| Germ |
 Germ Trackday Trickster
| P.addy |
 P.addy Red Rocket
| Bezzer |
 Bezzer World Chat Champion
| Germ |
| chris-red |
| Bezzer |
| Bezzer |
 Posted: 13:56 - 05 Sep 2011 Post subject: Re: Just ordered a custom built(?) blue flame evo can |
| chris-red wrote: | Your bike is air cooled, all bikes have oil in to aid lubrication and a lot of modern bikes are water cooled with a rad at the front to cool the water that is pumped round the engine to remove heat.
Because your bike doesn't have water cooling the oil goes through a radiator to help keep temps down.
There are plenty of bikes that have oil coolers as well as a waterjacket doesn't make them oil and water cooled. |
Sorry but you're wrong.The Bandit and it's early GSXR parent engines are all deemed SACS motors (Suzuki Advanced Cooling System) and are oil/air cooled motors, to save me a lot of typing......
| Quote: | The SACS system uses high volumes of engine oil aimed at strategic points of the engine, like the top of the combustion chamber, which are not typically well served by air cooling alone. In order to provide enough oil for both cooling and lubrication, the system uses a double chamber oil pump, using the high pressure side for lubrication of the parts (crankshaft, connecting rods, valvetrain), while the low pressure, high volume side provides oil to the cooling & filtering circuit. The oil removes heat from hot engine parts through direct contact, is pumped away and subsequently routed through the oil filter, followed by routing through an oil cooler before being returned to the main sump |
____________________ I used to be indecisive but now I'm not quite so sure. |
| chris-red |
 Posted: 14:02 - 05 Sep 2011 Post subject: Re: Just ordered a custom built(?) blue flame evo can |
| Bezzer wrote: | | chris-red wrote: | Your bike is air cooled, all bikes have oil in to aid lubrication and a lot of modern bikes are water cooled with a rad at the front to cool the water that is pumped round the engine to remove heat.
So it has more oil and a bigger oil pump? I think most air cooled bikes have this compared to water cooled bikes. SACS is marketing speak. IMO it's like saying my KR1S doesn't have a Powervalve it has KIPS. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| P.addy |
 P.addy Red Rocket
| Bezzer |
| chris-red |
| Bezzer |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 15:27 - 05 Sep 2011 Post subject: |
What's the issue? If the rad has water in, its water cooled. Oil? Oil cooled. No radiator? Air cooled. To me the pic is an oil cooled bandit ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| chris-red |
| MaybeGuy |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| Germ |
 Posted: 21:39 - 05 Sep 2011 Post subject: |
Ok,now back on topic
.....what do you reckon to a Blueflame,oval carbon stubby with twin ports and all the components to fit it for £250?  |
| SuzukiTom |
 SuzukiTom Nova Slayer
| Germ |
 Posted: 23:16 - 05 Sep 2011 Post subject: |
Can comes with clamp,hanger,linkpipe and all the stainless nuts n bolts to do the job  |
| stonesie |
 stonesie World Chat Champion
 Posted: 23:45 - 05 Sep 2011 Post subject: |
Doesn't sound too bad, just remember the big pair of circlip pliers you will need to get the baffles out, you will loose 10 man points for each baffle you leave in  |
| Germ |
 Posted: 23:57 - 05 Sep 2011 Post subject: |
| SuzukiTom |
| Germ |
The last post was made 14 years, 213 days ago. Instead of replying here, would creating a new thread be more useful? |
