Chain and Sprocket Set what do you reckon?
biker58
PostPosted: 18:48 - 08 Sep 2011    Post subject: Chain and Sprocket Set what do you reckon? Reply with quote
Ok as each month (if needed) i intend to service my bike somehow and next month it will be the chain and sprocket that gets changed.
What tools will i require?
Also can any fellow GSX600F riders let me know what they pay for chain and sprocket set?
what would a 45 toothed rear sprocket, 14 toothed front sprocket and a IRIS 530-112 X-Ring (Gold) Chain cost?
1995 Suzuki GSX600F rider
PostPosted: 19:01 - 08 Sep 2011    Post subject: Reply with quote
With the pictures I have seen of IRIS chains, likely cost would be a new set of crankcases Wink .
A kit from B&C seems to be just under £100.
biker58
PostPosted: 19:05 - 08 Sep 2011    Post subject: Reply with quote
Thanks
You wouldn't recommend an IRIS chain then? lol
I have been quoted £150 for the set with free delivery and thought it seemed a bit steep, i'm new to actually buying bike stuff to sort myself so definitely keeping my eye out for the p*ss takers
PostPosted: 19:43 - 08 Sep 2011    Post subject: Reply with quote
Wouldn't recommend an Iris chain.
£150 sounds a bit much. I would want it fitted for that much and wouldn't regard it as a cheap set then.
Which exact model of Teapot do you have?
biker58
PostPosted: 20:11 - 08 Sep 2011    Post subject: Reply with quote
It's a 95 model, i have tried to upload a picture but always get told the file is too large.
I was thinking around £100 would be an ok sort of price
Fizzer Thou
PostPosted: 21:00 - 08 Sep 2011    Post subject: Reply with quote
I would suggest keeping away from Regina chains as well.
For longevity I recommend a D.I.D. chain with decent sprockets like those from https://www.bandcexpress.co.uk/
The last few times that I have fitted new chain and sprockets for people I have used a Renthal front and a https://www.supersprox.com/uk/ rear with the DID chain.This rear sprocket has the lightness of the Renthal alloy rear with the longevity of a steel.Saying that I have had an alloy rear Renthal on my R1 for over 18,000 miles and shows little or no wear.
Always have a 'Plan B'
0l0dom0l0
PostPosted: 21:26 - 08 Sep 2011    Post subject: Reply with quote
Again, stay clear of iris. A friend snapped an iris chain on a 50cc ffs Surprised.
I wouldn't expect a DID chain and sprockets to cost more than around £100.
Have you checked Wemoto?
biker58
PostPosted: 22:03 - 08 Sep 2011    Post subject: Reply with quote
cheers for the heads up on IRIS guys, i'll check out all the ones you have all mentioned and hopefully get a set for about £100.
What tools will i need to change chain and sprocket?
neil.
PostPosted: 06:47 - 09 Sep 2011    Post subject: Reply with quote
Forget IRIS - even my old 125 managed to snap one after 7'000 miles. It was properly maintained as well.
yen_powell
PostPosted: 07:53 - 09 Sep 2011    Post subject: Reply with quote
DID x-ring chain.
You will need a chain splitter, a chain press tool and a riveter. You can buy kits with a tool that does all of these. I saw a Laser version in a Machinemart catalogue the other day, but the same set seems to be about with different manufacturers names on them.
XT1200Z and a DR350 in bits
DrDonnyBrago
PostPosted: 08:19 - 09 Sep 2011    Post subject: Reply with quote
IRIS is shit.
Don't know what year your bike is but here are a few suggestions:
Normal people buy this one:
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CSK3124VX
Likely the cheapest you will find a DID chain and sprocket kit.
Alternatively, if you like your bling buy one of these (different kits for different years):
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CSK3504VGB
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CSK3519VGB
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CSK3124VGB
You will struggle to beat those prices, I have the CBR kit, excellent quality, good service etc etc (I should get paid commission the amount I pimp that site).
Also consider the chain tool:
https://bikespeeduk.com/epages/steer2916.sf/en_GB/?ObjectPath=/Shops/steer2916/Products/CHAINTOOL
twfbr
PostPosted: 23:18 - 09 Sep 2011    Post subject: Reply with quote
Yea iris sucks lol try looking at supersprox their stealth is both steel and alloy witch wears really good and i believe that the sell RK chains in a full kit. And supersprox rear sprockets have a life time warranty when you buy the full kit from them directly witch to me is way worth the money last longer and lifetime cant beat it i think.
twfbr
PostPosted: 23:22 - 09 Sep 2011    Post subject: Reply with quote
as for tools it depends on your bike most likely you will need wrenches for the rear wheel to take it off and different ones to take off your front and rear sprocket and depending on ur chain you will need a chain breaker and or pliers to take off the master link
Fizzer Thou
PostPosted: 02:07 - 10 Sep 2011    Post subject: Reply with quote
Most big bike chains come with a soft link as standard.So a little more than a pair of pliers will be needed to remove this.I have found the easiest way is to grind off the heads of the soft link.This link is noticeable by the differant rivets used to hold in place the outer plate.Once the outer ends ofthe soft link are removed,it is quite easy to press out the pins so that there is sufficient for the outer plate to be removed.
If you do not have the right tools I am near to Bexleyheath/just off the A2 so you can always give me a PM and I can see if I can help.I am not a dealer - just an enthusiastic biker willing to help.
biker58
PostPosted: 17:50 - 10 Sep 2011    Post subject: Reply with quote
Fizzer Thou, thanks for the offer very kind, i'll more thank likely buy the tools required as i'll be attempting most of the jobs my self and will need them in the future anyway. Thumbs Up
Plenty of different chains and companies to look in to thanks guys.
Walloper
PostPosted: 18:22 - 10 Sep 2011    Post subject: Reply with quote
DID are good and a lot of OEM use them as standard fit.
Sometimes just a cheap to find a decent bike shop who don't charge the erf. And have them do it. No need for chain spliters and all that shite then.
By the time you pay for a proper spliter the garage labour and your hassle to do it will be saved.
But if you fancy having a go, Just do it. Smile
biker58
PostPosted: 21:04 - 10 Sep 2011    Post subject: Reply with quote
Very Happy I'll give it a go i reckon, first time round i'll probably cause myself hassle and it will work out expensive first time round as i will have to pay for tools too but will save me money in the long run and i'll get satisfaction from doing it myself.
I'd like to find a small local garage that are relatively cheap but after getting quoted stupid prices from a few garages for simple jobs i resent going to them now.
Easy jobs that will take experienced guys an hour or 2 will probably take me all day but it's the only way i will learn. Laughing
DrDonnyBrago
PostPosted: 22:09 - 10 Sep 2011    Post subject: Reply with quote
That's the best attitude to have mate.
As above though, if you are anywhere near newport I can lend a hand.
PostPosted: 22:53 - 10 Sep 2011    Post subject: Reply with quote
Also happy to help if you are close to Maidstone in Kent Thumbs Up
biker58
PostPosted: 10:57 - 11 Sep 2011    Post subject: Reply with quote
^^^ Thanks for the offers of help guys!^^^
I am unable to rate any more posts today. (if you are bothered lol)
Might take you up on the offer of help 1 day, you might regret it though! Confused Laughing
The last post was made 15 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 109.72 Kb
