That topic again Counter-Steering
Bod
PostPosted: 14:53 - 01 Sep 2004    Post subject: That topic again Counter-Steering Reply with quote
Hi all was watching a video about this today and I can't get my head round it. If I want to go round a right hand bend, push the left side of the bar? So when you are going round it what do you do next........ Confused Confused Confused Confused Confused
Adam_P
PostPosted: 14:55 - 01 Sep 2004    Post subject: Reply with quote
It probably happes naturally when you ride anyway, but as the bike comes out of the bend you just need to push slightly the other way and it will all come back into line.
The best thing to do... go and find a nice quiet road with some bends and TRY IT.
You'll soon see what it does and how it works.
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
fazed
Korn is my hero!
PostPosted: 14:56 - 01 Sep 2004    Post subject: Reply with quote
you do it naturally without realising , Try and actually do it and it could end up nasty Thumbs Up
Bod
PostPosted: 15:05 - 01 Sep 2004    Post subject: Reply with quote
humm tis a bit wierd
sv_cath
PostPosted: 15:13 - 01 Sep 2004    Post subject: Re: That topic again Counter-Steering Reply with quote
No no no!!! Shocked
To go right, you push the right side of the bar away from you, this makes your weight go forward and to the right, therefore leaning the bike to the right.
When you've got round the bend gently just gently move your weight back to a neutral position and you're back in a straight line!
Does that help?
ProXimaCore
Dougal
PostPosted: 15:13 - 01 Sep 2004    Post subject: Reply with quote
Interesting experiment to try is to find a big open space. Maybe an empty carpark. Come to a stop, then pull away while turning the bars slightly to the right for example. You'll continue to to turn right untill you reach a certain speed, then the bike will start to turn the other way all of a sudden. I usually have a play with it when turning out of a junction. You'll see it happen right before you.
Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing Sad
fuzz
PostPosted: 15:17 - 01 Sep 2004    Post subject: Reply with quote
When you're riding in a straight line, gently push the handle bars left or right momentarily. You will feel the bike want to lean in the opposite direction. You must be going quicker than about 15mph for this to work, otherwise you stay straight up and turn in a circle like a push bike! Mr. Green
The Tot
PostPosted: 16:33 - 01 Sep 2004    Post subject: Reply with quote
Countersteering comes instinctively when you pull a fast sweeping bend... You don't know that you're doing it but you are... there's a nice sweeping left hander which drops in elevation at the end of my road and that's when i notice countersteering in action as I AM NOT turning the handlebars to the left... but oddly to the right, bike is leant to the left. Don't try to MAKE yourself do it as FAZED said since it could be nasty. Nearly had a spill on my ped doing it. BTW, correct me if i'm wrong but a good example of counter steer might be found in speedway racing Question Rolling Eyes
Never argue with autism
Claud 14.7 to 1
PostPosted: 17:10 - 01 Sep 2004    Post subject: Reply with quote
I practice it. Not in a few weeks though. I will again. . .
Works well for dodging cars in emergencies, becuase you can dodge quickely out of the way. Make sure you are practicing in the dry though.
Good for tipping the bike hard into turns.
Good for fast change of direction at high speeds.
Good for smooth cornering
You will doing it naturally, but if you gently try it, and practice you will realise how it imporves your cornering.
You can also use it to adjust your line on roundabouts for example. As it can dip the bike in further quicky.
If you practice it, it becomes in-built into your brain and when you do need it you can utilise it, it is second nature.
E.g. When that car pulled out on me i had to use it for the first time, i didnt even think about it, it just happened and i avoided the car. Smile
Mr C
PostPosted: 17:19 - 01 Sep 2004    Post subject: Reply with quote
you are wrong Laughing
the act of countersteering tips the bike over to a lean angle where camber thrust will make it turn
although speedway riders are technically "countersteering", they are actually steering out of a skidding rear wheel which is a different kettle of fish entirely
187.3bhp = 201mph
bennyb24
PostPosted: 18:42 - 01 Sep 2004    Post subject: Reply with quote
ride along at about 50 in a dead straight line, gently push one of your handles forwards ! be amazed at strange results !
Don't try and always think about counter steering, I tried riding like that and spent a couple of weeks going very slowly and generally riding like a plonker Confused
have a look at this picture..... if you look closely you can see how far "the wrong way" the front wheel is pointing !
https://www.picman.co.uk/data/20040811FocBra/EVE%20GRP%202%20INTER/BENSON%20B/DSC_1511.jpg
california_rookie
PostPosted: 21:01 - 01 Sep 2004    Post subject: Reply with quote
The best way I've been explained it is: Push left, lean left, go left.
They actually mention this on our test and if you don't know it, that's already 1 down out of the 4 you're allowed to miss. I'd have never survived my first ride had I not known this.
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
mrchips
PostPosted: 21:07 - 01 Sep 2004    Post subject: Reply with quote
I read about it in Bike and had a try. I couldn't understand it at first but I went to a few corners and roundabouts and tried it out. It is good for tipping you into a corner harder and if you are running wide, push the bars a bit more and it will tighten up your line. It's confusing at first but eventually you get the hang of it and it proves very useful.
Bod
PostPosted: 23:41 - 01 Sep 2004    Post subject: Reply with quote
I think a few sessions in a car park is needed.
izzi81
PostPosted: 23:55 - 01 Sep 2004    Post subject: Reply with quote
The only way to know what it is is to try it. I couldn't get my head round it either until I tried it out - and found it had much more of an effect than I expected! So if you're going to experiment just don't use too much force, it doesn't make much at all to move the bike Smile
"The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81
Bod
PostPosted: 10:14 - 02 Sep 2004    Post subject: Reply with quote
Ok will give it a go later today. Embarassed
RUF_Rider
PostPosted: 11:58 - 02 Sep 2004    Post subject: Reply with quote
i use it on the minimoto Razz
Visitor Q
$25 whore
PostPosted: 12:06 - 02 Sep 2004    Post subject: Reply with quote
I almost exclusively used it. It is a very agressive way to ride but helps you get the utmost handling from your bike. Claud that is normal, if theres space you dodge cars, if there isnt you try and headbutt the front of a car, but you still always tend to try. I cant understand people who T-bone cars completely striaght on, surely some avoiding action must of occurred.
Anyhew it is very useful, helps you corner faster, dodge faster, and generally ride more agressively. For a Right handed, push the right hand side away from you gently, harder you push the faster you corner. So no throwing the bar away from you please, or youll be getting intimate with firstly a hedge and then the AA.
Ninja
Caption Abuser
PostPosted: 16:38 - 02 Sep 2004    Post subject: Reply with quote
I found my 900R front end to be particularly heavy and reluctant to steer when I first started riding. Positive counter steering helped enormously and I now find it's natural/ second nature.
The only other times I find I have to posistviely think about countersteering is when I've cocked up a bend or turn and find I'm not going round it tight enough and simply use a countersteer input to quickly modify the line.
Does countersteering only relate to heavier 'bikes? I wouldn't have thought about it on my old Suzi GP100 as man-handling the bars was more than enough?
James
4 wheels transport the Body ... 2 wheels transport the SOUL
Mr C
PostPosted: 16:50 - 02 Sep 2004    Post subject: Reply with quote
you simply can't ride any bike without counter steering at any speed above trotting pace
try it
at 40mph on a straight road take your hands off the bars and try to steer the bike
it takes massive weight shifts to make it lean and it is VERY slow to react
and it gets tougher the faster you go
the only way to lean (steer) a bike is to counter steer, you just don't know you are doing it, and yes it works on push bikes if you can go fast enough Wink
187.3bhp = 201mph
Claud 14.7 to 1
PostPosted: 17:03 - 02 Sep 2004    Post subject: Reply with quote
Note: It does not have to be an aggressive style at all. It does help to smoothen out cornering when applied with moderation. I know Ricardo will have to use it, if he rides fast.
You do do it anyway, but if you try it you will be emphasising the normal actions used to move the bike.
Try and you will see. Its hard to explain exactly how you can use it . See for yourself. As soon as you move the bars gently the bike will move. You only need slight movements.
I practiced in a straight with no cars around. After i progressed to using it to tip the bike around bends. Thumbs Up
You can always use it to stand the bike up again, when its lent over. All this will fall into place, when you try it.
PostPosted: 17:35 - 02 Sep 2004    Post subject: Reply with quote
A picture tells a thousand words.
This is a right hander!
You should be able to work out which bar end to push from that. (don't try to do what he is doing unless you have a foot of suspension on both ends and balls of steel, I used that as an extreme example to demonstrate the technique.)
Mr C
PostPosted: 17:38 - 02 Sep 2004    Post subject: Reply with quote
I think that is the same as speedway
he isn't using countersteering in the conventional sense in that pic, he is using it to stop the sliding rear from overtaking the front
countersteering on the road is used to initiate the turn, not to maintain it - if you keep pushing then you will keep leaning until you run out of grip or your bar end touches down
187.3bhp = 201mph
Andy99
PostPosted: 20:28 - 02 Sep 2004    Post subject: Reply with quote
countersteering does not have to be aggressive.
The harder you push the handlebar the faster the bike will lean,so if you push the handlebar gently the bike will lean slower.
The only way to practice this is to very gently do it in a straightline to get a feel to how quickly countersteering works then apply what you learn on a set of corners or a roundabout you know.
Bod
PostPosted: 09:03 - 03 Sep 2004    Post subject: Reply with quote
I am still confused to be honest about it. When I am in a straight line and lets say I want to go right, so I push the left bar and it goes left? Am I not pushing it far enough? Confused
The last post was made 22 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 127.79 Kb
