| itsallgood |
 itsallgood Nitrous Nuisance
 Posted: 16:58 - 30 Aug 2011 Post subject: Help! CG125 running crap |
A while back my bike started running quite badly, bogging down under load, then it got worse to the point it wont go above 20-25mph.
Even in neutral it wont rev much beyond a third of throttle or so - if you try it just pops / bangs and sounds terrible. If you open the throttle too quick it dies.
It takes a few kicks to start now, although once started it idles fine. Having said that it seems to run very hot even when its only been running a couple of minutes
I have changed the ignition coil, condenser, points, checked timing and valve clearances, stripped the carb (all jets seem clear)
Anything else?
Before it started to do this I had ran it really low on petrol then put a full tank in. Could it be bad fuel?
Oh and its a 93 brazil model...
My mod2 is booked for next week too  ____________________ 1995 Honda cg125 SOLD
1993 Jawa 350 twin sport (haven't found the "sport" aspect yet) |
| P.addy |
 P.addy Red Rocket
| itsallgood |
| N cee thirty |
 N cee thirty Banned
 Posted: 19:16 - 30 Aug 2011 Post subject: |
check the points again  ____________________ '00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30 Mod 2 Passed 09/06/2011
Jewlio Iglesias wrote: I actually did vote BNP once |
| RPM |
 RPM Nova Slayer
 Posted: 20:59 - 30 Aug 2011 Post subject: |
Hi there
This might be a daft question, but what state is the spark plug in, only I didn't see anything in your post regarding it
Is there any possibility of an air leak somewhere (starting issue)?
Mike |
| itsallgood |
 Posted: 21:13 - 30 Aug 2011 Post subject: |
Spark plug was a bit black.....i swapped it for another one (of unknown condition....)
Havent had a chance to try some fresh fuel tonight either  ____________________ 1995 Honda cg125 SOLD
| JakeW476 |
 JakeW476 Two Stroke Sniffer
| itsallgood |
 Posted: 21:02 - 05 Sep 2011 Post subject: |
Managed to sort it - turned out the float / float return spring was knackered. Replaced both and it seems to run almost like it should - still a touch juddery but the fuel is a couple of months old so hopefully fresh stuff will sort it!
Bike must have been running lean as opposed to rich!
Thanks for the replies  ____________________ 1995 Honda cg125 SOLD
The last post was made 14 years, 218 days ago. Instead of replying here, would creating a new thread be more useful? |
