| _Troy_ |
 _Troy_ World Chat Champion
 Posted: 20:14 - 23 Aug 2011 Post subject: Brake light - only works with lots of force |
Evening all,
I have a Honda Cityfly 125, and the brake light doesn't seem to be working.
However, when i press the rear brake to the point of almost snapping it works.
So obviously the bulb isn't the issue. Is it something to do with a connector somewhere? Can something have gotten dirty and clogged?
I have done a search and can't find much, so any help is appreciated.  ____________________ Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650 |
| iooi |
 iooi Super Spammer
 Posted: 20:22 - 23 Aug 2011 Post subject: |
There will be a switch at the back of the pedal. just need to adjust it.
Usually its a case of screwing it a bit. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| _Troy_ |
| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 20:38 - 23 Aug 2011 Post subject: |
| _Troy_ |
| neil. |
 neil. World Chat Champion
 Posted: 07:26 - 24 Aug 2011 Post subject: |
Front brake light switch - follow the wires to the front brake lever and you'll find the switch. Some are a round bullet-shaped switch that plugs into a hole in the lever mount others a square block type that if fitted under the lever with a small bolt.
In either case it's most likely the switch plunger is stuck in. Remove the switch and give it a good dose of wd40 and scrub with a toothbrush. You might have to tease the plunger back into operation or you can dismantle the switch and clean it properly. Watch because they fly apart especially the round ones.
Rear brake light is worked by a similar effort except it's pulled by a light spring. Usual problem for these is just like the front switch - they fill up with road dirt.
Un-hook the spring from the pedal, un-plug the wires from the loom and then pull the switch out from it's mount in the frame - you might have to un-screw it but most just wiggle out.
Strip this down by and clean it thoroughly. Don't be surprised to find extensive corrosion to the contact ring, just clean it up with some emery & wd40. Re-assemble it and plug it into the wires to check it works. If it does just re-fit it to the bike and adjust the height so that the brake light works after a small amount of travel on the pedal. ____________________ a.k.a 'Geri'
The last post was made 15 years, 47 days ago. Instead of replying here, would creating a new thread be more useful? |
