| Section59 |
 Section59 Spanner Monkey
 Posted: 19:57 - 02 Sep 2011 Post subject: Project TS200RT Tidy Up |
Now then peoples. First project, first project thread.
Not used to doing this kinda thing and am as useless as anything when it comes to mechanical stuff, so go easy on me. I figured if i had some people watching what im doing, it might make me pull my finger out and get this fucker sorted, instead of it forever being in the shed in bits.
Also hoping some of you guys can help me with the many problems im sure to have also.
Plans are :
Source a top end kit, piston, rings, wrist pin, circlips, little end bearing, which is seeming easier said than done!
Redcar suzuki quoted me £150 just for the piston and rings! Might have sourced rings and piston from germany for considerably less though if it pans out, just waiting on the seller to get back to me.
Get frame and swingarm powdercoated gloss black, might get the yokes done also but that would mean getting the stem pressed out and new head bearings, right?
Tank, tank side panels painted gloss black, new front and rear mudguards, and somehow tidy up the side panels as they're scratched to buggery. Basically i just want to tidy it up as best as i can for as little as poss and also learn a bit more about the mechanicals in the process.
Heres a few pics of how it looked until i started stripping it, will update with pics tomorrow with current progress.
https://farm7.static.flickr.com/6197/6106434323_15ba91ba0c.jpg
https://farm7.static.flickr.com/6193/6106434065_4aac3e40fb.jpg
https://farm7.static.flickr.com/6071/6106433869_5f1b10172a.jpg https://farm7.static.flickr.com/6066/6106981164_7cf0cf8bba.jpg
Ignore the RM stickers. They're only on there due to not being able to find original TS200R graphics.. |
| Section59 |
| at106 |
 at106 Brolly Dolly
 Posted: 22:24 - 02 Sep 2011 Post subject: |
Good luck with your project
To remove the rounded bolt, first try filing two flats on either side and use a good fitting open ended spanner on the two flats. If that doesnt work cut a slot accross the centre of the bolt head and use a good flat screwdriver to get it out. To cut the slot a junior hacksaw may fit if not you will need something like a dremmel. |
| stevo as b4 |
| chris-red |
 Posted: 10:17 - 03 Sep 2011 Post subject: |
You don't have to get the stem pressed out or the bearings changed to powder coat the yokes you will have to change the bearings to powder coat the frame.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| Section59 |
 Posted: 16:54 - 03 Sep 2011 Post subject: |
| at106 wrote: | Good luck with your project
Cheers for that, will give that a bash in a bit, hopefully the file thing will work as i've got no dremmel!
| stevo as b4 wrote: | Hi mate nice project! I'll be watching this progress with interest, as it's my kind of bike TBH!
Did you do the supermoto conversion yourself on it, or buy it like that to start with? I've never seen a TS200R motard before, and i reckon it will be a really cool and great fun bike to ride too!
We all have an interest in certain types and styles of bike that we like to seek out and specialise in, and Big bore 200cc versions of the popular 2stroke 125 trail bikes are one of mine! Id quite like to get a 200cc version of every Japanese 125 trail bike one day, and the Gilera and Aprilia 200cc models too. |
Grab a pew matey, might be a long one with my mechanical skills! Bought the bike as is with the motard wheels already on, the guy that owned it before the last owner did the motard conversion himself.
Got the enduro wheels for it too but honestly, its far more fun on the motard wheels. Has got me into trouble a couple of times though, hence the username on here....
Have only seen two motard ts200r's on the net, both in japan. Short rebuild vid of one can be found on youtube here : https://www.youtube.com/watch?v=CQ54eujU_XU (i know, super crap music, right..) - If mine comes up half as good as that i'll be happy.
When i first bought this, i also had my hornet. I've had more fun on this little two stroke on the single track lanes than i did on the hornet!
Seeing as you're into the 200cc big bores, you wouldn't happen to have any information on it, would you? I've scoured the net for months trying to find info on it, but hardly anyone knows anything about them! From what i can figure out so far, it uses the same motor as the RG200 and the wolf200?
| chris-red wrote: | You don't have to get the stem pressed out or the bearings changed to powder coat the yokes you will have to change the bearings to powder coat the frame.  |
Ah, in that case then, i think i might get the yokes done also. They're not too bad but for the extra £10 it'll cost might aswell get those done aswell.
Is there anything i should do to prep for powdercoat?
Anyway, Moar pics :
Frame and swingarm stripped, still need to get the bearings out the swingarm, any tips for this?
https://farm7.static.flickr.com/6067/6108892899_6a7d0cc3d6.jpg
Soaked the headlight/side panels in bleach overnight to clean them up a bit, kinda worked but due to the deep scratches, still look tatty. Think im going to change the headlight anyway as the connector is knackered
https://farm7.static.flickr.com/6077/6108891937_3f0327f029.jpg
Forks have been stripped and new fork seals put in, which was all i was supposed to be doing to it before putting back on the road, but then i got the smart idea to tidy it up, just waiting on some fork oil now...
https://farm7.static.flickr.com/6199/6108894165_83fa761d9d.jpg |
| dangerousdave |
 dangerousdave Traffic Copper
| stevo as b4 |
 Posted: 23:51 - 04 Sep 2011 Post subject: |
The Suzuki TSR is quite a rare bike even in 125cc form, as few were sold in the uk, compared to DTR's/KMX's and even KDX's are much more common than the TSR.
I don't think that Mainland Europe got the TS200R, and it seems to be one of the less imported Japanese 2stroke trail bikes too. There was an RG200Fun/Wolf, and i seem to remember seeing a broucher on line for one, that claimed 35bhp@9000rpm for the motor.
For spares, you can try the grey bike specialists and any trailbike specialists etc, but your probably going to get 200cc specific parts and engine bit's from Japan, or Aus/NZ much more easily. I dare say that some cycle parts, and bodywork will interchange with the 125's, but expect the suspension front and rear to be slightly different, as most 200cc versions of 125 trial bikes, had a better and different chassis spec than the 125's.
Examples would be the Alloy swing arms on the KMX and MTX200, and the dual radiator set up on the DT200R, along with better shocks and USD or stronger and bigger forks. |
| Werny |
 Werny Traffic Copper
| Section59 |
| Section59 |
 Posted: 10:38 - 10 Sep 2011 Post subject: |
Well, now im fucked off.
Bought some new fork seals (pyramid parts...) about a week or so ago and fitted them. Got my fork oil in the post this morning so i figured i'd put the oil in and get the suspension part buttoned up and done. Guess what? They're fucking leaking.
I knew this would happen as after i bought them, i did some googling and i'm not the first. My fault for not checking first i suppose, still asking for a refund though.
So, waste of £7 there already, now i've got to find some decent replacements. Oh, i also lost a shit load of my new fork oil while re-stripping the forks down coz i got a bit angry and knocked the fork over, doh..
Also missed the postman while doing the above, so have to wait until monday now so i can go pick up my speedo cable and clutch springs.
I wish i'd stayed in bed... Although, i did manage to get that mullered bolt out, borrowed a dremel and cut a slot in it.  |
| Section59 |
 Posted: 16:25 - 15 Sep 2011 Post subject: |
Well, some progress finally.
Got my refund from p-k-n on ebay for the seals, after having the cheek to ask me if i'd put em in the wrong way! So i sent em this pic to show how shite they were.
https://farm7.static.flickr.com/6068/6144210362_11a58c9da2_z.jpg
Got my NOS piston/rings in from the Netherlands and also bought a new wrist pin and little end bearing.
https://farm7.static.flickr.com/6083/6149855037_df1f66ccfb.jpg
Dry fitted it all together for now until i can get myself a gasket kit.
Am i right in thinking most of the gaskets from a TS125R will fit, besides base and head gasket? They look very similar...
Also got my new clutch springs and speedo cable through from wemoto (Excellent service. Will use again.) so those are all fitted. no pics sorry, although im sure you know what they both look like..
Removed front and rear wheel bearings, one of the back ones was a bitch and i ended up knocking the centre out then struggling for 15 min trying to remove the remaining outer ring.
https://farm7.static.flickr.com/6090/6149850563_b0e56ceac2.jpg https://farm7.static.flickr.com/6194/6150402466_2fc935d801.jpg
New bearings ordered and will be fitted asap once they arrive. These needed to be done anyway as i got an advisory for em at last mot.
Really want to get the wheels and hubs powdercoated as they look a bit manky but i dont have the cash for that at the min so going to leave them as is. Might do em after i've got it all back together and on the road.
Sooo, thats about it for now. Next update im hoping to have a nice swingarm and frame to show off, if i can afford it. |
| dangerousdave |
The last post was made 15 years, 25 days ago. Instead of replying here, would creating a new thread be more useful? |
