1995 RS125 Tempreature Gauge Fluctuates
SUPERSTAR101
PostPosted: 19:20 - 22 Aug 2011    Post subject: 1995 RS125 Tempreature Gauge Fluctuates Reply with quote
Aprilia RS125 " 1995 "
Tempreature Gauge Fluctuates between COLD and HOT
but the bike doesent over heat and runs really well
just wondering what advice you all have ?
could it be thermostat or the sensor in the head ?
Thanks
matt
Frost
PostPosted: 21:13 - 22 Aug 2011    Post subject: Reply with quote
How quickly does it change?
I doubt the termostat is responsible as it only opens and closes slowly. It's either a dodgy connection, our you have air in the system.
PostPosted: 21:29 - 22 Aug 2011    Post subject: Reply with quote
Sensor or wire between it and the temp gauge would be my guess as well.
0l0dom0l0
PostPosted: 22:21 - 22 Aug 2011    Post subject: Reply with quote
As above sounds like a damaged wire.
Unless it's over a very long period in which case it could be the engine.
ie, cooler at high speeds and hot a low speeds.
SUPERSTAR101
PostPosted: 06:34 - 23 Aug 2011    Post subject: Reply with quote
Thanks anyone know wear the sensor is ? thanks very much matt
PostPosted: 08:34 - 23 Aug 2011    Post subject: Reply with quote
Towards the back of the cylinder head cover.
SUPERSTAR101
PostPosted: 12:46 - 23 Aug 2011    Post subject: Reply with quote
Thanks how would i get to the head i have no idea as im new to aprilia rs125's thanks very much mighty BCF
PostPosted: 12:50 - 23 Aug 2011    Post subject: Reply with quote
Take the seat off. Undo the bolt at the front of the petrol tank. Lift the tank up (it is hinged at the back under the front of the seat).
Look under the tank and you will see the engine. Right at the top is the spark plug cap. Look about 1~2 inches back from that and you should find the temp sensor. My guess would be the wire is loose, possibly ground out on the engine itself or the frame.
PostPosted: 12:51 - 23 Aug 2011    Post subject: Reply with quote
You should be able to see a bolt at the top of the tank near the front. Allen key on my one.
You simply unbolt that and flip the tank up, might need to take the front seat off though!
Edit - Damn Keith..
SUPERSTAR101
PostPosted: 12:56 - 23 Aug 2011    Post subject: Reply with quote
Thanks for your adivce keith Very Happy
will let you know how i get on
OUT !
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 63.12 Kb
