spray grease up an exhaust
fredsredhat
PostPosted: 15:22 - 20 Aug 2011    Post subject: spray grease up an exhaust Reply with quote
a neighbour of my mother in laws keeps parking across her drive, we've tried speaking to him politely, tried telling him straight but he still keeps parking there. I've got some spray grease, if i shove a load of this up the exhaust will it do any permanent damage? hopefully, if im right then it'll smoke like billy-o when he gets a mile away and the exhaust warms up. i dont want to do any real damage, just piss him off a bit like he pisses us off. any other ideas for childish revenge?
PostPosted: 15:29 - 20 Aug 2011    Post subject: Reply with quote
Shouldn't do any harm. A nice big printed sign spray-glued to his windscreen would get the point across.
PostPosted: 15:38 - 20 Aug 2011    Post subject: Reply with quote
Park across their drive......
Frost
PostPosted: 17:44 - 20 Aug 2011    Post subject: Reply with quote
Spray grease will get heated up and blow out the end of the exhaust, that's all.
Expanding foam on the other hand will require a new back box to remove.
A fist full on nails on the ground might convince him that parking there isn't a great idea.
Some 40 grit wet & dry rubbed firmly on at eye level on the drivers side of the wind screen should piss someone off a great deal.
Brake fluid isn't kind to paint work and can be used to write any number of swear words.
Chunks of spark plug ceramic go through windows very easily and quietly.
2-4 good sized lads can pick up the back end of a car and wheel it to somewhere else. If they wanted to they could also roll it onto it's roof.
PostPosted: 18:47 - 20 Aug 2011    Post subject: Reply with quote
Anything you do will invite retaliation. Confront him yourself, resolutely, or find someone who will.
The999Kid
PostPosted: 18:58 - 20 Aug 2011    Post subject: Reply with quote
smear lard/butter/animal shit under the door handles?
Frost
PostPosted: 19:22 - 20 Aug 2011    Post subject: Reply with quote
Superglueing razor blades there would work, as would putting tiny stones into the lock Laughing
The only plan i'd really advise is getting some lads round to pick the back end up and wheel it somewhere. The car will then not be in your way, they will get the message that this will be a recurring event if they keep parking there. It also shows them that you know enough decent sized lads to make their life problematic if they piss you off Wink
DrDonnyBrago
PostPosted: 19:29 - 20 Aug 2011    Post subject: Reply with quote
Park 1 inch away from each of his bumpers.
kerr
i always thought you could get somone towed if they park across your drive.
aprilia 125 Af1 Futura >> Suzuki gsxr 600 srad >> J1 zx6r >> cbr 600rr >> Speed Triple
garth
PostPosted: 19:41 - 20 Aug 2011    Post subject: Reply with quote
Arm yourself with a screwdriver.
Take out all his lightbulbs.
Swap the numberplates.
Take the rubbers out his windscreen wipers.
Sew cress seeds in all the gaps in the bodywork.
Tape porn to the passenger side.
Spray "I'm a CUNT" in glow in the dark paint on his drivers door.
Livefast123
PostPosted: 19:45 - 20 Aug 2011    Post subject: Reply with quote
Does the drive have a dropped kerb, if so park your car on the drive so he blocks you in. Then call the plod and say that he is obstructing your drive and you need to get to a importent meeting / birthday / wife's in labour etc.
They then send the friendly local community plastic PCSO who get the car removed.....he'll have a nice £200 cost to get the car back and i think he'll get the point.
It doesn't work if you want to pull into your drive though, it's only an offence to block a vehicle in.
Then tell him if he does it again then the outcome will be the same. If she doesn't drive buy a banger for £50 on the bay and leave it on the drive.
Current ride - Yamaha MT-07
Redoko
PostPosted: 19:51 - 20 Aug 2011    Post subject: Reply with quote
Need a paint diagram.
Do you mean at the end of it, or at the end of it on the opposite side of the road?
herulach
PostPosted: 20:28 - 20 Aug 2011    Post subject: Reply with quote
This, if its your side of the road, get it towed, if its the otherside chill out and learn to park better (or learn to park worse and get a towbar installed.
YBR 125>FZS600
temeluchus
PostPosted: 02:43 - 21 Aug 2011    Post subject: Reply with quote
https://www.surplusstore.co.uk/catalog/product_info.php/products_id/333
these, sequestered in various nooks and crannies of the exhaust would be fun.
Martay
PostPosted: 02:44 - 21 Aug 2011    Post subject: Reply with quote
Heard a simmilar and awesome one a while back. Dog shite under the handles with drawing pins pressed into it.
Grabs handle
Stabs fingers
Sticks fingers in mouth
...poo
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
TUG
PostPosted: 03:55 - 21 Aug 2011    Post subject: Reply with quote
Dump battery acid over car. Jack up car move to the main road (double yellows) after letting down all tyres. Piss on radiator. Scottoiler chain lube up the exhaust. block in car with you're care and someone elses. so on and so on the more awkward you make it for them the more likely they are to stop.
Haz ER-5, innit!
hmmmnz
PostPosted: 07:01 - 21 Aug 2011    Post subject: Reply with quote
just about all the sugestions invite problems to you or your mum in law,
you had it pretty close with the spray grease, but the exhaust box doesnt get hot enough,
on the other hand a big blob of normal grease up near the headers, works wonders, and it smokes for ages, nice black smoke Very Happy
it requires sliding under his car though,
the humans are dead
I kick arse for the lord
pepperami
PostPosted: 17:15 - 22 Aug 2011    Post subject: Reply with quote
? will you lot stop titing about with all this girly stuff.
OP ask him nicely once not to park there, then tell him nicely not to park there, if it continues, hit him very very hard with a length of bar and set his car on fire, job done!
any come backs, kill his entire family very slowly.
alledgedly!
bombom
PostPosted: 20:46 - 22 Aug 2011    Post subject: Reply with quote
Try and spray some up front on the manifold, itl stink like crazy haha
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
Handsome
PostPosted: 21:12 - 22 Aug 2011    Post subject: Reply with quote
Politely let him know that whilst he is free to park on the road and yes he has payed his road tax he didn't pay for your dropped gutter, so would he kindly remove his car and stop blocking said driveway as he'll soon moan if his car is clipped whilst cars are being put on and taken off the drive, say it in a firm voice and keep eye contact, say the above and shut up, say nothing else, just stare at him...
The above also helps if you know someone with a recovery truck Wink ...
Frost
PostPosted: 21:14 - 22 Aug 2011    Post subject: Reply with quote
Do him in the Gary!
oops, wrong thread.
fredsredhat
PostPosted: 22:52 - 22 Aug 2011    Post subject: Reply with quote
thanks for the replies, i dont want to cause any damage at all. i've asked him, told him, threatened him but it just wont sink in. like i said she doesnt drive so there's no car but there is our caravan which he blocks in so im not sure ringing the authorities is really necessary. i certainly dont want any comebacks and im not al that bothered if he doesnt know its from us, i just want to ruin his day basically Karma
potato
PostPosted: 23:07 - 22 Aug 2011    Post subject: Reply with quote
He obviously thinks your a pussie then Wink
Don't have that Laughing
OOOooosshh!
t121anf
PostPosted: 23:42 - 22 Aug 2011    Post subject: Reply with quote
even if there was a car on the drive no laws are broken by blocking it, found this out researching a problem neighbour at my parents in law, some police site down south said they wouldn't be interested if the car is legal
PostPosted: 01:00 - 23 Aug 2011    Post subject: Reply with quote
fredsredhat wrote:
threatened him
I doubt it.
The last post was made 14 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 126.91 Kb
