Gilera Coguar 125 engine cuts out sometimes
Pieter
PostPosted: 10:46 - 07 Sep 2011    Post subject: Gilera Coguar 125 engine cuts out sometimes Reply with quote
Hi,
I have a weird problem, when I'm riding with my bike, the engine suddenly cuts out..
So when I'm driving at 5th gear, it cuts out, so I switch to 4... switch to 3, and then it starts again!
It also happens when I'm at the traffic lights, but then I wait for 10 seconds and the engine starts (off cours after hitting the starter)
This happens 1 time in 2 hours riding.. EVERY DAY
I heard that the electronics of the bike are terrible.. Is it the electronics?
I apologize for my bad English, I'm from Belgium, and I'm hoping that you can help me!
Oh and the spark plug is changed, so that's not the problem
finpos
PostPosted: 11:20 - 07 Sep 2011    Post subject: Reply with quote
The very first thing I would look at is the sidestand. It will have an electrical switch which for safety will stop the engine if the stand is down. Sometimes the stand is loose or the switch is stiff so it can cause the engine to stop when braking or cornering.
Start the bike, hold it upright with the stand up, then push the stand down 1cm with your hand - see if the engine stops.
f.
Pieter
PostPosted: 11:37 - 07 Sep 2011    Post subject: Reply with quote
Thank you very much for your reply, finpos!
I already tought that, but then I normally should have seen the red light appering on the dash.. But I'll check it when I'm home and let you know!
Odie
PostPosted: 20:23 - 07 Sep 2011    Post subject: Reply with quote
Common problem with the cougar, my wife has one and this some-times plays up, undo it, clean with an electrical cleaner and put back together, it dont help living under the chain and getting covered in crap!
Option, plastic bag and 2 cable ties, undo the connector, place plastic bag with a hole in the bottom over cable and feed through the hole in the bottom and the top, join up the connector and and at the loose bag ends cable tie them tight, stops more crap getting on the connector.
odie
Pieter
PostPosted: 11:36 - 08 Sep 2011    Post subject: Reply with quote
@Odie
You mean the sidestand connector right?
I'll clean that up and do what you said!
Yesterday I drove the bike again and there was no problem this time..
Today I'm gonna check and I let you know
Thanks for the help
Odie
PostPosted: 18:33 - 08 Sep 2011    Post subject: Reply with quote
Pieter wrote:
@Odie
yes mate, also the bad vibes your getting, check the engine mount bolts are tight, my wifes had worked loose and was causing the same thing.
Odie
The last post was made 15 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 47.53 Kb
