Adjusting points and timing on a CG 125 94
hornetmike
PostPosted: 21:35 - 24 Aug 2011    Post subject: Adjusting points and timing on a CG 125 94 Reply with quote
I've just put a CG back together from a box of bits, with a new barrel and piston, carbs cleaned . It starts after loads of hard kicks or a bump start and then runs but only on the throttle. I think it could be the timing as I've tried differnet carbs.
How do I check and adjust the timing ? The magneto sits on top of the points, but you can get at the wiring coming from the points to the coil.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
hornetmike
PostPosted: 21:59 - 24 Aug 2011    Post subject: Reply with quote
not sure its the orginal engine, does the voltage drop when the points open ? what do i undo to advance / retard the points ?
The last post was made 15 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 46.19 Kb
