Raising Handlebars?
KuDeTa
PostPosted: 03:21 - 01 Sep 2011    Post subject: Raising Handlebars? Reply with quote
Hiya,
I'm very recently passed my CBT and have just start riding really. I own a CG125 (2005).
I'm a really tall guy and feel quite uncomfortable on the bike with the handlebars so low. I am wondering if it is possible to replace/improve my setup so that they are a little bit higher.
I have no mechanical experience, but i'm a very hands on guy so doubt the actual work will be a problem. Is it simply a case of finding a replacement of the right diameter or is it more involved? Any links to a good place to find replacement would be most appreciated. Also, am i allowed (in the UK) to do this work myself and drive it or will i have to take it to mechanic for a once over.
Your patience with a newb is greatly appreciated Smile
Ku
Quote Me Happy
PostPosted: 06:56 - 01 Sep 2011    Post subject: Reply with quote
You can either get new bars with a higher bend or you can buy bar risers.
I'd go with the risers, they'll only take a few minutes to fit.
Dazbo666
PostPosted: 07:12 - 01 Sep 2011    Post subject: Reply with quote
You could do a search for Renthal (or similar) handlebars that have various angles and heights available ... and/or you could change the handlebar riser for a taller one.
Just be sure to double check there's still enough free play in your clutch, throttle and brake cables when your controls are moved to their new position
Word of the day : DILLIGAF
DrDonnyBrago
PostPosted: 08:47 - 01 Sep 2011    Post subject: Re: Raising Handlebars? Reply with quote
You can change bars without needing approval from a garage.
Simplest option if you can find them is a set of bar risers - if you buy new bars you will need to swap everything over to the new set, not that difficult but a bit of a pain in the ass. If you want new bars it is simply a matter of choosing some with the correct dimensions where it mounts to the forks and where the grips and controls fit. Also make sure your cables, brake lines etc etc are long enough with the bar risers/new bars and don't get pulled tight or snag on anything when you turn turn the handlebars.
This is a set of handlebar risers:
https://www.1tail.com/productImages_thumbBIG/158000
To be honest though, CGs are tiny bikes so you may never be comfortable, the biggest 125 is probably the 125 varadero so that might fit you but the best solution is to pass your motorcycle test and get a larger bike more suited to your body size and with a bigger engine.
The last post was made 14 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 40.39 Kb
