My aprilia rs 125 HELP!!
Benjii25
PostPosted: 19:53 - 06 Sep 2011    Post subject: My aprilia rs 125 HELP!! Reply with quote
Hello, I have an aprilia rs 125 bought it a few days ago, running fine, then yesterday i was sat at traffic lights ready to go then it cut out and just completely lost power, It started again okay but it just keeps cutting out when I slowely release the clutch... Its a 2002 Aprilia RS 125 GP-01 FACTORY DERESTRICTED... Its done 4000 miles... I have changed spark plug three times using br10 eg and have checked fuel, cleaned air filter and fuel filter... I can get it going if I give it about 8,000 revs but then i look like a twat because its revving so high when i shouldn't be...
If anyone could help i would be really grateful... Will do anything to get her back on the road Sad
Also when i lean her to the side the oil light comes on why does it do this?
Please help me!!
Ben
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Benjii25
PostPosted: 20:30 - 06 Sep 2011    Post subject: Reply with quote
Dr. Quack wrote:
Sounds like the power valve is stuck open. I think the blade is positioned above the exhaust header, the solenoid actuator pulls the cable to release the blade and sometimes they stick open causing low power whilst the revs are low.
Could be that the carb needs cleaning if the solenoid actuator is working properly.
At 4000miles (if the bike has been de-restricted from new), it won't be far off needing a top end rebuild, Cheap re-hone and a 10th milli oversized piston kit. £100 job if you can do it your self.
Thanks, I will have a look tomorrow where is the exhaust header? Sorry i'm new to this haven't had the bike long... The bike hasn't been driven for about 3 years, but he had it serviced every year and i have got the recipts of the work carried out,
Ben
Livefast123
PostPosted: 20:57 - 06 Sep 2011    Post subject: Reply with quote
As the bike has been stood for a long time then the jets in the carb probably need a good clean out due to having stale old petrol in them. It's an easy job, whip the carb off and clean the said items with petrol and compressed air.
Have you checked your 2 stroke oil level, usually it's low when the bikes leant over and it comes on, only top quality synthetic stuff for the RS.
I would run a compression test just to see what kind of condition the top end is in, I wouldn't expect it would need one after 4000 miles but you never know and could be causing issues with low end power. BTW you need to rev a 2 stroke 125 to pull off.....don't be scared Wink
Current ride - Yamaha MT-07
Benjii25
PostPosted: 21:38 - 06 Sep 2011    Post subject: Reply with quote
Thanks everyone i will try it all tomorrow after work and keep you updated!
Ben
WannaBeDude
PostPosted: 05:00 - 07 Sep 2011    Post subject: Reply with quote
He could of said your mistaken a bit ' nicer ', but your advice was OTT to say the least.
Service schedule gives the rebuild intervals, but better still, to use the engine compression readings to see if it's due new rings, which is around 5000 miles
As for the piston that should be good for 10000 miles est as i'm just going off mine which is highly strung italian 2T aswell.
Reading the ops post, sounds like he's not used to the revs needed in pulling off, and is stalling it ! Smile but as no one else has said that i doubt it. Rolling Eyes
WannaBeDude
PostPosted: 05:06 - 07 Sep 2011    Post subject: Reply with quote
Be interested to hear why 4000 miles is near a top end rebuild under normal circumstances ie properly maintained, not thrashed to death from new, run in etc. Rolling Eyes
WannaBeDude
PostPosted: 05:37 - 07 Sep 2011    Post subject: Reply with quote
Yes i'm aware of the above, as having bought a 2T from new, i've spent a lot a time learning what not to do.
Like don't buy an italian 2T if you want reliability, even from new ! lol
I have a tester on order as mines done 5500 KM.
The point Chris was making was your initial post just said 4000 rebuild needed soon, without stating what you have.
You first advice should of been to get a tester, as bike is new to him, as the psi No will tell him all of what you have said there or there abouts,
So in reality, theres a chance he could need an early rebuild but with facts known he could go another 4000 miles or more. Though perhaps rings needed in between.
Idea
SuzukiTom
PostPosted: 11:09 - 07 Sep 2011    Post subject: Reply with quote
if you don't know what your talking about.
don't post.
+1 i got we had one that was fine till 14k
compression test if in doubt
SuzukiTom
PostPosted: 11:12 - 07 Sep 2011    Post subject: Reply with quote
also compression tests: ideally the engine should be warmish and you need to pin the throttle wide open to test. make sure your not in contact with the plugs either!"
SuzukiTom
PostPosted: 13:04 - 07 Sep 2011    Post subject: Reply with quote
Livefast123 makes a good point about carbs. on CV carbs if a pilot jet gets blocked it wont idle very well if at all. could be a carb cleaning effort, thats not uncommon.
its not scientific but with eveything in situ you could pop the carb float bowl off and have a nose about to see if you see any dirt, that doesnt mean theres not somthing stuck in the jet however, if your going to remove hets its best to have the carb off the bike to get it up the light.
Benjii25
PostPosted: 18:36 - 07 Sep 2011    Post subject: Reply with quote
Thanks everyone she is knowing running good, still a bit worried that she might cut out again but I will gain trust in her.
I took the carb off had a good clean blew threw all the jets put it all back together, also gave everything a really good clean.
Thanks for everyones help Smile
Ben
The last post was made 14 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 90.7 Kb
