| Nope. |
 Nope. World Chat Champion
 Posted: 16:50 - 05 Sep 2011 Post subject: Ok guys, im stumped. Sachs XTC Woes... |
Hey all, Ive got a problem which I cant seem to fix. I Acquired a Sachs XTC 125 4 Stroke about 2 months ago with a view to fixing it and using it through winter then letting my mate learn on it. Looking at it, it looked an easy fix. It ran, but as soon as you touched the throttle It would just cut out. Part of the airbox was missing so Fair enough I thought too much air, Ill have it then just get the part for the airbox.
So, I got the bike and sure enough I obtained the part for the airbox. I fitted the airbox and the filter and sure enough the problem persisted. It happily revs up on choke, but touch the throttle and it dies. Ive stripped and cleaned the carb, Ive cleaned the (plastic) tank, replaced the airbox inlet and still the same problem.
Ive just had the carb out and ive put gasket paste all around the inlet manifold and carb, all around the airbox manifold, around the air filter join and ive put a new gasket around the air intake part of the airbox. Start it up and sure enough the problem persists. If I take the airfilter off and the air intake box off and use my hand then I can get it to rev up on the throttle but it doesnt de-celerate again. It revs to about 5-6k and then stays there. If I remove my hand it drops right down again and then when I though the throttle it cuts out
So, Id like to get this bike ready for october, Ideas please guys. I could just keep stripping it and replacing parts until it works but id rather just find the problem the quick and easy way. ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
Current: 2011 Yamaha XT660Z Ténéré, 2003 Yamaha YZR-R1 5PW (In Build), 2009 Kawasaki ZZR1400 |
| pepperami |
 pepperami Super Spammer
 Posted: 18:43 - 05 Sep 2011 Post subject: |
Welcome to my club of pain and fail , If you look through the old threads in workshop you`ll know that I`ve been through this very same mangle!
In the beginning once I finally got a spark and the starter motor to turn over, the damm thing would`nt start .
I did`nt have acess to sonic cleaning but I did have access to high pressure air and solvents (not at the same time though ), so that`s how I cleaned my carb at first.
That was a bit better but still I could`nt get it to tick over or rev properly and it would die
Off came the carb many times trying to get it right, cleaning it a few times made it a bit better but not right.
So new jets and a new diaphram= a bit better but still not right!
New fuel line and cleaning out the tank = a bit better.
Look at where the choke cable goes into the carb and the slider? there as mine had a whole load of nasties (strange gunk) there?.
I have also found that mine hates being on it`s sidestand and sometimes the floats will stick if it has been on the sidestand for long periods.
I now have a small piece of tube that fits the hole (there`s a screw in it) at the bottom of the float bowl.
So now if I have an issue with the carb, I put that tube in and give the carb a blow BEFORE I start to pull it apart, as sometimes it can just be a bogie in the carb causing problems and this can blow them out.
Spiders webs and earwigs in the airbox dont help matters either
I also found that once the fresh new petrol got through things improved . ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Drake |
 Drake World Chat Champion
 Posted: 19:14 - 05 Sep 2011 Post subject: |
sound like if its running with choke its running too lean when off choke? well sound like that to me ____________________ was: derbi senda, aprilia sx125, nsr250 mc16, cagiva mito, cb600 hornet now: mk1 bandit, KR1S, landrover series 3 light weight 2.5 petrol, 5speed box |
| Souleh |
 Souleh Trackday Trickster
 Posted: 19:20 - 05 Sep 2011 Post subject: |
Carb.
Mine was the exact same.
Get it back out and stripped down!!
Mine did this alot  |
| Asimo |
 Asimo Spanner Monkey
| Souleh |
| Nope. |
 Posted: 18:18 - 06 Sep 2011 Post subject: |
Fixed it
Stripped and cleaned the carb again, used 6 bar compressed air on the jets and body and now shes running pretty well.
Couple of kinks to sort out and then she'll be ready to go  ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| pepperami |
 Posted: 18:43 - 06 Sep 2011 Post subject: |
| Souleh |
 Posted: 23:07 - 06 Sep 2011 Post subject: |
Oh there easy to fix! Its just they need regular attention and endless heartache.
Id still buy another one mind, got a soft spot for them
Id prob go OEM teeth or +1 or +2
Its a city bike imo |
| Nope. |
 Posted: 23:42 - 06 Sep 2011 Post subject: |
Right, now she's running onto the next bit. The side stand is a bit, um, broken. When up it is in contact with the chain and rubs against it when the chain is moving. This is obviously bad and needs to be rectified, there appears to be a lot of space in the side stand bracket and im just intending to fill the gap with some washers. Does anybody else have experience of such an issue? Also, the bike leans over very far on the stand, further then id expect it too, is this common with the sachs? ____________________ Former: Derbi GP1 50, Sachs XTC 125, Suzuki GSXR 400 GK73A, Kawasaki ZX7R, Suzuki DR250, Yamaha RD350
| Asimo |
| pepperami |
 Posted: 17:43 - 07 Sep 2011 Post subject: |
PM and pics sent Mr Computid
Please let me know that you got them as I`m a bit of a rookie when dealing with pictures ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
The last post was made 14 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
