YBR125 Clutch Slipping
sparkywilliam...
PostPosted: 10:26 - 01 Sep 2011    Post subject: YBR125 Clutch Slipping Reply with quote
YBR125 29k Miles 2007 .
Was slipping at high revs so i have replaced clutch with one from a younger lower mileage (2009,4,000k)
Please see attached picture of plates (showing burnt metal colour) and basket (with marked indents where the plates sit)
New clutch works great but wanted your opinions on how those two things could affect the clutch.
incidentally i went through a long period of using cheap basic car oil and (without causing a long debate on the merits of car/bike oil etc!-which has been repeated many times before on this forum)... do you think this would have aided it's decline?
Thanks all
Mark
Previously CG125,YBR125 Now GSF600 Bandit
DrDonnyBrago
PostPosted: 11:20 - 01 Sep 2011    Post subject: Re: YBR125 Clutch Slipping Reply with quote
Thanks all
Mark
Heat marks on the clutch plates suggests it has either been slipping for a while or you have been drag racing it Wink .
I would guess that the notched clutch basket caused the plates to not move freely, sticking the clutch open and causing it to slip. The slipping then probably caused the bluing of the plates maybe warping them with heat and making the slipping effect worse. Could be a few causes though tbf.
Either way, assuming your cable and lever are well adjusted and that the new parts are in good nick you should have sorted it. Can't see the oil being a contributory factor.
PostPosted: 11:23 - 01 Sep 2011    Post subject: Re: YBR125 Clutch Slipping Reply with quote
Noticeable notches, but not sure if they can be felt. Assuming they can then I would agree.
sparkywilliam...
PostPosted: 11:51 - 01 Sep 2011    Post subject: Reply with quote
yes the notches were quite bad and could be felt.
It had been slipping for a while. (Does the words YBR and drag racing belong in the same sentence?!)
Thanks chaps
craigT19
Jolly Green Giant
PostPosted: 20:58 - 02 Sep 2011    Post subject: Reply with quote
it doesnt need to be slipping for a while for it to do that, think about it, its 2 metal surfaces rubbing together and at say 5k rpm (6k redline on ybr, from memory 5k rpm in top is about 50mph) there rubbing together at extremely high speed.
Ybr have very small clutches even compared to other 125's they have small clutches.
They suffer in particullar from dirty oil? the clutch has its own oil strainer (behind the clutch casing just below and to the right of the clutch basket), no this isnt there for the engine...its there for the clutch Wink, this should be removed and cleaned every 12k miles or so... if u dont you actually restrict the oils ability to drain away from the clutch plates over lubing them causing more slip- more slip more heat- more heat... faster pwned clutch plates.
As for the notches, thats fairly normal tbh, the clucth basket itself is cast from pretty poor grade metal and with alot of miles they start to wear.
Honestly its just wear and tear mate, try not to worry about it Wink Thumbs Up
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
The last post was made 14 years, 305 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 46.85 Kb
