Brake light - only works with lots of force
_Troy_
PostPosted: 20:14 - 23 Aug 2011    Post subject: Brake light - only works with lots of force Reply with quote
Evening all,
I have a Honda Cityfly 125, and the brake light doesn't seem to be working.
However, when i press the rear brake to the point of almost snapping it works.
So obviously the bulb isn't the issue. Is it something to do with a connector somewhere? Can something have gotten dirty and clogged?
I have done a search and can't find much, so any help is appreciated. Cool
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
iooi
PostPosted: 20:22 - 23 Aug 2011    Post subject: Reply with quote
There will be a switch at the back of the pedal. just need to adjust it.
Usually its a case of screwing it a bit.
_Troy_
PostPosted: 20:33 - 23 Aug 2011    Post subject: Reply with quote
Thanks, i'll check that in the morning.
But what about the front brake? Pulling the lever doesn't activate the brake light at all....
craigT19
Jolly Green Giant
PostPosted: 20:38 - 23 Aug 2011    Post subject: Reply with quote
on the back of the brake lever theres a small swicth with 2 wires on it, pull the wires off and touch them together....if the brake light comes on then the swicth needs replacing Thumbs Up easy to check
Front brake light witch shouldnt cost more than a couple of pound
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
_Troy_
PostPosted: 21:01 - 23 Aug 2011    Post subject: Reply with quote
Thanks for the help guys, i shall investigate tomorrow
neil.
PostPosted: 06:26 - 24 Aug 2011    Post subject: Reply with quote
Front brake light switch is not usually adjustable and is probably buggered. Maybe some dirt/corrosion in it. Could try reviving it by removing it from the brake lever assembly and giving it a bath in contact cleaner whilst operating it vigorously.
Rear switch is like a 'plunger', adjusted by turning a knurled screw that raises or lowers it. Sounds like you need to lower it. Might also be dirty, and mine really benefited from a bath of contact cleaner after 30'000 miles or so as it was turning on when first pressing the pedal, then off/flickery when pushing down a bit more. Since you have a drum brake on the rear, adjustment is needed every now and then as shoes wear or you adjust the pedal free play to compensate for it etc.
Pete.
PostPosted: 07:26 - 24 Aug 2011    Post subject: Reply with quote
Front brake light switch - follow the wires to the front brake lever and you'll find the switch. Some are a round bullet-shaped switch that plugs into a hole in the lever mount others a square block type that if fitted under the lever with a small bolt.
In either case it's most likely the switch plunger is stuck in. Remove the switch and give it a good dose of wd40 and scrub with a toothbrush. You might have to tease the plunger back into operation or you can dismantle the switch and clean it properly. Watch because they fly apart especially the round ones.
Rear brake light is worked by a similar effort except it's pulled by a light spring. Usual problem for these is just like the front switch - they fill up with road dirt.
Un-hook the spring from the pedal, un-plug the wires from the loom and then pull the switch out from it's mount in the frame - you might have to un-screw it but most just wiggle out.
Strip this down by and clean it thoroughly. Don't be surprised to find extensive corrosion to the contact ring, just clean it up with some emery & wd40. Re-assemble it and plug it into the wires to check it works. If it does just re-fit it to the bike and adjust the height so that the brake light works after a small amount of travel on the pedal.
a.k.a 'Geri'
The last post was made 15 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 54 Kb
