RD 350 F2 YPVS Help (now with video)
PostPosted: 15:32 - 22 Aug 2011    Post subject: RD 350 F2 YPVS Help (now with video) Reply with quote
Hello,
I recently dug my RD out of the back of the garage and got it MOT'd. I'd recently rebuilt the forks, and the front end feels great. However, the engine seems to be running like crap. When I took it for an MOT they almost failed it on the fact that the indicators stopped working when the headlights were switched on. This was discovered to be a battery problem, so I replaced the battery with a tarty AGM battery. Since replacing the battery the running problem is a bit better... but not fixed. It stuttered around 5000rpm and then would bog down when warm. I assumed the problem was to do with the total lack of electrical power and the fact that the YPVS servo is electric. The powervalve noise is louder and higher pitched now after replacing the battery, and all the lights and electrics work perfectly. There obviously was an issue with the battery, but now that is sorted. But it still doesn't run right!
So, back to the drawing board, I took a look at the plugs. They were sooty, but not too bad. However, I found that the left hand plug cap was loose and no longer clicked onto the plug. So I replaced the plugs and the plug caps, and again the problem is a *little* better, but not perfect.
Now it seems to stutter around 7000rpm, and then when hot it bogs down over those revs. I'd guess it was fuel starvation, but it only does it after the engine has been up to temperature for five minutes or so. Up until then it seems to run perfectly.
Anybody got any ideas what I can check? The bike has been sat for a while, so I might need to clean out the carbs, but I don't really want to do that if I can help it because removing the carbs on this bike is a real pig of a job. Well, removing them isn't difficult, but re-fitting them is! I've also tried running the bike with the fuel tap on prime which doesn't seem to help either.
Help!
PostPosted: 15:42 - 22 Aug 2011    Post subject: Reply with quote
Its more than likely a "clean the carb, it'll sort it" job.
If it runs like a bag of spuds when warm i'd assume its sort of like my bike when I leave choke on...it just bogs and wants to run like chuff.
PostPosted: 16:00 - 22 Aug 2011    Post subject: Reply with quote
BLUEX5 wrote:
If your confident in sparks and ypvs operation then i'm afraids its carb time. Especially the needle jet / pilot circuit. Being stood the carbs are no.1 suspect.
[/i]
Yeah you're probably right. You're only really telling me what I already know but its reassuring to hear it from someone else. Tomorrow will be spent stripping down the carbs. Again! Smile
Frost
PostPosted: 16:07 - 22 Aug 2011    Post subject: Re: RD 350 F2 YPVS Help Reply with quote
MarJay wrote:
Hello,
I got as far as this before giving up in disgust. What happened to you? You used to be alright.
Suntan Sid
PostPosted: 19:23 - 22 Aug 2011    Post subject: Reply with quote
Have you checked out the charging system, coils, Reg/Rec etc.
Seem to have jumped from an electrical problem straight to cleaning the carbs.
How is your new battery now, is it still fully charged?
MaybeGuy
PostPosted: 21:04 - 22 Aug 2011    Post subject: Reply with quote
If it's stuttering at certain revs and fine elsewhere, it's most likely the powervalve set wrong. Especially if it sounds different.
PostPosted: 21:36 - 22 Aug 2011    Post subject: Reply with quote
Don't think so, the powervalve turns and there is a flat spot at 5-6000 rpm where it opens at the wrong time, but this is most definitely a flat spot, and not a stuttering or misfire.
PostPosted: 21:37 - 22 Aug 2011    Post subject: Re: RD 350 F2 YPVS Help Reply with quote
Frost wrote:
MarJay wrote:
Hello,
Well, I spent last December stripping the forks on the RD, then all my tools got nicked, then I bought an FZR400 which I had to get ready for a trackday, and then the MOT ran out. I'm purely a victim of circumstance, honest!
PostPosted: 21:35 - 24 Aug 2011    Post subject: Reply with quote
Update:
I cleaned out the carbs today, and I also replaced the knackered fusebox which was held together with wire, and had a household 10A fuse instead of a 15A automotive fuse.
The carbs did have a bit of rust in the float bowls, but I've seen much worse. There did look to be some muck in the main jets, but it came out very easily, and I'm thinking that petrol probably should have got it out...
Anyway, I've not ridden the bike yet since having the carbs off but it still seems to run like a bag of spanners in my quick test... however Ididn't have a chance to fully warm it up, and it did seem to start very easily and idled properly from cold which was a bit of a surprise.
Hopefully if the weather is OK tomorrow I'll find out if I've managed to fix it. If not I suspect the next port of call is to try a different ignition coil. I really really really hope its not a fcuked CDI unit, but then I suppose it would give me an excuse to go for a Zeeltronic...
PostPosted: 22:22 - 24 Aug 2011    Post subject: Reply with quote
BLUEX5 wrote:
I've never known a CDI go down on an F2, but I've known a stator plate burn out. Annoying because the only way to really eliminate things is by swopping them for known good ones. Easy when your mate owns a bike shop full of dead LC's and YPVS's (which was a privilidge I once had), but a PITA otherwise. Not teaching my granny but did you check the emulsion tubes and associated feeds were hygenically clean?
Yep, cleaned all of the brass parts with carb cleaner, and blew compressed air through...
The bike runs fine at high revs so I don't think its a stator problem or a CDI problem, but the HT lead connections to the coil aren't great, only one of the four retaining clips is still in place. Now held in place with carefully looped cable ties. A new coil and a new set of HT leads probably wouldn't go amiss anyway though.
However, the fact that the bike runs at high revs, but not very well between 6-8000 rpm leads me to think that its a main jet problem because the power jets take over at very high revs...
It still could be an ignition problem though, and the pain with those is that they are expensive it seems
{edit} It doesn't pop and bang though, which implies fuelling rather than intermittent ignition... And the fuel tap is knackered, the bike dies unless you run it on prime, I was wrong about that!{edit}
Old Git Racing
PostPosted: 22:31 - 24 Aug 2011    Post subject: Reply with quote
YPVS servo motor can go down if you run it without or with a duff battery. Check its working right, watch the cables or take the end cap off and observe as the revs go up, sounds about the revs when its going from closed to open.
OGR
PostPosted: 22:33 - 24 Aug 2011    Post subject: Reply with quote
OGR
Done this, its fine. Definitely not a YPVS problem.
Frost
PostPosted: 22:37 - 24 Aug 2011    Post subject: Re: RD 350 F2 YPVS Help Reply with quote
MarJay wrote:
Blah Blah Blah Excuses etc
Listen i was talking to your bike last night and well... things aren't good right now. Basically it's in a bad way emotionally. Yeah it's got a few physical issues but the two are very much linked... in short it's just not getting the love and attention it needs... they're a high maintenance breed after all. Anyway we discussed it and agreed it would be best if it came to stay we me, at least for a little while.
PostPosted: 22:44 - 24 Aug 2011    Post subject: Re: RD 350 F2 YPVS Help Reply with quote
Thats fine, but I'll need you to pay for the therapy bill from the noted rebuildologist Mr Stan Stephens, and the accessories bill for the cartridge emulators in the forks... Wink
Frost
PostPosted: 23:23 - 24 Aug 2011    Post subject: Reply with quote
That'll be fine. I suggest we make the exchange on neutral ground. I'll bring the bike back next week.
What? I don't know where you live? doesn't mat... erm... email me the address. Yes. do that.
PostPosted: 19:22 - 25 Aug 2011    Post subject: Reply with quote
Hmm. Apologies perhaps to OGR, it could be a YPVS problem. I videoed the powervalve pulley when revving the engine and it makes a good attempt at doing its job, but it jumps about as if it's under electrical interference from the engine running. When the engine is off the YPVS cycles fine. When it's running it jumps back and forth in a random way. I think the YPVS motor itself is fine but perhaps the coil is on it's way out and is giving off electrical interference, or the CDI unit is borked. Any thoughts would be appreciated! Oh yeah and I tried running the bike with the YPVS servo disconnected and it was rideable. Not perfect but certainly night and day better than with it connected. The tacho doesn't seem to know what it's doing though and does also jump about randomly sometimes.
Hmm. I vaguely remember reading somewhere that a jumping tacho signifies a borked CDI unit... But I might have imagined it.
philoldsmobil...
PostPosted: 20:25 - 25 Aug 2011    Post subject: Reply with quote
is it charging?
PostPosted: 09:34 - 26 Aug 2011    Post subject: Reply with quote
philoldsmobile wrote:
is it charging?
Yep, sure is.
PostPosted: 10:32 - 26 Aug 2011    Post subject: Reply with quote
This is what the YPVS does when the engine is running:
https://www.youtube.com/watch?v=dq33cKIksSg
This is the servo cycling normally on startup:
https://www.youtube.com/watch?v=R4QRvI1xFtA
and this is the servo when the engine is running:
https://www.youtube.com/watch?v=Xtkdxh1Mw6Q
PostPosted: 10:49 - 26 Aug 2011    Post subject: Reply with quote
Dodgy electrical connection somewhere. Check the loom plugs and CDI block connector.
PostPosted: 22:29 - 26 Aug 2011    Post subject: Reply with quote
I'm told that the powervalve and the tacho are on the same circuit, so the two acting weird could be the same thing. I've got to check the earth from the black wire on the tacho and perhaps run another earth to a point on the frame.
Suntan Sid
PostPosted: 21:56 - 27 Aug 2011    Post subject: Reply with quote
I had a 350 YPVS from new, (the only new bike I've ever owned), and I can assure you that the the power valve jumped around like that from day one, never had any running issues with it! In fact mine jumped around a lot more than that!
The last post was made 15 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 140.79 Kb
