| MarJay |
 MarJay But it's British!
 Posted: 15:32 - 22 Aug 2011 Post subject: RD 350 F2 YPVS Help (now with video) |
Hello,
I recently dug my RD out of the back of the garage and got it MOT'd. I'd recently rebuilt the forks, and the front end feels great. However, the engine seems to be running like crap. When I took it for an MOT they almost failed it on the fact that the indicators stopped working when the headlights were switched on. This was discovered to be a battery problem, so I replaced the battery with a tarty AGM battery. Since replacing the battery the running problem is a bit better... but not fixed. It stuttered around 5000rpm and then would bog down when warm. I assumed the problem was to do with the total lack of electrical power and the fact that the YPVS servo is electric. The powervalve noise is louder and higher pitched now after replacing the battery, and all the lights and electrics work perfectly. There obviously was an issue with the battery, but now that is sorted. But it still doesn't run right!
So, back to the drawing board, I took a look at the plugs. They were sooty, but not too bad. However, I found that the left hand plug cap was loose and no longer clicked onto the plug. So I replaced the plugs and the plug caps, and again the problem is a *little* better, but not perfect.
Now it seems to stutter around 7000rpm, and then when hot it bogs down over those revs. I'd guess it was fuel starvation, but it only does it after the engine has been up to temperature for five minutes or so. Up until then it seems to run perfectly.
Anybody got any ideas what I can check? The bike has been sat for a while, so I might need to clean out the carbs, but I don't really want to do that if I can help it because removing the carbs on this bike is a real pig of a job. Well, removing them isn't difficult, but re-fitting them is! I've also tried running the bike with the fuel tap on prime which doesn't seem to help either.
Help! ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| P.addy |
 P.addy Red Rocket
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Frost |
 Frost World Chat Champion
| Suntan Sid |
 Posted: 19:23 - 22 Aug 2011 Post subject: |
Have you checked out the charging system, coils, Reg/Rec etc.
Seem to have jumped from an electrical problem straight to cleaning the carbs.
How is your new battery now, is it still fully charged? ____________________ "Everybody needs money, that's why they call it money!"  |
| Blau Zedong |
 Blau Zedong Banned
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:04 - 22 Aug 2011 Post subject: |
If it's stuttering at certain revs and fine elsewhere, it's most likely the powervalve set wrong. Especially if it sounds different. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| MarJay |
| MarJay |
| MarJay |
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
 Posted: 22:22 - 24 Aug 2011 Post subject: |
| BLUEX5 wrote: | I've never known a CDI go down on an F2, but I've known a stator plate burn out. Annoying because the only way to really eliminate things is by swopping them for known good ones. Easy when your mate owns a bike shop full of dead LC's and YPVS's (which was a privilidge I once had), but a PITA otherwise. Not teaching my granny but did you check the emulsion tubes and associated feeds were hygenically clean? |
Yep, cleaned all of the brass parts with carb cleaner, and blew compressed air through...
The bike runs fine at high revs so I don't think its a stator problem or a CDI problem, but the HT lead connections to the coil aren't great, only one of the four retaining clips is still in place. Now held in place with carefully looped cable ties. A new coil and a new set of HT leads probably wouldn't go amiss anyway though.
However, the fact that the bike runs at high revs, but not very well between 6-8000 rpm leads me to think that its a main jet problem because the power jets take over at very high revs...
It still could be an ignition problem though, and the pain with those is that they are expensive it seems
{edit} It doesn't pop and bang though, which implies fuelling rather than intermittent ignition... And the fuel tap is knackered, the bike dies unless you run it on prime, I was wrong about that!{edit} ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| Old Git Racing |
 Old Git Racing World Chat Champion
| MarJay |
| Frost |
| MarJay |
| Frost |
| MarJay |
| philoldsmobil... |
 philoldsmobil... Renault 5 Driver
| MarJay |
| MarJay |
 Posted: 10:49 - 26 Aug 2011 Post subject: |
Dodgy electrical connection somewhere. Check the loom plugs and CDI block connector. ____________________ a.k.a 'Geri'
| MarJay |
| Suntan Sid |
 Posted: 21:56 - 27 Aug 2011 Post subject: |
I had a 350 YPVS from new, (the only new bike I've ever owned), and I can assure you that the the power valve jumped around like that from day one, never had any running issues with it! In fact mine jumped around a lot more than that! ____________________ "Everybody needs money, that's why they call it money!"  |
The last post was made 15 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
