New four stroke engine.
sidewinder
PostPosted: 22:40 - 09 Sep 2011    Post subject: New four stroke engine. Reply with quote
https://www.stumbleupon.com/to/2kxLnu/www.new4stroke.com/t:4e6a95258a770;src:all
Enjoy Very Happy pretty interesting reading
Frost
PostPosted: 23:00 - 09 Sep 2011    Post subject: Reply with quote
Added complexity for what benefit? Also combustion area shape doesn't look too efficient.
hmmmnz
PostPosted: 04:15 - 10 Sep 2011    Post subject: Reply with quote
very similar to the bear head, but using pistons instead of sliding ports,
as for complexity its no more complex than 4 valves a cam and rocker arms,
less complex if anything
the humans are dead
I kick arse for the lord
LordShaftesbu...
PostPosted: 09:59 - 10 Sep 2011    Post subject: Reply with quote
This new concept eliminates the most complicated mechanism in the combustion engine: the head and valve train.
The idea is to replace the camshaft with a crankshaft and replace the valves with pistons. By doing this, the inventor, Andrew Feliks, created a new and very simple four stroke engine.
In this invention the piston with compressions rings slides in a cylinder which has a side port. A pair of these pistons and cylinders replaces the intake and exhaust valve.
The Artist
PostPosted: 10:01 - 10 Sep 2011    Post subject: Reply with quote
+1
No way that is going to be as efficient as modern common rail diesels.
Frost
PostPosted: 13:32 - 10 Sep 2011    Post subject: Reply with quote
Instead of all that you now have twice as many cranks, 3 times as many big end bearings, 3 times as many piston rings potentially giving 3 times the oil loss with 3 times as many cylinders that can become oval.
Surely it only acheives the same ting as a split single but with aditional complexity?
hmmmnz
PostPosted: 10:29 - 12 Sep 2011    Post subject: Reply with quote
i didnt say it was a good idea, but its relitivly simple,
not as simple as the bear head though
the humans are dead
sniff6
PostPosted: 16:53 - 12 Sep 2011    Post subject: Reply with quote
Is this the Beare Head??? A six stroke engine!!!
https://upload.wikimedia.org/wikipedia/en/thumb/3/38/M4%2B2anim.gif/300px-M4%2B2anim.gif
I'd never heard of it TBO
'Great Britain' Love it https://img43.imageshack.us/img43/3967/67004290.gif or Leave it
chrisw
PostPosted: 22:01 - 12 Sep 2011    Post subject: Reply with quote
That looks just as inefficient as the one above. If you watch the rotation of the main crank, just at the point it will be creating peak torque, the smaller (right-hand) piston is moving away, increasing the volume of the combustion chamber. Confused
The Artist
PostPosted: 11:27 - 13 Sep 2011    Post subject: Reply with quote
Yeh, massive fail there. Unless the cranks are linked (obviously through some reduction gear).
sniff6
PostPosted: 15:41 - 13 Sep 2011    Post subject: Reply with quote
Found this..The guy himself to explain it to you.https://www.ftn2day.nl/images/icon_eek.gif
https://www.youtube.com/watch?v=-PW5Y7v00Xo
chrisw
PostPosted: 16:58 - 13 Sep 2011    Post subject: Reply with quote
It explains how it works but focuses on energy required to open the valves. That's just one part of how efficient an engine is. How about the 'blow-past' of the additional cylinder, additional weight and rotational masses and as mentioned the changing size/shape of the combustion chamber.
And with bikes, that design makes the engine taller, adding mass high up in the frame exactly where you don't want it.
Great idea, but flawed. I'd like to see one put on a dyno and compared to a 'traditional' design. It just doesn't add up to me but I'd be happy to be wrong!
sniff6
PostPosted: 17:12 - 13 Sep 2011    Post subject: Reply with quote
UUUmmm... Your right of course,How about the Grail engine??? They have devloped a new 2 stroke engine that is enviromentally friendly, can run on almost any fuel, and weighs next to nothing. I belive the 100hp motor has 1 cylinder, and weighs less than 75 lbs....imagine the possibilities.
One Litre Engine Projections based upon vehicle weight and engine demand:
* 100+ MPG’s
* 180 ft lbs Torque
* 200 Horse Power
https://www.youtube.com/watch?v=4ZxrumC_DYU&feature=player_embedded
hmmmnz
PostPosted: 19:37 - 14 Sep 2011    Post subject: Reply with quote
no its not,
the bearehead motor was a simple overhead motor that has the valve train replaced with a single sliding port operated via the original cam chain/belt, he had it running on a ducati and a dr650, it had a load more torque than standard, on a vid i saw of the dr650, the had it against a wall, and dropped the clutch at idle it would just sit there and wheel spin,
unfortuanatly someone managed to buy the patents from mr beare and shut down his site etc etc and that was the end of that,
the humans are dead
The last post was made 14 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Found on the 'Net All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 85.2 Kb
