honda bros 400.. chain adjustment im doomed
Quote Me Happy
PostPosted: 12:17 - 28 Aug 2011    Post subject: Reply with quote
Sounds like a snail cam type adjuster?
Turn it one way to tighten, turn the other way to loosen.
Have you actually looked at the parts on the bike? It may make sense once you've had a look.
yen_powell
PostPosted: 12:32 - 28 Aug 2011    Post subject: Reply with quote
https://www.wemoto.com/bikes/Honda/NT_400_L_Bros_MKll_NC25_PGM_Ignition/90-92/picture/Tool_Chain_Adjuster/
There ya go. Should arrive next day.
XT1200Z and a DR350 in bits
yen_powell
PostPosted: 14:56 - 28 Aug 2011    Post subject: Reply with quote
Bank holiday Wink
Well go and buy a universal one today from Halfords or Hein Gericke.
neil.
PostPosted: 15:14 - 28 Aug 2011    Post subject: Reply with quote
Does the bike have its own little tool kit under the seat or behind a fairing? Might be one of those in there...
Odie
PostPosted: 10:23 - 29 Aug 2011    Post subject: Reply with quote
Last resort, old screw driver and a hammer, use the screw driver as a drift to push the adjuster whilst hitting it with a hammer.
chrisjpartrid...
PostPosted: 23:53 - 29 Aug 2011    Post subject: Reply with quote
I have owned two of these bike and the chain is very easy to adjust ASSUMING that nothing is seized of been buggered by a previous keeper.
I recommend buying the correct tool - There are two parts to it, both available from Wemoto.
With the bike on the centre stand you should slacken the pinch bolt and the C-spanner tool hooks over the eccentric hub to turn it one way or the other. To tighten the chain you need to turn it clockwise I believe.
Spraying some penetraiting oil into the gaps first is also a good idea.
Problems come from two directions - if the thing has seized it will not turn and if a previous owner has spent too much time using a hammer and screwdriver they they may have chiseled the teeth off the adjuster so you may not be able to turn it.
A new part is £180 plus a pain to fit, so well worth looking after the old one if it's still good!
dannyjohnson This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 14 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 67.21 Kb
