| devojunior |
 devojunior Brolly Dolly
| mjn51 |
 mjn51 Traffic Copper
| Marmalade |
 Marmalade World Chat Champion
 Posted: 09:22 - 17 Aug 2011 Post subject: |
Has he disturbed wiring, maybe blocked a breather or trapped an airway. pull off and refit breathers that may have split when disturbed, wires that may have come disconnected etc.
Possibly head gasket. Made more likely by having overheated.
Water will often fly out of an open filler cap as it can boil when not under pressure. With cap on the water has a higher boiling point due to the pressure.
Refill it, run it and see if the hoses get really hard, caused by cylinder compression leaking into the waterways.
If so you could get a gas test done but it is pretty much a done deal by then if pipes are pressurising and losing water etc.
Also check oil to see if there is any water or creaming, especially at the cap and in breather pipes ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky
| devojunior |
| mr jamez |
 mr jamez World Chat Champion
| volvodai |
 volvodai Two Stroke Sniffer
| dextersaurus |
 dextersaurus World Chat Champion
 Posted: 20:52 - 17 Aug 2011 Post subject: |
The TT600 has 4 connections on the bottom of the tank.
One red clip
One silver clip
These are your fuel hoses.
Then 2 black rubber ones at the back.
These are your overflow tubes.
the one attached to the overflow tank for the rad should NOT be attached to the fuel tank. that's your problem. looks like what he's done is attach it from the rad straight to the fuel tank. tell him this should attach to the expansion tank.
Second, the TT600 doesn't pull from under 4k revs. he's riding it wrong.
Is the ECU light on? the little orange one above the oil light?
If so, tell him to buy the cable off amazon.
https://www.amazon.co.uk/OBD2-OBD-II-Cable-409-1-Skoda/dp/B001C1MNTM/ref=sr_1_1?ie=UTF8&qid=1313613963&sr=8-1
with that, you can download 'tuneECU' which is basically what the garage uses to change fuel maps and the like.
It'll also tell him any problems the bikes having. it's how i diagnosed the misfire on mine.
And btw, my TT ran at near enough 100 degrees all the time.
HTH
Dunc |
| devojunior |
| dextersaurus |
| devojunior |
| devojunior |
 Posted: 13:22 - 18 Aug 2011 Post subject: |
mr dunkable .
whilst your not busy lol which one of these four is it he needs to download if it is any of them that is ?
https://www.box.net/shared/pusg6v7nyd |
The last post was made 14 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
