need help with my 2001 yamaha wr250f
gavin198
PostPosted: 16:20 - 02 Sep 2011    Post subject: need help with my 2001 yamaha wr250f Reply with quote
hi all any info would be great on my problem
i jet washed my bike and lost my spark dumb i know
so i paid an auto electrician to come out too tell me my problem
he said cdi due to there was no reading from the orange wire
so i managed to source one and i fitted it and now i still have no spark
i have readings from the pic up ect front light will come on
just no spark now this is my last plea for help
any thing for me to try i will i need fix it as its also my main transport
waffles
PostPosted: 16:24 - 02 Sep 2011    Post subject: Reply with quote
Stupid question here - have you actually checked the spark plug to make sure you didn't jetwash inside it? I did the same thing with my xr, funny watching four or five guys trying in vain to start a bike when all it needed was a quick squirt with a compressor Rolling Eyes
gavin198
PostPosted: 16:31 - 02 Sep 2011    Post subject: Reply with quote
derr i should of check that first how stupi.....................
actually went out and bought a new one
along with the cdi
but i dont want to pay again for another auto electrician to come out
Formerly known as
P.
Cover the entire area in wd40, HT lead, spark plug etc
Have you changed spark plug? If not, try a new one.. Could be coincidental that it died that day Laughing
Do you have a multimeter? Check the loom and work your way from the battery forwards.
gavin198
PostPosted: 16:35 - 02 Sep 2011    Post subject: Reply with quote
Was last week the wash tho and all connections been dried also i have no battery on my bike
also kids broke my multimeter thats why i paid auto electrician
He did multimeter readings and he said cdi due to the wire that goes to ignition coil did not produce a reading
waffles
PostPosted: 16:45 - 02 Sep 2011    Post subject: Reply with quote
You paid for an auto electrician to diagnose your bike and you are mocking my contribution? I assumed that as you hadn't checked seeing as there was no mention of it in the OP. Silly me!
When you turn the key and start it does it attempt to crank over or is there nothing at all? Check the charge across the battery then start checking connections behind the headlight as its possible that some spray got up in there. Pull the connectors apart, check for any corrosion and give each side a squirt of WD40.
EDIT - no battery, no problem. Try and borrow a multimeter as its a lot cheaper than forking out for someone to fart around with your bike. Got a workshop manual for it?
EDIT 2 - See if this one works
gavin198
PostPosted: 16:56 - 02 Sep 2011    Post subject: Reply with quote
No not mocking you contribution as i should of stated that a new plug was purchused
There is no key on my bike only one connection from the headlight
and this is unclipped anyway same with the stop button
and i havent managed to find anyone with a multimeter as of yet.
I do hav a manual for it https://www.ymenvom.nl/new/manuals/M5PH-30.PDF
page 604 electrics but would need a multimeter to check proper
yen_powell
PostPosted: 17:28 - 02 Sep 2011    Post subject: Reply with quote
Water in your killswitch, killswitch on?
Low tension leads to the coil, are the spade terminals green, if so, scrape them and reconnect.
Is the sparkplug cap screwed onto the lead properly? Remove it, cut a few mm of lead off and reconnect.
XT1200Z and a DR350 in bits
gavin198
PostPosted: 17:40 - 02 Sep 2011    Post subject: Reply with quote
Kill switch removed so no interferance from that
also removed the whole loom and stripped it down drying all connections and wire
I did remove the cap and held it in my hand with bit of wire poking out and touching my skin and i did kick it and no shock
SuzukiTom
PostPosted: 20:36 - 02 Sep 2011    Post subject: Reply with quote
he actually tested any of these connections?
id test the stator output and work your way out fromt there
Fizzer Thou
PostPosted: 21:29 - 02 Sep 2011    Post subject: Reply with quote
Is there a side stand cut-out switch? Or even a clutch lever cut-out switch?
I am surprised that a so called auto-electrician could not find the fault.They charge a lot more than the cost of a reasonable multi-meter from somewhere like Screwfix or Machine Mart.
Always have a 'Plan B'
gavin198
PostPosted: 14:51 - 03 Sep 2011    Post subject: Reply with quote
I know now lol. I've just been and purchased one
there is no side stand cut out or clutch
gavin198
PostPosted: 08:59 - 04 Sep 2011    Post subject: Reply with quote
big improvement today with my checking and my mate limited knowlage and his multimeter and the manual
https://www.ymenvom.nl/new/manuals/M5PH-30.PDF (the manual i used) that one user sent me the link to for that im greatful
IGNITION COIL INSPECTION
primary coil resistance 0.28 (WITHIN SPEC)
Secondary coil resistance 11.3 (WITHIN SPEC)
CDI MAGNETO INSPECTION
Pickup coil resistance 312 (WITHIN SPEC)
-----Charging coil 1 resistance------- NO READING----------
Charging coil 2 resistance 605 (WITHIN SPEC)
DO NEED TO REPLACE THE MAGNETO NOW OR IS THERE ANY FIX FOR THIS?
gavin198
PostPosted: 16:02 - 05 Sep 2011    Post subject: Reply with quote
will a stator out of a 2004 wr250f fit in my 2001 wr250f
Fizzer Thou
PostPosted: 12:13 - 06 Sep 2011    Post subject: Reply with quote
Compare the part numbers -
https://www.ronayers.com/Fiche/TypeID/26/Type/GENERATOR_/MakeID/4/Make/Yamaha/YearID/42/Year/2001/ModelID/7741/Model/WR_250F/GroupID/368002/Group/GENERATOR_
https://www.ronayers.com/Fiche/TypeID/26/Type/GENERATOR_/MakeID/4/Make/Yamaha/YearID/45/Year/2004/ModelID/1832/Model/WR250FS_WR250F/GroupID/346360/Group/GENERATOR_
But I would send the alternator to these people https://www.westcountrywindings.co.uk/ as they do a good quick turnaround on your existing coil former,so keeping the costs down.
gavin198
PostPosted: 17:44 - 07 Sep 2011    Post subject: Reply with quote
Fizzer Thou wrote:
it got sent off today as they was recomended by one of the local racers/shop owner i sent mine down with his
thanks
The last post was made 14 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 93.23 Kb
