OEM tyres
Werny
PostPosted: 11:53 - 21 Aug 2011    Post subject: OEM tyres Reply with quote
Just a quick question, as I'm slightly curious about this.
I bought my xj6 new last year with Dunlop Sportmax Roadsmart tyres fitted. I quite liked them, so when it came time to replace the rear, about 5k miles, I fitted another roadsmart.
Since then I've noticed a distinct band appear on the center of the tyre where the harder compound is, it's really obvious just glancing at it. However I cannot remember seeing the same banding on the original tyre, same type/make/spec/whatever tyre. I was also somewhat suprised at having to get a new tyre at 5k miles, this is an xj6 with bugger all bhp, I kind of expected a bit more life.
Now seeing this strip made me wonder if there is any possibility the OEM tyres are in any way inferior to the exact same tyres bought as replacements. Do Dunlop maybe supply single compound sportmax tyres to Yamaha? Or should I just put away my tinfoil hat?
If it helps the front tyre is still the original and showing no sign of banding, although it does really need to be replaced now at 8k or so.
neatbik
PostPosted: 12:16 - 21 Aug 2011    Post subject: Reply with quote
Quite often oem tyres are inferior to the ones you buy from a dealer/tyre place to replace them with.
The manufacturer gets them at a cheaper price. Its not something they shout about, but it does happen.
Dunlop are buggers for doing this, as are Bridgestone (they did it with the BT016, but cant remember which bikes they were fitted oem)
Mileage wise though 5k doesent sound too bad to be honest, but as usual it all comes down to how much stick you give them.
I'd just assume it's because the tyre is now being made by a new lowest bidder in whichever humid hell hole has the cheapest access to rubber and child labour.
garth
PostPosted: 13:48 - 21 Aug 2011    Post subject: Reply with quote
5k is low for a roadsmart, though.
chillyman0
PostPosted: 14:07 - 21 Aug 2011    Post subject: Reply with quote
got a rear roadsmart on my vfr, approching 9k miles including 2k touring fully loaded 2 up! Must be a couple of mm left too
1996 gsf600n (sold)
Nick 50
PostPosted: 14:42 - 21 Aug 2011    Post subject: Reply with quote
I know you said it was new, but have you checked the wheel alignment is ok?
Werny
PostPosted: 15:17 - 21 Aug 2011    Post subject: Reply with quote
Thanks for the replies, guys!
Somehow, that doesn't suprise me Sad
beatnck2 wrote:
...it all comes down to how much stick you give them.
I do like to ride a bit spiritedly, but it's a low power pissy commuter, not a sports bike.
I had thought it may be a bit low milage, glad for some kind of confirmation Very Happy
I've not checked alignment, but it has had 2 dealer services and nothing was said about that. I know that's no guarantee, however!
Thanks again for the replies Mr. Green
Rowey
PostPosted: 15:20 - 21 Aug 2011    Post subject: Reply with quote
Often OEM tyres are different to the tyres you buy from the shops. I found with a pair of oem 014's they were much harder wearing, stiffer, offered less feedback, grip and warmed up slower than the replacement 014's I had fitted from a shop.
Even though the name was the same the compound used was noticeably different.
Is your rear shock set a little too stiff? And despite your bike not being a hugely powerful beast, I've found with lower BHP bikes I'm often pinning the throttle a lot more than on bigger bikes where I'm smoother.
ZX6R C6F.
chillyman0
PostPosted: 15:27 - 21 Aug 2011    Post subject: Reply with quote
A bit confused as to what you mean actually...
Do you get a visible strip or a strip that has worn abnormally as with my rear sometimes in the damp i can get home from an easy ride and there is a distinct strip of lighter colour rubber in the centre. doesnt usually mean it is wearing abnormally...
1996 gsf600n (sold)
Werny
PostPosted: 15:41 - 21 Aug 2011    Post subject: Reply with quote
There's a distinct strip of lighter rubber in the center of the tyre, I'm not worried about it as I know it's just the different compound. The only reason I mentioned it was that I didn't notice this colour difference on the old tyre.
There is no abnormal wear, in fact 3k miles after fitting it still looks mostly new Mr. Green
My shock has not been adjusted since I bought it, I don't know what I'm doing with suspension, or anything really, so I leave it well alone. I am a right skinny bastard, so if it's set to suit a normal 12-13 stone bloke then for me at 10 stone it will obviously be wrong.
chillyman0
PostPosted: 15:58 - 21 Aug 2011    Post subject: Reply with quote
yeah I get the colour strip, dont worry about it Thumbs Up
1996 gsf600n (sold)
The Spin Doctor
PostPosted: 10:26 - 29 Sep 2011    Post subject: Reply with quote
First post here so hi to everyone...
Sorry to be along a bit late on the topic, but I just happened to spot the OP on a google search.
My XJ6 Divvie also came with Roadsmarts, and the rear on mine (with very little m'way use incidentally) was squared off and totally finished at 4500 miles.
Interesting point about spotting the lighter band on the replacement Roadsmart, because I used to run the twin compound Bridgestone BT45s on our training school bikes and they would visibly show up the dual compound.
There was certainly no such banding on the OE Roadsmart, so I'm wondering if the speculation is indeed correct, and the OE fitment ISN'T dual compound.
It would certainly explain why it wore out so fast and squared so badly! It also makes for a total mismatch wear-wise with the front - mine's just hit 10k and it's still got about 2mm on it - I'm just about to replace it with a new Conti for the winter.
If that's the case that Dunlop saves a few pennies by fitting a single soft-compound tyre that wears out quickly, it's a bit daft as the result of fast wear is that most riders seem to fit something else when the time comes to change the tyre, costing them business in the long run.
"Force has no place where there is need of skill" Herodotus 450BC
DrDonnyBrago
PostPosted: 11:03 - 29 Sep 2011    Post subject: Reply with quote
Have you finally left visordown Spin?
Welcome to the forum, hope you stick around Thumbs Up Thumbs Up .
The Spin Doctor
PostPosted: 12:12 - 29 Sep 2011    Post subject: Reply with quote
Thank you Smile I wondered if I'd bump in to a few familiar faces Wink
Sadly VD's dead in the water... amazing what a few ill-judged marketing "opportunities" can do to a once thriving community. Rolling Eyes
I'm still technically a mod of the 'Survival Skills' section (I think they forgot about me when they turned off the old mod crew's powers Wink ) but about the only post in the last month was to a three year old thread having a rant about people trying to get their knee down Very Happy
I'll no doubt poke around the various sections!
One thing you might be able to help with... where's the SUBMIT button? I can see a preview button, and if I click that I get a SUBMIT button appear, but I can't see one on the editing window that avoids having to go to the preview first. Am I missing something?
truslack
PostPosted: 12:22 - 29 Sep 2011    Post subject: Reply with quote
It will appear after you've made a few posts, it's just to get people used to writing in proper English!
DrDonnyBrago
PostPosted: 12:27 - 29 Sep 2011    Post subject: Reply with quote
I left VD a while back, the forum was on it's knees then and is pretty much 6ft under now Surprised .
There is a Karma system on BCF that makes the forum pretty much self moderating - basically if you help people out, post good info, avoid swearing and crap spelling etc etc you get positive karma (see the little Thumbs Up Thumbs Down in the corner of other people's posts - here you rate other people's posts/thank them for advice etc), when you have a bit more positive karma you won't need to preview your posts and can just click submit.
Negative karma is used when people are abusive, post crap information or spam, enough negative karma gets them banned.
If you are interested:
https://www.bikechatforums.com/viewtopic.php?t=21812
Enjoy the forum Thumbs Up .
The Spin Doctor
PostPosted: 14:06 - 29 Sep 2011    Post subject: Reply with quote
OK, got it... thanks folks.
It was probably in the Posting Guidelines which I did skim through!
All is now clear!
PostPosted: 14:14 - 29 Sep 2011    Post subject: Reply with quote
the bridgestones they fit to busas as oem are utter crap
PostPosted: 14:15 - 29 Sep 2011    Post subject: Reply with quote
A bit of a late reply, but I believe you're thinking of the CBR600RR. Thumbs Up
The last post was made 15 years, 9 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 106.7 Kb
