 KuDeTa Derestricted Danger
 Posted: 03:21 - 01 Sep 2011 Post subject: Raising Handlebars? |
Hiya,
I'm very recently passed my CBT and have just start riding really. I own a CG125 (2005).
I'm a really tall guy and feel quite uncomfortable on the bike with the handlebars so low. I am wondering if it is possible to replace/improve my setup so that they are a little bit higher.
I have no mechanical experience, but i'm a very hands on guy so doubt the actual work will be a problem. Is it simply a case of finding a replacement of the right diameter or is it more involved? Any links to a good place to find replacement would be most appreciated. Also, am i allowed (in the UK) to do this work myself and drive it or will i have to take it to mechanic for a once over.
Your patience with a newb is greatly appreciated
Ku |
 ..... Quote Me Happy
 Dazbo666 World Chat Champion
 Posted: 07:12 - 01 Sep 2011 Post subject: |
You could do a search for Renthal (or similar) handlebars that have various angles and heights available ... and/or you could change the handlebar riser for a taller one.
Just be sure to double check there's still enough free play in your clutch, throttle and brake cables when your controls are moved to their new position ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
 DrDonnyBrago World Chat Champion
 Posted: 08:47 - 01 Sep 2011 Post subject: Re: Raising Handlebars? |
You can change bars without needing approval from a garage.
Simplest option if you can find them is a set of bar risers - if you buy new bars you will need to swap everything over to the new set, not that difficult but a bit of a pain in the ass. If you want new bars it is simply a matter of choosing some with the correct dimensions where it mounts to the forks and where the grips and controls fit. Also make sure your cables, brake lines etc etc are long enough with the bar risers/new bars and don't get pulled tight or snag on anything when you turn turn the handlebars.
This is a set of handlebar risers:
https://www.1tail.com/productImages_thumbBIG/158000
To be honest though, CGs are tiny bikes so you may never be comfortable, the biggest 125 is probably the 125 varadero so that might fit you but the best solution is to pass your motorcycle test and get a larger bike more suited to your body size and with a bigger engine. |
