changing fork seals any recommendations?
biker58
PostPosted: 20:38 - 02 Sep 2011    Post subject: changing fork seals any recommendations? Reply with quote
My GSX600F is in pretty good condition but i have decided to get a few things done on it just to be safe, in a couple of weeks i will attempt to change the fork seals.
I will get myself a guide to work from and take my time so i dont have any disasters.
Just to get me started what tools will i need?
Will a Haynes manual be sufficient for the job?
How do i know what oil to replace?
Thanks
1995 Suzuki GSX600F rider
hmmmnz
PostPosted: 20:45 - 02 Sep 2011    Post subject: Reply with quote
pretty easy job,
you'll need either a allen key set of socket to undo the bottom bolt,
and all the tools needed to remove the wheel and the forks from the clamps,
as for oil, 15w is normally standard, i tend to go for a heavier oil as im a bit heavier, a 20w or 25w
up to you really,
the haynes should cover everything
the humans are dead
I kick arse for the lord
biker58
PostPosted: 20:54 - 02 Sep 2011    Post subject: Reply with quote
hmmmnz wrote:
pretty easy job,
up to you really,
Thanks for the good fast reply!
SuzukiTom
PostPosted: 21:11 - 02 Sep 2011    Post subject: Reply with quote
losen the caps and all that jaz beofre you unclamp the forks.....make life a bit easier!
have a bucket ready, its a messy job.......if your anything like me
Raffles
PostPosted: 21:33 - 02 Sep 2011    Post subject: Reply with quote
Are your fork seals actually knackered?
biker58
PostPosted: 21:40 - 02 Sep 2011    Post subject: Reply with quote
One is looking a bit worse for wear although there is no problem with it at the moment. Just thought would be a good idea to replace them as it's a new bike and i'm not sure when they were last done anyway.
Bezzer
PostPosted: 23:16 - 02 Sep 2011    Post subject: Reply with quote
Crack the top nuts as mentioned, just a 1/4 turn will do then slacken and remove the allen headed bolt hidden right underneath each fork leg. These hold the damper tube inside the legs and if you don't take them out when the insides still all under compression it can be a right pig to do without the special tool.
Unscrew them fully and take them out don't just "slacken" them as the Haynes says otherwise it can just spin when the rest is undone and again be a right pig.
The last post was made 14 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.79 - MySQL Queries: 13 - Page Size: 51.92 Kb
