Car speaker question
dransy
PostPosted: 18:17 - 28 Aug 2011    Post subject: Car speaker question Reply with quote
Im after changing the speakers in my car , ive looked in the manual and the sizes are 61/2"
Im not after anything fancy or expensive just want something better than the standard ones that are in at the moment.
Can anyone recommend any? Also will i just be able to swop them straight over?
Thanks
Marco
Poseidon
PostPosted: 18:51 - 28 Aug 2011    Post subject: Reply with quote
I had some 180w 16.5cm infinity two way speakers in my ford escort (way back in 2002). Had the car for a year, when I sold the car my dad stole the speakers and blaupunkt head unit and fitted them in his astra van. He uses the van daily and loves his music loud, the speakers are still going strong and sound as good as ever. Found some that look very similar on the bay for 42quid... clicky.
I'm no expert on audio matters, but it seemed no matter what music I chucked through them, the sound was amazing!
EDIT:
Should add that with all the little holes around the edge, you should be able to offer them up and screw them straight in.
1977 Honda CG125
defblade
PostPosted: 10:05 - 29 Aug 2011    Post subject: Reply with quote
Be careful.... most stereos will allow you to turn their amplifier up so high it starts clipping the signal. The nicer the speakers you put in, the quicker this will kill them! (Which is why you always hear lads saying "those were rubbish, they cost £100 and blew in a week"). This is because a better speaker is more sensitive and more responsive... but therefore more delicate when fed a poor signal.
When you fit them, get/make a test tone disc and play a 1kHz signal through your stereo - you'll hear when the note suddenly changes as you turn the volume up. That'll be clipping - turn the volume back a couple of notches and never go above that setting.
If it's not loud enough, come back and ask about amps Wink
dgo1212
PostPosted: 11:05 - 29 Aug 2011    Post subject: Reply with quote
What car is it? If it's newish and quite decent try replacing them with something that will, as you ask "swap straight over", in most cars the standard head units look better than any replacement and same go's for the speakers, speakers diy'ed into parcel shelfs and subs/amps etc in the boot look ghey and can be a real pain in the arse at times
Edit-the ones that Poisedon has found you will not only fit but probably allow the standard covers to go back on instead of the infinity covers, excellent find Thumbs Up
Also take on board the other posters (sorry forget who it was) advice about not turning them up too loud, the test disc sounds a good idea Thumbs Up
Hockeystorm65
PostPosted: 15:41 - 29 Aug 2011    Post subject: Reply with quote
I had these in my FTO:
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_768523_langId_-1_categoryId_165707
with additional Black air tweeters in the dash and a pair of Megavox 6x9's in the back, sounded great. Very Happy Very Happy
Good judgement comes from experience.....experience comes from bad judgement!
The Tot
PostPosted: 23:57 - 30 Aug 2011    Post subject: Reply with quote
Firstly what car? I assume you're looking for front speaker mounts?
I swapped over the front door speakers and went up a size from 5" to 6 1/2" and went with these
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_238023_categoryId_165707_langId_-1?cm_sp=Intelligent_Offer-_-Product_List_Zone_1-_-Blank&iozone=PLPz1
Those are Alpine SXE 1725 coaxials. It's literally a straight swap. I decided to solder and heat shrink them into the existing wire.
I've got an aftermarket kenwood head unit, and since installing these bargain puppies, I've had to reset my EQ to cater for the fact that the built in tweeters put in a lot more highs. Generally speaking, I've got my EQ set to handle metal and rock, so there's a massive mid range scoop, bass and treble guitar solos are accentuated. I don't even need a sub. I play my music load but I seldom turn it to 11. Bass is punchy without being overwhelming. But generally, you get a greater warmth out of these. Affordable and a very good upgrade. I was looking at getting the Alpine SPG's which are the next range up, but I'm adequately impressed with how they sound in my civic.
Pics below
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/285323_10150322575525712_500990711_9472023_4564490_n.jpg
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc6/267474_10150322574540712_500990711_9472004_1025943_n.jpg
https://a7.sphotos.ak.fbcdn.net/hphotos-ak-ash4/267440_10150322580075712_500990711_9472065_3745338_n.jpg
Never argue with autism
defblade
PostPosted: 06:12 - 31 Aug 2011    Post subject: Reply with quote
But you'd be amazed how much better it sounds with one Wink
Apart from the increased bass (which is nice,, but isn't so necessary for rock/metal), you can high-pass your fronts at maybe 100 or 120Hz and take a load of work off them - you'll get even better mids Smile
Daimo
PostPosted: 12:56 - 31 Aug 2011    Post subject: Reply with quote
Firstly, do you have an uprated head unit? This is the first thing to do to vastly improve quality in all areas. It improves the signal, and a cheap speaker can sound a lot better with aftermarket head unit.
If so, you can replace the speakers, but you may find you need to cut the original connector block off that connects to the standard speakers.
You can run the front speakers off off the head unit. Most have "Pre-Outs" these days to either the sub or speakers.
Audio really is a case of "how much do you want to spend?" I've spent £300 on EACH set of components in the past. Depends how much boom you got coming through Wink
A set of 6.5" will go in, as mentioned above you may need plastic adapter plates if the cone is quite deep. Personnally, I made my own out of wood. It doesn't allow so many vibrations to run through the plastic (hence noise/quality loss).
My old kit (those are 15"s, far too big, but I got them at a very good price. Really, I needed two of these Kicker amps, one to power each sub, but at £700, I could only afford so much as an early 20 yo.)
https://images30.fotki.com/v464/photos/4/48802/198778/2003NewICEEquip3-vi.jpg
And the missis, which comprised of x2 sets of Comps (seperate tweets and mids), two amps, and two 12"s.
https://images57.fotki.com/v1613/photos/4/48802/198779/5_1of1-vi.jpg
dransy
PostPosted: 13:52 - 31 Aug 2011    Post subject: Reply with quote
Yeah my head unit is after market its jvc can't remember what model .
Like I say I don't wanna go wild just something better than the original ones car is a 2000 Citroën. Xsara
I like my music loud but don't drive the car enough to spend loads .
Daimo
PostPosted: 14:16 - 31 Aug 2011    Post subject: Reply with quote
Right, well you head unit will probably have a 50x4 (or 60x4 etc) output. That means the head unit can do a peak of 50watts in 4 channels.
So, realistically, unless your wanting to put an amp in to beef up the power, you do not need any more powerfull speakers than the head unit can provide power to. But generally, low end speakers dont cost much and arn't worth upgrading too over standards.
I.E. If you look at a seat of 6.5" speakers, that have a 100w output, then those speakers are more powerfull than the head unit can put out anyway.
RMS power is the one to look at. All the boxes usually have a big wattage figure. But don't be fooled, this is just the peak output, a short sharp burst of power.
RMS is continuous power. So if I have a speaker that has the following speaks
200w
RMS 100w
This means the speaker can continuously run 100w of power all the time, with a brief burst up to 200w
Long story cut short......
Look for some good spec 100w, 60w RMS speakers, to run off your head unit. I'd do a search for a car audio forum (caraudiodirect was a good one, if its still there? Been a few years).
You shouldn't need to spend too much as you simply wont have the power to run them properly. Not without upgrading to an amp.
My personnal choice in your situation.
Leave the front speakers. Turn the bass right down, and work on mid/treble tuning on your head unit. They should be enough for the moment.
Get a small power amp, a small sub, and install off the pre-out off your head unit. A couple of RCA leads, a power lead (and fuse) to the battery for the amp, and sub in the boot.
Bass is mutli-directional, the background fill would be enough. Then you have your fronts (with no bass, as its not needed as you have the sub) which provide mid and treble.
IMO, just upgrading the fronts without extra power from an amp isn't worth your time/money. Go with the small sub and amp, and run no bass through the fronts Smile
Otherwise, it gets complicated Laughing
https://images19.fotki.com/v22/photos/4/48802/245463/ICEWiringLayout-vi.jpg
The Tot
PostPosted: 19:04 - 31 Aug 2011    Post subject: Reply with quote
I've been trying to dig up responses and opinions regarding underseat powered subwoofers - 8" jobbies. I value my boot space since I quite frequently shove my guitars in there so a sub is out of the question. I want, as you guys quite rightly pointed out, to dedicate my 6" jobbies to handle the midrange and highs and anything less than 120 hz to be handled by the amped sub. What's your opinions? Besides, since the woofer is actually mounted in the cabin, then it'll probably have a better effect than being in the boot.
defblade
PostPosted: 20:33 - 31 Aug 2011    Post subject: Reply with quote
Young lad I was working with had an all-in-one Kenwood 150w sub/amp thing installed under his seat the other day.
I was surprised - much better than I expected and just right to fill the sound out from the HU powered speakers. Overall the sound was nice and quite meaty, but a long way from properly loud Wink
The Tot
PostPosted: 20:48 - 31 Aug 2011    Post subject: Reply with quote
My only main query is with the wiring of those things. Because they come with an integrated loom that requires the 12V supply to be wired to any accessory socket in the interior fuse box, I want to know what supply (10A) to tap into. Kenwood/Pioneer, it matters not, none of them have provisions to wire directly to the battery. So I just need clarification on this.
I've got the RCA outlets from the back of the HU to cater for the signal.
Either way, it'll certainly help with the clarity of my sound. Not bothered about sound pressure levels. It's just that when I want to hear screaming death metal, I want to make sure that the double bass punches nicely as well as having the flexibility of providing screaming leads. I'd also appreciate some mids for the vocals too.
Sort me out with that one and i'll order one with my next pay cheque.
defblade
PostPosted: 05:42 - 01 Sep 2011    Post subject: Reply with quote
Order an in-line fuse holder and a relay as well. Wire the power from the battery, via the in-line fuse, to the relay then on to the amp. Switch the relay using the "remote" wire from your HU (or just use the switched live supply that goes into the HU if you don't mind the sub being on with the ignition, rather than strictly on with the HU).
Enjoy Smile
Daimo
PostPosted: 08:20 - 01 Sep 2011    Post subject: Reply with quote
tbh, not as much as you'd think, it depends how well the bass travels.
I.e My setup, was pointed to the front of the car (no rear seats). It actually pulled air out of your lungs. But as soon as I opened the boot, the opposite to where the subs faced, it sounded ruddy awful.
With the advancements in quality these days, I hear a lot of systems use either an under seat setup, or Stealth setup. Where basically the sub/amp combo is built into the tidy side of your boot so it doesn't loose you any boot space.
Issue with under seat sub, it purely space i'd say. Its ALL about the box, you can have a cheap sub, but good box, and it'll still sound quite good.
8" is very "thump thump", the bigger the sub, the more BOOOOOOOOOM you get over thump thump (love the examples Laughing ). But you will need to mount it facing the bottom of the seat, and it'll need a few inchs of box to mount the magnet, plus an amp somewhere. So you need to take the seat out etc. IMO, its a lot of work for minimal gains compare to below.
I would look at a stealth boot setup like this..
https://images2.rdefined.com/d/87674-1/Stereo06.jpg
The Tot
PostPosted: 16:10 - 01 Sep 2011    Post subject: Reply with quote
thump thump is indeed what I will need. Taking the seat out should be no biggie however. The reason why i would also object to a stealth setup is how I drive and particularly if you have pointy or sharp edged objects in your boot! I don't want my cones to be perforated by my storage boxes as it slides everywhere!
Daimo
PostPosted: 09:25 - 02 Sep 2011    Post subject: Reply with quote
You can also buy plastic grates/covers that fit over the front of the sub to stop it being damaged.
As I say, the only issue with under seat setup I think will be space. You need to box the sub to make use, and I just dont think there will be enough room under the seat.
Deffo stick with either an 8" or 10" then. Personnally, i'd go with a 10", i've had 8"s and whilst the thump was good, it was all it was good for. 10" gives you a bit more flex in overall sound. Its why 10"s and 12"s are so popular.
st3v3
PostPosted: 16:43 - 02 Oct 2011    Post subject: Reply with quote
Quick bump rather than start an new thread...
Learnt some things so far, but since I'm learning in the audio components dept, I wanted to ask:
I got a JVC pop-off, stock set of 5" front door speakers and it worked nicely, filled the car with sounds but not OTT.
I got a sub box a while ago, (maybe 6 months) but never touched it and now I want to test it, there's no amp and since the unit drives the front speakers I do questoin why i need an amp for it?
I pluged it in, directly, so the sub in the boot is wired to the white and red auio sockets on the back of the HU but it doesn't work.. the speaker is fine, no damage and the setup of the sub is simple; wire from speaker to terminals of the box.
Where have I gone wrong (was it not installing an amp?) and what am i doing to fix it and get the new tarty part working?
Davo
Davo To The Rescue!
PostPosted: 17:53 - 02 Oct 2011    Post subject: Reply with quote
There is a small amplifier built into the head unit, which is why it can drive the standard door speakers
So you've connected the sub straight to the pre-out's (short for pre-amplified output) on the back of the headunit?
You need an amplifier in between the head unit and the sub!
To wire it in you're going to need to run a power cable from the battery (fused close to the battery), a pair of RCA leads and a remote lead (low current cable to remotely turn on the amp).
Connect these to the amp, then connect the amp to the sub.
I'll try and draw up a diagram when I get off my ipad.
/EDIT: https://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm <-- that'll do better than I can for now.
st3v3
PostPosted: 18:04 - 02 Oct 2011    Post subject: Reply with quote
.. Whistle maybe..
My dad's a dab hand at it, but i wanted to learn it myself, i can't rely on him for electricals forever.
Such a simple bit of stuff, is so much work. Rolling Eyes Laughing
The last post was made 14 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 122.89 Kb
