.27 Kb
