| dextersaurus |
 dextersaurus World Chat Champion
| Chalky. |
 Chalky. World Chat Champion
| Casper |
 Casper World Chat Champion
| dextersaurus |
| dextersaurus |
| Casper |
| dextersaurus |
| dextersaurus |
| Blau Zedong |
 Blau Zedong Banned
| dextersaurus |
| Robby |
 Robby Dirty Old Man
| dextersaurus |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:13 - 25 Aug 2011 Post subject: |
| Mr Dunkable wrote: | Looks like it's the valve stem seals.
I'll drop the engine next month and replace them....
Meh, was hoping to get it back on the road this week.
Oh well. CAR IT IS THEN.
Dunc |
Don't jump the gun.
My CBR was smoking worse than a 2 stroke after I got it running again for the first few runs.
You won't clear the smoke until the thing is warmed properly and put under load.
Take it for a good spin, let it get up to temp then thrash the nuts off it. After that (on the same trip) go down the motorway and cruise.
Worked for me anyway and mine is pretty good now.
Also, the bike is perfectly ridable as it is and personally I wouldn't even bother changing the seals. Get a vid of it running up so we can see to what extent it's smoking. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Stalk |
 Stalk Brolly Dolly
| Serendipity |
 Serendipity World Chat Champion
 Posted: 12:28 - 27 Aug 2011 Post subject: |
When you had the oil leak that required the replacement of the sump didn’t you say that you went for a ride and it was running rough, before you noticed the leak? You posted a picture of the whole drain plug area smashed off. Does that mean that you took the bike for a spin with absolutely no oil in it at all? I know CBRs are tough, but that’s not going to do it any favours. ____________________ 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| MickC |
 MickC Spanner Monkey
 Posted: 12:37 - 27 Aug 2011 Post subject: |
This is from:
https://www.cb750c.com/modules.php?name=Forums&file=viewtopic&t=9997 (you may have to register to view the original post - its free if you do)
It's a way of doing valve seals without having to dismantle the top end:
Bucko wrote:
I successfully replaced all the valve seals in my 1100 without removing the head. I used the smaller of the two Lisle ‘plunger style’ tools pictured here: https://www.amazon.com/Lisle-36050-Keeper-Remover-Installer/dp/B0012S61IO. I sent an email to Lisle telling them what I wanted to do and asking which tool I should use and they recommended the one above. I’m not sure why the smaller of the two tools is not available as a stand-alone product but it doesn’t’ seem to be – it’s only available in the kit. There were several tool options that purported to do the same thing but since I didn’t know for sure that it would work, I purchased the cheapest one I could find and it worked just fine.
Replacing all 16 seals took about two hours (not including engine and cam removal of course) and that was being very careful and inspecting each bore carefully. If I did it again, I would expect that it would take less than an hour.
Here’s the method I used:
(Here's a link to a video on how the tool works - not my video, or the tool that I used, but it will give you an idea of how it works: https://www.youtube.com/watch?v=ZFTaeu4GIPo)
I lowered the desired piston and pushed 20 ~30 cm’s of clear plastic tubing into the cylinder (trying to get it to ‘ring’ around the piston crown), then raised the piston until it stopped. Some folks have used rope for this trick. I couldn't find any suitable rope in the garage so I used he battery hose (which I don't need any more since I have an AGM battery). Since you're not actually pressing on the valves when you use the tool, you don't need a lot of pressure on the piston pushing up on the plastic tubing - only enough to keep the valves from falling down.
I cut the bottom off a 35mm film container and split the side and used it as a valve bore protector.
Plugged everything in sight with rags
I removed the bucket and shim with a magnet and inserted the bore protector.
Using the removal section of the above tool, press down on the valve retainer with moderate pressure to remove the retainer and keepers, both of which will be grabbed by the magnet in the tool It’s hard to convey what ‘moderate’ means – but in this context, it means significantly less pressure than required to put the keepers back in.
Using a small pair of needle nose pliers, remove the keepers from the tool and insert back into the retainer (the strong magnet in the tool necessitates the use of the needle nose pliers most of the time)
Remove the springs - taking care to ensure the spring seats don’t come out too – they sometimes stick to the oil on the bottom of the spring and need to be re-inserted.
Using a pair of long needle nose pliers with serrated noses (if that’s the right term?), carefully remove the seal. If you have a small set of valve seal removal pliers, this would be a breeze (next time I do this job, I’ll have a set). In my case, this was the most time consuming part of the job, not because it was so difficult, but because I took my time to avoid damaging the valves and guides, or losing the valve seal springs. On the seals that I found installed in the head, the small wire ‘spring’ that wraps around the base of the seal to ensure a tight fit with the guide, was so small, it was barely visible (admittedly I can see worth crap), but I had to be extra careful when I pulled the seals out, that the wires came out too (probably not a good idea to have any floating around in the valve train). In almost all cases, the wire came out by itself first, before the seal came out. In my case the original seals (don’t know if they were original to the bike) were not brittle, in fact they were the opposite, gummy even. Fortunately, they weren’t so gummy that I had to scrape any of them off the guide, but I did have to go fishing for a few pieces that were mangled due to us of the needle nose pliers
Press a new, oil dipped Viton valve seal over the valve
Using an appropriate sized deep socket, press the valve seal over the guide. Only thumb pressure required. It’s obvious when the seal ‘clicks’ on.
Reinstall the springs, taking care to ensure the tightly wound coils are facing down (toward the piston).
Place the retainer with the keepers in it back on to the springs
Using the installation section of the above tool (inserts into the removal section), press down hard to seat the keepers into the valve and retainer. It took me a while to figure this part out. I thought that it wasn’t working, then by playing with a loose valve I have, I figured out that I wasn’t pressing hard enough. I’ve used this type of tool before, but it was on an automotive engine with a single spring, and it was a while ago - It takes a lot more pressure on th tool to seat the keeprs the 1100F engine. I put a folded cloth in my palm (cause it would hurt my hand if I didn’t) then laid my body weight on my hand/arm to get the required pressure (while keeping the tool in line with the valve. There is an audible click when the keepers install – it’s very satisfying! It seemed to take a lot more pressure to seat the exhaust keepers than the intake keepers. Doesn’t make sense as the springs are the same (I think). Perhaps just a better angle for pushing on the intake side when the engine is sitting flat (i.e. top is sloping towards the front)
Using the removal tool on the newly installed retainer, give the retainer a mild whack with a plastic hammer (less than a whack really) to ensure the keepers are properly seated.
Remove the bore protector
Dip the bucket and shim in oil and place in the head
Repeat for 3 remaining valves for that piston
Take large swig of beer (you don’t want to do this too many times before completing all valves)
Release piston, remove tubing, then move to the next piston
Notes
Having the head on the engine makes this tool easy to use. Because of the pressure required to install the keepers using the tool, it might be tricky to use on the head while it's sitting on the bench. Might just be a matter of blocking off the head so it doesn’t move. All head movement issues aside, using this tool would be much, much, much faster and simpler than dinking around with the old tried and true “C” clamp method, but if that’s what you trust, go for it.
Even if you wouldn’t use this tool to install the keepers, it makes removing them so easy; it would be a welcome addition to any tool box.
In closing…..
So, I’m still fixing things and haven’t put the motor back in the freshly touched up frame (contemplating cam chains now) so I can’t comment on how everything has worked out – that’s yet to be seen, but I don’t’ expect any problems at this point, at least, I don’t expect any problems related to the valve seal job (lord knows: there tons of other shit that will fail in the project yet). One could argue that it’s a bit nuts to have the engine out of the frame and not take the head off. I don’t necessarily disagree! It's just that this motor is new to me and I don't have a good feeling for what needs to be done to it to freshen it up. I did compression and leak down tests and they booth looked exceptional but it smoked on startup like it was a prop in a war movie – a pretty clear indication that the valve seals were gone, but everything else seems good. I didn’t want to remove the head and all the work that goes along with that only to find that there was nothing wrong. After I put a few miles on this engine, I may decide that I want to get into the engine after all – but I’ll make that call when I actually ride it and have a feeling for how it’s running. I can look at motor disassembly next winter if things are worse than they appear.
I have a low mileage 900 that runs really nicely but it too blows some smoke. I wouldn’t ever even consider changing the seals if that means having to crack the head, but now that I know this method works, when I get a chance, I’ll eagerly pull the motor, touch up the frame and bit, swap in new seals, and shove the motor back in.
Hope this is useful.
Useful? Damn that is just freakin' EXCELLENT!!!!
This thread is locked, please discuss it over here or elsewhere... ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| dextersaurus |
| dextersaurus |
| dextersaurus |
 Posted: 19:58 - 29 Aug 2011 Post subject: |
Got it all put back together today.
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/316925_2142432134108_1645368025_2036120_1097591_n.jpg
Battery was completely dead, and while checking the bits and bobs to see why it was draining so quickly, i found that someone (not me) had joined up the remote start on the alarm. to the positive earth... which meant the alarm was shorting out the battery and causing it to just drain completely.
It's now fixed, and on the trickle charger.
Tomorrow shall be the last chance to fix any niggles it has, and i'll take it for a run before dropping it off tomorrow night.
Here's hoping all is well now
Dunc |
The last post was made 14 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
