RED X
Mrjoolz
PostPosted: 13:15 - 07 Sep 2011    Post subject: RED X Reply with quote
Can you put Red X in bikes to clean engine etc, or would it do more harm then good ?
Nope.
PostPosted: 13:20 - 07 Sep 2011    Post subject: Reply with quote
You can, but it does sweet F all. Just search for redx and I'm sure you'll come across the many many threads on the subject.
Mrjoolz
PostPosted: 13:29 - 07 Sep 2011    Post subject: Reply with quote
ok ta. Just wondered if it would clean out bike, to make it idle easier etc.
fatpies
PostPosted: 13:34 - 07 Sep 2011    Post subject: Reply with quote
Oh it has an effect alright, it lightens your wallet, and causes something called Plac-e-bo effect. Very Happy
DrDonnyBrago
PostPosted: 13:41 - 07 Sep 2011    Post subject: Reply with quote
Redex gets a bit of a hard time on here, it has it's uses, just those uses don't extend to putting it in your fuel and expecting it to fix anything. On the other hand it also wont cause any harm.
What it IS good for is using it undiluted to remove petrol varnish residues that have been caused by stale fuel.
As for dumping it in your tank and expecting it to fix anything - no.
Try balancing your carbs/throttle bodies if it is idling poorly.
PostPosted: 13:44 - 07 Sep 2011    Post subject: Reply with quote
I've used Redex on a number of bikes and it has had the effect of approximately the square root of bog all. If the carbs needed cleaning, the only way to clean them is to take them off the bike and clean them properly with carb cleaner and compressed air.
Redex is a waste of money IMO. I've heard the odd bit of anecdotal evidence to say that the diesel redex stuff can help diesel engines, but never petrol.
SuzukiTom
PostPosted: 15:58 - 07 Sep 2011    Post subject: Reply with quote
its never done much for me either, if your hoping to clean a carb out as above...roll your sleaves up and pull them out and give them the deep clean!
Andy_Pagin
PostPosted: 16:23 - 07 Sep 2011    Post subject: Reply with quote
I did the fabled redex-decoke once on my Landrover, squirt redex in each cylinder, leave overnight, spin the engine without plugs to clear the redex out, then plugs back in & fire her up.
It was a cold damp November morning, the cloud of white exhaust smoke was spectacular in its density, volume and longevity.
My house disappeared from view.
I quickly jumped in & drove up the street to clear her out, leaving a trail a Boeing 747 would have been proud of.
Made bugger all difference to anything, the head was still nicely coked up when I whipped it off the next week.
dudders7
PostPosted: 21:33 - 07 Sep 2011    Post subject: Reply with quote
Redex works well in two strokes, a real noticeable difference on a small one. Don't notice much in 4 strokes. Upto you however probably best balancing the carbs and cleaning them etc.
Riding in the sun in Australia on a 04 Worked ZX10R along with a fleet of other crazy toys
andys675
PostPosted: 22:02 - 07 Sep 2011    Post subject: Reply with quote
put some in my cb250rs as a kid back in 86-87, must have put too much in but it cleaned all the carbon off the back off the valves, only thing was the carbon was the only thing sealing the valves and had to grind them back into the seats after.............
temeluchus
PostPosted: 22:55 - 07 Sep 2011    Post subject: Reply with quote
its mostly good for shifting water out of fuel as it is mostly paraffin.
cheaper just to pour some paraffin or meths in your tank for the same effect.
R6 Wilson
PostPosted: 16:47 - 08 Sep 2011    Post subject: Reply with quote
It seemed when I used Redex on my Speedfight that was running rich/fouling that it temporarily solved the problem, apart from that I doubt it's worth the money :l
♥ YZF-R6 '05 ♥
Time is money so I stay late
The last post was made 14 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 72 Kb
