| c_dug |
 c_dug Super Spammer
| DrDonnyBrago |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 08:39 - 06 Sep 2011 Post subject: |
Did it just drop out of gear. Was it just after a shift?
CBR's can sometimes drop out of 6th if you don't shift positively enough. ____________________ My Flickr |
| DrDonnyBrago |
| Benson_JV |
 Benson_JV World Chat Champion
| Mrjoolz |
 Mrjoolz Brolly Dolly
| Germ |
 Germ Trackday Trickster
| Fizzer Thou |
| c_dug |
 c_dug Super Spammer
 Posted: 19:05 - 06 Sep 2011 Post subject: |
None of that sounds right to me.
The bike definitely didn't skip out of gear, I backed off the power when I heard the noise but when I throttled back on the power was straight there, no faffing with the gear lever needed.
The Chain and sprockets (front and back) are less than 5000 miles old and are well adjusted, it was the first thing I checked when I got to work as I recently changed the rear tyre, my first though was "oh fuck, I didn't tighten something up!"
I don't think it's the gearbox, the bike has done 43,000 miles but the gearbox is silky smooth in all gears and almost never skips out of gear.
I rode the bike back from work the other night and then in and back again today, to me the clutch feels fine. Even if it was the clutch, what would cause those symptoms? Surely the only bad thing that would happen with a warn clutch under load would be it slipping. I wasn't changing gear at the time of the noise or anything.
Just to clarify, it happened for the first time when I was overtaking a lorry down some lanes, at about 7krpm in 3rd gear. I went through a village and as I came out the other side I left the bike in first gear all the way up to the redline, it didn't do it again. So I slowed back down, put the bike in second from about 20mph and full throttled, it made the noise again, this time at a lower rpm and speed. Both of the times it made the noise the bike was well in gear. Both times the engine was under load. Both times it was in a different gear at different RPM.
To me this eliminates it being the gearbox for certain. I know it wasn't the chain and sprockets. I can't think of how the clutch could cause the described symptoms.
My CCT has been rattling for quite a while now, probably way over 10,000 miles, but it was never made so much noise that I have considered it a problem. That said, I was going to change it this Saturday anyway. If the Cam chain had skipped would the bike still be running fine? I would have thought it would cause it to run really rough or make the valves hit the pistons?
Any ideas? ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
 Posted: 04:10 - 07 Sep 2011 Post subject: |
Yeah - your gearbox is f'ked. Classic jumping of the dogs.
Just so you know, jumping gear dogs doesn't knock the bike out of gear nor into another gear. What it feels like is someone giving the engine a good hard crack with a heavy hammer that you can feel through the seat and bars when under power. ____________________ a.k.a 'Geri'
| DrDonnyBrago |
| finpos |
 finpos World Chat Champion
| c_dug |
 c_dug Super Spammer
| finpos |
| c_dug |
 c_dug Super Spammer
 Posted: 10:19 - 07 Sep 2011 Post subject: |
Can I not just buy this?
Don't suppose anybody near Essex wants to lend me a workshop  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| finpos |
 Posted: 10:26 - 07 Sep 2011 Post subject: |
Yep, of course (although I worry about parts described with question marks ). Do a bit of research, though - don't buy it if it's a common failure because you will probably be buying more broken parts, and find out how much of the engine needs to come apart for you to fit the new bits - once again, stripping and rebuilding a high mileage 4-pot from the top is simply not worth it.
You probably only need the input shaft, btw.
f. |
| Germ |
 Posted: 17:05 - 07 Sep 2011 Post subject: |
https://www.cmsnl.com/honda-cbr600f-1993-spainkph_model2285/partslist/E__1500.html
Parts 17 and 6 are 2nd gear. 175 Euros from that place but Dave Silver might be cheaper. Either that or get them out and have at them with a dremel and a drum stone. I can't grind those the way I did Binge's but I could do a pretty good job by hand. ____________________ a.k.a 'Geri'
| c_dug |
 c_dug Super Spammer
 Posted: 03:07 - 08 Sep 2011 Post subject: |
Yes, no harm will be done if you avoid making it jump. ____________________ a.k.a 'Geri'
The last post was made 14 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
