Project TS200RT Tidy Up
Section59
PostPosted: 19:57 - 02 Sep 2011    Post subject: Project TS200RT Tidy Up Reply with quote
Now then peoples. First project, first project thread.
Not used to doing this kinda thing and am as useless as anything when it comes to mechanical stuff, so go easy on me. I figured if i had some people watching what im doing, it might make me pull my finger out and get this fucker sorted, instead of it forever being in the shed in bits.
Also hoping some of you guys can help me with the many problems im sure to have also.
Plans are :
Source a top end kit, piston, rings, wrist pin, circlips, little end bearing, which is seeming easier said than done!
Redcar suzuki quoted me £150 just for the piston and rings! Shocked Might have sourced rings and piston from germany for considerably less though if it pans out, just waiting on the seller to get back to me.
Get frame and swingarm powdercoated gloss black, might get the yokes done also but that would mean getting the stem pressed out and new head bearings, right?
Tank, tank side panels painted gloss black, new front and rear mudguards, and somehow tidy up the side panels as they're scratched to buggery. Basically i just want to tidy it up as best as i can for as little as poss and also learn a bit more about the mechanicals in the process.
Heres a few pics of how it looked until i started stripping it, will update with pics tomorrow with current progress.
https://farm7.static.flickr.com/6197/6106434323_15ba91ba0c.jpg
https://farm7.static.flickr.com/6193/6106434065_4aac3e40fb.jpg
https://farm7.static.flickr.com/6071/6106433869_5f1b10172a.jpg https://farm7.static.flickr.com/6066/6106981164_7cf0cf8bba.jpg
Ignore the RM stickers. They're only on there due to not being able to find original TS200R graphics..
Section59
PostPosted: 21:47 - 02 Sep 2011    Post subject: Reply with quote
Lots of interest i see! Laughing Laughing
Anyway, seeing as i've got the camera out and the motor is sat next to me, might aswell update on the engine front.
Cylinder head and barrel off :
Bore looks good to me, no scoring, can still see hone marks.
https://farm7.static.flickr.com/6067/6106587815_4484c949dd.jpg
Head is pitted quite a bit though, no signs of an explosion in there as the pits are uniform, whats the best way to clean it up, or will it be alright to use as is?
https://farm7.static.flickr.com/6065/6106587393_fd57fb183d.jpg
Need to take the clutch cover off to replace the plates/springs as when it was together there was serious clutch slip but i've hit a snag, mullered clutch cover bolt. Whats the best way to get this out, bearing in mind i don't have many tools at my disposal..
https://farm7.static.flickr.com/6183/6107135754_f4bb867a3d.jpg
at106
PostPosted: 22:24 - 02 Sep 2011    Post subject: Reply with quote
Good luck with your project Thumbs Up
To remove the rounded bolt, first try filing two flats on either side and use a good fitting open ended spanner on the two flats. If that doesnt work cut a slot accross the centre of the bolt head and use a good flat screwdriver to get it out. To cut the slot a junior hacksaw may fit if not you will need something like a dremmel.
stevo as b4
PostPosted: 09:09 - 03 Sep 2011    Post subject: Reply with quote
Hi mate nice project! I'll be watching this progress with interest, as it's my kind of bike TBH!
Did you do the supermoto conversion yourself on it, or buy it like that to start with? I've never seen a TS200R motard before, and i reckon it will be a really cool and great fun bike to ride too!
We all have an interest in certain types and styles of bike that we like to seek out and specialise in, and Big bore 200cc versions of the popular 2stroke 125 trail bikes are one of mine! Id quite like to get a 200cc version of every Japanese 125 trail bike one day, and the Gilera and Aprilia 200cc models too.
PostPosted: 10:17 - 03 Sep 2011    Post subject: Reply with quote
You don't have to get the stem pressed out or the bearings changed to powder coat the yokes you will have to change the bearings to powder coat the frame. Thumbs Up
Section59
PostPosted: 16:54 - 03 Sep 2011    Post subject: Reply with quote
Cheers for that, will give that a bash in a bit, hopefully the file thing will work as i've got no dremmel!
Grab a pew matey, might be a long one with my mechanical skills! Laughing Bought the bike as is with the motard wheels already on, the guy that owned it before the last owner did the motard conversion himself.
Got the enduro wheels for it too but honestly, its far more fun on the motard wheels. Thumbs Up Has got me into trouble a couple of times though, hence the username on here.... Rolling Eyes
Have only seen two motard ts200r's on the net, both in japan. Short rebuild vid of one can be found on youtube here : https://www.youtube.com/watch?v=CQ54eujU_XU (i know, super crap music, right..) - If mine comes up half as good as that i'll be happy.
When i first bought this, i also had my hornet. I've had more fun on this little two stroke on the single track lanes than i did on the hornet!
Seeing as you're into the 200cc big bores, you wouldn't happen to have any information on it, would you? I've scoured the net for months trying to find info on it, but hardly anyone knows anything about them! From what i can figure out so far, it uses the same motor as the RG200 and the wolf200?
Ah, in that case then, i think i might get the yokes done also. They're not too bad but for the extra £10 it'll cost might aswell get those done aswell.
Is there anything i should do to prep for powdercoat?
Anyway, Moar pics :
Frame and swingarm stripped, still need to get the bearings out the swingarm, any tips for this?
https://farm7.static.flickr.com/6067/6108892899_6a7d0cc3d6.jpg
Soaked the headlight/side panels in bleach overnight to clean them up a bit, kinda worked but due to the deep scratches, still look tatty. Think im going to change the headlight anyway as the connector is knackered
https://farm7.static.flickr.com/6077/6108891937_3f0327f029.jpg
Forks have been stripped and new fork seals put in, which was all i was supposed to be doing to it before putting back on the road, but then i got the smart idea to tidy it up, just waiting on some fork oil now... Rolling Eyes
https://farm7.static.flickr.com/6199/6108894165_83fa761d9d.jpg
dangerousdave
PostPosted: 15:25 - 04 Sep 2011    Post subject: Reply with quote
great project mate, will keep my eye on it & help out if i can.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
stevo as b4
PostPosted: 23:51 - 04 Sep 2011    Post subject: Reply with quote
The Suzuki TSR is quite a rare bike even in 125cc form, as few were sold in the uk, compared to DTR's/KMX's and even KDX's are much more common than the TSR.
I don't think that Mainland Europe got the TS200R, and it seems to be one of the less imported Japanese 2stroke trail bikes too. There was an RG200Fun/Wolf, and i seem to remember seeing a broucher on line for one, that claimed 35bhp@9000rpm for the motor.
For spares, you can try the grey bike specialists and any trailbike specialists etc, but your probably going to get 200cc specific parts and engine bit's from Japan, or Aus/NZ much more easily. I dare say that some cycle parts, and bodywork will interchange with the 125's, but expect the suspension front and rear to be slightly different, as most 200cc versions of 125 trial bikes, had a better and different chassis spec than the 125's.
Examples would be the Alloy swing arms on the KMX and MTX200, and the dual radiator set up on the DT200R, along with better shocks and USD or stronger and bigger forks.
Werny
PostPosted: 00:32 - 05 Sep 2011    Post subject: Reply with quote
Good luck with the project!
Have you got that butchered bolt out yet? If the suggestions already given don't work, you can try locking a pair of molegrips onto it to try and undo it, assuming you have any, but it doesn't really look like you got the room there.
If you have a centerpunch, drill and a 6.5mm drillbit (assuming it's an M6 bolt), you could also pop a center dot in the middle of the head then drill into the bolt with the 6.5mm drill, when it drills through the head the remains of the head will just pop off the shank of the bolt, leaving you able to slide the casing off the protruding stud, then remove it at your convenience once the casing is out of the way.
Section59
PostPosted: 19:12 - 05 Sep 2011    Post subject: Reply with quote
Cheers for the tips and comments guys!
Nothing new done since last post, still havent got the bolt out, taking it to a mates garage tomorrow as he's got more tools than i have, should have it out in no time.
On the plus side, i've ordered new piston + rings, cost me £67 inc delivery from germany, but thats a damn sight better than the £150 redcar wanted!
Need to source a gasket kit, wrist pin and some circlips now, oh, and get some fork oil..
Section59
PostPosted: 10:38 - 10 Sep 2011    Post subject: Reply with quote
Well, now im fucked off.
Bought some new fork seals (pyramid parts...) about a week or so ago and fitted them. Got my fork oil in the post this morning so i figured i'd put the oil in and get the suspension part buttoned up and done. Guess what? They're fucking leaking. Rolling Eyes
I knew this would happen as after i bought them, i did some googling and i'm not the first. My fault for not checking first i suppose, still asking for a refund though.
So, waste of £7 there already, now i've got to find some decent replacements. Oh, i also lost a shit load of my new fork oil while re-stripping the forks down coz i got a bit angry and knocked the fork over, doh..
Also missed the postman while doing the above, so have to wait until monday now so i can go pick up my speedo cable and clutch springs.
I wish i'd stayed in bed... Mad Although, i did manage to get that mullered bolt out, borrowed a dremel and cut a slot in it. Smile
Section59
PostPosted: 16:25 - 15 Sep 2011    Post subject: Reply with quote
Well, some progress finally.
Got my refund from p-k-n on ebay for the seals, after having the cheek to ask me if i'd put em in the wrong way! Rolling Eyes So i sent em this pic to show how shite they were. Mr. Green
https://farm7.static.flickr.com/6068/6144210362_11a58c9da2_z.jpg
Got my NOS piston/rings in from the Netherlands and also bought a new wrist pin and little end bearing.
https://farm7.static.flickr.com/6083/6149855037_df1f66ccfb.jpg
Dry fitted it all together for now until i can get myself a gasket kit.
Am i right in thinking most of the gaskets from a TS125R will fit, besides base and head gasket? They look very similar...
Also got my new clutch springs and speedo cable through from wemoto (Excellent service. Will use again.) so those are all fitted. no pics sorry, although im sure you know what they both look like..
Removed front and rear wheel bearings, one of the back ones was a bitch and i ended up knocking the centre out then struggling for 15 min trying to remove the remaining outer ring.
https://farm7.static.flickr.com/6090/6149850563_b0e56ceac2.jpg https://farm7.static.flickr.com/6194/6150402466_2fc935d801.jpg
New bearings ordered and will be fitted asap once they arrive. These needed to be done anyway as i got an advisory for em at last mot.
Really want to get the wheels and hubs powdercoated as they look a bit manky but i dont have the cash for that at the min so going to leave them as is. Might do em after i've got it all back together and on the road.
Sooo, thats about it for now. Next update im hoping to have a nice swingarm and frame to show off, if i can afford it.
dangerousdave
PostPosted: 23:35 - 20 Sep 2011    Post subject: Reply with quote
If the bolt pattern is the same then you can always modify them if needed with a scalpel. Just check the gasket sits flush with the ports.
The last post was made 15 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 86.58 Kb
