| alf wayliner |
 alf wayliner L Plate Warrior
| Pete. |
 Pete. Super Spammer
 Posted: 11:50 - 23 Aug 2011 Post subject: |
All you can do is remove the bearings and take a trip to the bearing factors. Standard ball bearings are not suitable, you need proper headrace bearings either taper roller or ball type. ____________________ a.k.a 'Geri'
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 12:10 - 23 Aug 2011 Post subject: |
if i remember rightly, they dont have a tapered head race, but inner and outer races with ball bearings
you might get away witha roller bottom 30X55X17 and top 25X47X15
your best bet is to see if you can pck the existing ones with a pant load of grease and then tighten it back up, or pull them out and see if my measurements are right and get some from your local bearing guy,
don't talke my measurements as gospel!!!! ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Pete. |
 Pete. Super Spammer
 Posted: 12:20 - 23 Aug 2011 Post subject: |
Tapered race are usually replacement. You could use regular bearings, if you could find them in angular contact format, which are designed for axial loads. ____________________ a.k.a 'Geri'
| Pete. |
 Pete. Super Spammer
 Posted: 12:24 - 23 Aug 2011 Post subject: |
| alf wayliner |
| Pete. |
 Pete. Super Spammer
 Posted: 12:30 - 23 Aug 2011 Post subject: |
I'm going by the sizes hmmnz posted but what you could do is remove the ones you have, measure the stem, headstock and thickness for each and put the sizes into google. ____________________ a.k.a 'Geri'
| alf wayliner |
The last post was made 14 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
