Engine making a very big clunk under load - cbr600f
c_dug
PostPosted: 22:17 - 05 Sep 2011    Post subject: Engine making a very big clunk under load - cbr600f Reply with quote
Hi guys,
Today my CBR started making a massive clunk and momentarily loosing power when the engine was under heavy load.
It's never done it before, and it was only effected by load, not revs.
Any suggestions of the cause? CCT or clutch would be my first guesses?
DrDonnyBrago
PostPosted: 07:52 - 06 Sep 2011    Post subject: Re: Engine making a very big clunk under load - cbr600f Reply with quote
c_dug wrote:
Hi guys,
Doubt it is the cct - that makes a metallic rattling noise and doesn't typicaly have any physical symptoms other than the noise unless it is so well and truly naffed the timing skips. CCT is also rev dependent.
Not sure as to what it is, but I would be fairly certain it isnt the cct, I don't think a cam timing issue caused by a severely busted CCT would act like that either.
Clutch sounds could be a worthwhile route of investigation.
PostPosted: 08:39 - 06 Sep 2011    Post subject: Reply with quote
Did it just drop out of gear. Was it just after a shift?
CBR's can sometimes drop out of 6th if you don't shift positively enough.
DrDonnyBrago
PostPosted: 08:50 - 06 Sep 2011    Post subject: Reply with quote
I can second that ^^^^^. First time it happened I thought my chain had come off Laughing .
Benson_JV
PostPosted: 10:18 - 06 Sep 2011    Post subject: Reply with quote
Thirded. Laughing
I coasted to the side of the road with my left indicator on tapping my brake light as a sort of hazard light.
PostPosted: 10:26 - 06 Sep 2011    Post subject: Re: Engine making a very big clunk under load - cbr600f Reply with quote
c_dug wrote:
Hi guys,
Reading that it sounds like it happened more than once. If it's clunking under load in a particular gear and it does it all the time getting steadily worse then it's either a worn out front sprocket or gear dogs.
Check the sprocket and hope it's knackered.
Mrjoolz
PostPosted: 10:29 - 06 Sep 2011    Post subject: Reply with quote
could be rear sprocket if chain jumping, off teeth.
:o(
Germ
PostPosted: 10:33 - 06 Sep 2011    Post subject: Reply with quote
Silly question time.....checked the chain tension,could be as simple as it being too slack and trying to slip off front or rear sprockets?
Fizzer Thou
PostPosted: 12:17 - 06 Sep 2011    Post subject: Reply with quote
Sounds like it is going to be an engine out and strip off the bottom crankcase to inspect the gearbox if the chain and sprockets are okay.
Always have a 'Plan B'
c_dug
PostPosted: 19:05 - 06 Sep 2011    Post subject: Reply with quote
None of that sounds right to me.
The bike definitely didn't skip out of gear, I backed off the power when I heard the noise but when I throttled back on the power was straight there, no faffing with the gear lever needed.
The Chain and sprockets (front and back) are less than 5000 miles old and are well adjusted, it was the first thing I checked when I got to work as I recently changed the rear tyre, my first though was "oh fuck, I didn't tighten something up!"
I don't think it's the gearbox, the bike has done 43,000 miles but the gearbox is silky smooth in all gears and almost never skips out of gear.
I rode the bike back from work the other night and then in and back again today, to me the clutch feels fine. Even if it was the clutch, what would cause those symptoms? Surely the only bad thing that would happen with a warn clutch under load would be it slipping. I wasn't changing gear at the time of the noise or anything.
Just to clarify, it happened for the first time when I was overtaking a lorry down some lanes, at about 7krpm in 3rd gear. I went through a village and as I came out the other side I left the bike in first gear all the way up to the redline, it didn't do it again. So I slowed back down, put the bike in second from about 20mph and full throttled, it made the noise again, this time at a lower rpm and speed. Both of the times it made the noise the bike was well in gear. Both times the engine was under load. Both times it was in a different gear at different RPM.
To me this eliminates it being the gearbox for certain. I know it wasn't the chain and sprockets. I can't think of how the clutch could cause the described symptoms.
My CCT has been rattling for quite a while now, probably way over 10,000 miles, but it was never made so much noise that I have considered it a problem. That said, I was going to change it this Saturday anyway. If the Cam chain had skipped would the bike still be running fine? I would have thought it would cause it to run really rough or make the valves hit the pistons?
Any ideas?
PostPosted: 04:10 - 07 Sep 2011    Post subject: Reply with quote
c_dug wrote:
Any ideas?
Yeah - your gearbox is f'ked. Classic jumping of the dogs.
Just so you know, jumping gear dogs doesn't knock the bike out of gear nor into another gear. What it feels like is someone giving the engine a good hard crack with a heavy hammer that you can feel through the seat and bars when under power.
DrDonnyBrago
PostPosted: 07:26 - 07 Sep 2011    Post subject: Reply with quote
It would run rough at the very least.
I think pete has nailed it tbh.
The pic below is a random gear and dog setup.
https://www.dansmc.com/dogs.jpg
The little lumps are the dogs, these fit into the recesses on the gear next to it, if the dogs are worn they do not have a nice sharp right angle at the edge, instead they are rounded off or even sloped as is the edge of the hole. Under load, because there are not two nice sharp edges the gears dogs can come out of the recesses and clunk into the next recess along with a big thud and a momentary loss in power.
finpos
PostPosted: 07:40 - 07 Sep 2011    Post subject: Reply with quote
I'd go with the dogs idea as well, except for the fact it's happening in different gears. If it were worn dogs I'd expect it to happen in the same gear all the time (and quickly getting worse as the case hardening gets knocked off the gears with every clunk). The feeling is exactly like a chain slipping (if you've ever ridden a knackered pushbike) and it's often mistaken as such. (Motor)bike chains have to be completely and obviously bolloxed for this to happen, though.
Which may throw you a bit of a bone in that you're not getting it into gear quite as well as you think you are, and that's often down to a partially seized gear linkage.
f.
c_dug
PostPosted: 09:15 - 07 Sep 2011    Post subject: Reply with quote
Perhaps is was in the same gear then, I'll try again on the way to work today.
I assume it's a bit of a bastard job to fix? I've never delved as deep as the gearbox before, only gone as far as top end off, or sump plate off.
finpos
PostPosted: 10:02 - 07 Sep 2011    Post subject: Reply with quote
Engine out, you'll need 2 new gears (£50 -£100 each), gaskets and a manual to tell you how to build up the gear shafts. If you are unlucky you may need a press. On a 50,000 mile bike every part will be worn to it's tolerance limit so you may need to buy more stuff (shims, bearings, thrust washers...) as you go along.
...and that's if you can get into the box from the bottom of the engine. If you need to strip it down from the top, just buy a new engine, it will skint you rebuilding it.
If the dogs have indeed failed it's normally a common failure on particular bikes (i.e. gear X fails on model YYYYY) so gogle may help you out.
f.
c_dug
PostPosted: 10:19 - 07 Sep 2011    Post subject: Reply with quote
Can I not just buy this?
Don't suppose anybody near Essex wants to lend me a workshop Laughing
finpos
PostPosted: 10:26 - 07 Sep 2011    Post subject: Reply with quote
Yep, of course (although I worry about parts described with question marks Smile ). Do a bit of research, though - don't buy it if it's a common failure because you will probably be buying more broken parts, and find out how much of the engine needs to come apart for you to fit the new bits - once again, stripping and rebuilding a high mileage 4-pot from the top is simply not worth it.
You probably only need the input shaft, btw.
f.
Germ
PostPosted: 10:27 - 07 Sep 2011    Post subject: Reply with quote
Would it be worth considering a reconditioned engine and/or gearbox?I know many engineering places will do a part-ex for your old bits and knock some cash off the recon one.
Not sure if there's any bike places that do the same though,I'm just thinking out loud here.
PostPosted: 17:05 - 07 Sep 2011    Post subject: Reply with quote
https://www.cmsnl.com/honda-cbr600f-1993-spainkph_model2285/partslist/E__1500.html
Parts 17 and 6 are 2nd gear. 175 Euros from that place but Dave Silver might be cheaper. Either that or get them out and have at them with a dremel and a drum stone. I can't grind those the way I did Binge's but I could do a pretty good job by hand.
c_dug
PostPosted: 23:00 - 07 Sep 2011    Post subject: Reply with quote
Confirmed it was just second gear on the way to work today, avoiding using second as much as possible from now on! I assume it's safe enough just to ride around it for the time being until I can get the bits to fix it?
PostPosted: 03:07 - 08 Sep 2011    Post subject: Reply with quote
Yes, no harm will be done if you avoid making it jump.
The last post was made 14 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.65 - MySQL Queries: 15 - Page Size: 116.01 Kb
